sharing LCD connections
I've got a lcd hooked up to my BS2p using seven pins, and it works just fine,
and in the manual it says that "only the Enable pin needs to remain dedicated
to the LCD and the other pins can be shared with other devices if wired
carefully". I'd like to hook the six "shareable" pins into a keypad matrix to
have nine buttons, but I'm unsure if that would fry the LCD or not, or if the
10k pulldown resistor at the stamp pin would make the LCD not function?
Also, I'm worried that when the LCD is being written to, that a pressed button
might mess it up. One solution might be to have a stamp pin provide the the
keypad matrix with +5 so I can control when the keypad is activated. Can a
single stamp pin's output be used for a keypad since there is no load?
Thank you all,
stewart
Stewart Mayer, stewlist@k... on 01/08/2002
Thank you all,
stewart
to share the LCD data lines. It worked by pulling these lines up to +5v
through 10K resistors. The normally open buttons were connected to ground
through 1K resistors. The 1K resistors are CRITICAL -- they protects the
Stamp.
When the lines are made inputs the Stamp with see +5v (1) with the button
open and about 0.45v (0) when the button is pressed.
Even if a button stays pressed, the correct data will be sent to the LCD.
When a data pin goes high the five volts will be "felt" across the 1K and the
Stamp pin will be protected (sourcing about 5 mA). When the pin goes low, it
will sink about 0.5 mA through the 10K.
When using this scheme with the BS2p, I would be inclined to manually make
all of the button pins inputs before scanning them. You can easily do this
by clearing the required bits in the DIRS register.
Hope this helps.
-- Jon Williams
In a message dated 1/8/02 10:10:06 AM Central Standard Time,
stewlist@k... writes:
> I've got a LCD hooked up to my BS2p using seven pins, and it works just
> fine,
> dedicated
> to
> the
> button
> the
lines can also be used in this manner like the data lines?
Stewart
On Tue, 8 Jan 2002 11:41:50 EST, jonwms@a... wrote:
>Scott Edwards designed a BS1 application some time ago that allowed the Stamp
>Stamp.
>Hope this helps.
>-- Jon Williams
> Sounds like a very nice solution. Thank you. Do you think that the R/W and
> RS
Yes. The only line that can't be shared is the Enable line since a pulse on
that line causes the LCD to look at the RS, R/W and data lines.
-- Jon Williams
-- Parallax
