Help with a ADC0834 — Parallax Forums
Help with a ADC0834
edited 2002-01-12 16:45 in General Discussion
I have an ADC0834 4 channel ADC that I want to use to monitor 4 different
temperature probes. After looking through the data sheets, I still don't
understand how the different channels are selected. Has anyone worked with one
of these or know how this is done?
Hank
    edited 2002-01-11 06:16
    Hank,
    The channel selection is made with the DI pin on the 0834. The
    addressing tables in the National data sheet show the bit
    combinations for the channel selection. The timing tables show
    how the bits are transmitted.
    Four wires are needed for the stamp connection: DI, DO, CS,
    and CLK. The code for a BS2 looks something like this
    ' adc_chan is %1100, %1101, %1110, or %1111 for channels
    ' 0 through 3 in single-ended mode
    ' first select the channel
    shiftout di_pin, clk_pin, msbfirst, [noparse][[/noparse]adc_chan]
    ' then read the data
    shiftin do_pin, clk_pin, msbpost, [noparse][[/noparse]data\8]
    Marylou
    _______________________________________
    different temperature probes. After looking through the data sheets, I
    still don't understand how the different channels are selected. Has
    anyone worked with one of these or know how this is done?
    > Hank
    edited 2002-01-12 05:51
    Thanks Marylou, I'll give that a try.
    Hank
    Sent: Friday, January 11, 2002 1:16 AM
    Subject: [noparse][[/noparse]basicstamps] Re: Help with a ADC0834
    > Hank,
    > Marylou
    Hank,
    I forgot to mention that the 0834 chip must be enabled with with the
    CS pin.
    low cs_pin
    high cs_pin
    Marylou
    > Hank
    > From: "zonie999" <apstumpf@u...>
    > To: <basicstamps@y...>
    > > Hank,
    > > Marylou
