low power voltage monitor
Hi
We built a battery voltage monitor in the standard way just using a
741 op amp. (we want to monitor for a low voltage condition on a
12volt battery) We ran the output into a BS2SX. Everything works
good, but it draws a lot of power. (>50ma) Is there a bettery, more
conservative way to do this?
Jody
Jody
a small load resistor to ground.
in selecting the zener remember to allow for ~1.4vdc to turn the stamp pin
high. For example a 1N4741a with a 100K load to Ground will read high near
12.25 volts and draw less than a milliamp.
> Hi
> Jody
It shows how to set up a 555 timer as a kind of ADC to convert a
voltage level into a pulse that varies with the voltage level. I
have incorporated this circuit into my robot power monitor and works
great.
Hal
--- In basicstamps@y..., "moparjody" <jody.gallant@s...> wrote:
> Hi
more
> Jody
