276-137A and Current
Hello,
I've hooked up a Radio shack 276-137A IR detector's output directory
to the stamp before, even though the output is TTL, the port blew.
This leads me to my questions. Please help.
1. If you know where I can find a data sheet on this IR detector,
please share that info, i've been looking for some time now with no
luck.
2. I know these sensors "dissipate" 3.0mA, but how much current would
its output source to the stamp? In other words, why did it blow the
port on the stamp (2sx) if the stamp is capable of sinking 25mA per
pin??? I only had four inputs on the stamp..each one was one of these
detectors, and of course only reading one at a time.
3! What I plan on doing is having four of these sensors wired to say
ports 0, 1, 2, and 3, and reading their state simoultaneously by
using "InA". Theoretically this shouldn't be a problem, however my
experience with this sensor tells me this will burn these four ports.
Please give me some feedback on this, it's very important to me, as
having this work is crucial to my project.
luck.
Stamps and never had any trouble. The one thing you MUST do is make sure
that your pin is an INPUT. To be on the safe side, you can put a 1K resistor
between the Stamp pin and the output from the detector -- that will protect
the Stamp from programming errors.
-- Jon Williams
-- Parallax
In a message dated 1/11/02 6:35:25 PM Central Standard Time, cbielek@y...
writes:
> luck.
side use your advice.
--- jonwms@a... wrote:
> You may have made a programming error. I have used
> that part with BASIC
> -- Jon Williams
> -- Parallax
> writes:
> TTL, the port blew.
> this IR detector,
> time now with no
> > luck.
> much current would
> why did it blow the
> sinking 25mA per
> time.
> simoultaneously by
> problem, however my
> important to me, as
> removed]
> from the same email address that you subscribed.
> Text in the Subject and Body of the message will be
> ignored.
______________________________________________________________________
Web-hosting solutions for home and business! http://website.yahoo.ca
