LCD troubles.... (BASIC STAMP 1)
Hello,
I'm running into an odd problem with the BASIC
Stamp 1 and an OPTREX DMC 16128 LCD module (16x1).
The Stamp 1 drives one of my other 16x1 displays
ok but when I connect it to the OPTREX 16128 LCD
it will only display the first 8 characters. I've
got a few of these modules and they all do the
same thing. I'm at a loss as to why I can't get
the last 8 characters to display. If possible I
would like to get them to work since they are nice
large character displays.
Robert
Robert
line feed or count over a certain number of characters to get to the 2nd 8
characters on the display. This sounds like the cheesy displays I got with
my serial interface boards from MPJA.
As a side note, I finally did get the MPJA serial boards working -- but you
may have to turn the robot off / on 3-4 times to get the display to
initialize properly.
> Thanks,
> Robert
plugged it into a HandyBoard and the first line was shown in the
first 8 characters and the second line was shown in the last 8
characters.
I tried sending a linefeed (and later a CR) but still could not
write to the second bank of 8 characters on the display with the
Stamp 1. I am using the example program SERVO.BAS with the display.
I am beginning to wonder about the way it initializes the LCD and if
it might be setting it for 1 line operation. If that is the case
then I wouldn't be able to use the rest of the display since it would
be on the second line.
Anyone else see this problem before? Maybe there is a better way
to init the display.
Robert
--- In basicstamps@y..., Rodent <daweasel@s...> wrote:
> Some displays treat the 16 x 1 displays as a 2 x 8 -- ie you have
> to do a line feed or count over a certain number of characters to
> get to the 2nd 8 characters on the display. This sounds like the
> cheesy displays I got with my serial interface boards from MPJA.
second line. GOTO this link:
http://members.aol.com/jonwms/stamps
and download the file LCDDEMO2.BAS. It will show you how to deal with at
two-line display using the BS1.
-- Jon Williams
In a message dated 1/7/02 7:09:43 AM Central Standard Time,
rdoerr@b... writes:
> I did some more testing and you must be right about my display. I
> characters.
its two lines. You might also try sending characters 8 at a time, like
11111111 22222222 33333333 -- the 1's should show up in the first 8
characters, and whatever shows up in the last 8 will tell you how many
characters per line it expects.
Here are two sites for LCD's based on Hitachi chipsets:
http://home.iae.nl/users/pouweha/lcd/lcd.shtml
http://www.ferrara.linux.it/members/munehiro/lcd/hd44780_lcd0.htm
> characters.
