Stamp 1 problem
Hi, we have worked with Stamp 2sx's over the past while, but we are
trying to conserve power so we are switching to a Stamp1. Problem is
we can't seem to communicate to it. We have the Stamp.exe software,
we loaded a sample program, we built a cable, but when we do a Alt-R
we get a "Unable to Verify EEprom" message. (or something similar)
We are running the software under windows ME in a dos window. Could
this be the problem??
Any other ideas?
Jody
Any other ideas?
Jody
different from bs2 seriess stamps to bs1. The stamp manual at parallax
explains all.
Chris
Sent: Saturday, January 05, 2002 5:11 AM
Subject: [noparse][[/noparse]basicstamps] Stamp 1 problem
> Any other ideas?
> Thanks
> Jody
be sure that reset is not tied high
be sure that Palm hotsync is not in the tray
I have had some DOS ME problems in the past but not this one
Rod
Friday, January 04, 2002, 4:11:07 PM, you wrote:
m> Hi, we have worked with Stamp 2sx's over the past while, but we are
m> trying to conserve power so we are switching to a Stamp1. Problem is
m> we can't seem to communicate to it. We have the Stamp.exe software,
m> we loaded a sample program, we built a cable, but when we do a Alt-R
m> we get a "Unable to Verify EEprom" message. (or something similar)
m> We are running the software under windows ME in a dos window. Could
m> this be the problem??
m> Any other ideas?
m> Thanks
m> Jody
m> To UNSUBSCRIBE, just send mail to:
m> basicstamps-unsubscribe@yahoogroups.com
m> from the same email address that you subscribed. Text in the Subject and
m> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Best regards,
a.rodriguez mailto:stuff@m...
doesn't work. We hooked it up to our HP protocol analyzer, and it
appears as though the BUSY pin is staying high, and when you try to
program the stamp it does not even try to go low.
Our next attempt will be on a different PC with a PURE dos boot. I
hate WindowsME. It has caused problems before when programming old
Motorola Radios.
Jody
--- In basicstamps@y..., "Chris Anderson" <fuel@b...> wrote:
> Are you using the stamp1 dos editor, and a suitable cable?. If not,
they are
parallax
> explains all.
> Chris
high, but should I maybe tie it low (gnd) to be sure its not getting
noise?
We tied it to our protocol analyzer. The Busy PIN is not even trying
to go low when you do a write.
Our next attempt will be on a pure DOS only machine.
Thanks for the help.
Jody
--- In basicstamps@y..., "a.rodriguez" <stuff@m...> wrote:
> Hello moparjody,
> Rod
Chuck
