DS1302 RTC Accuracy
I've built a school-bell alarm system for my old High School. The time
seems to be running a little fast (gains a couple seconds an hour). Any
good ideas on how I can increase the accuracy? I have the crystal as close
as I can wire-wrapping. Should I solder it directly to the X1/X2 leads?
The data sheets call for a 6pf crystal, but I think I am using a 10pf,
standard RTC issue 32.768KHz.
Martin Hebel
Martin Hebel
How temperature friendly is your environment? You could put a variable
capacitor across the crystal and use it to "pull" the frequency. You
could either measure the frequency with a counter or trial and error
until you aren't losing time. A small trimmer capacitor (10 or 20pf)
would probably do the trick. This allows you to dynamically compensate
for circuit capacitance that you can't easily predict without heavy-duty
modeling. However, trimmers are not known for great temperature
accuracy.
Also, crystals themselves are fairly temperature sensitive. In very
critical circuits they are put in an "oven" that keeps them hot.
Probably overkill here though.
I'm not sure if some types of variable capacitors are more temperature
stable than others? The little trimmers would probably be pretty good. A
mica compression trimmer might be more or less stable, I really don't
know.
Al Williams
AWC
* Easy RS-232 Prototyping
http://www.al-williams.com/awce/rs1.htm
> From: martin@s... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=SRkmkdKCnLuyr2P2Qf6002Wv1mNiK6MdiGKG4oxzQqTi__FIS71_z4J0jMrI-yeWVEKeu7d25mFOAQ]martin@s...[/url
> Sent: Thursday, January 03, 2002 8:34 AM
> Subject: [noparse][[/noparse]basicstamps] DS1302 RTC Accuracy
> The time seems to be running a little fast (gains a couple
> seconds an hour). Any good ideas on how I can increase the
> accuracy? I have the crystal as close as I can
> using a 10pf, standard RTC issue 32.768KHz.
> Thanks,
> Martin Hebel
> from the same email address that you subscribed. Text in the
I'll give it a shot. Hope Radio Shack carries trimmer pots because
I'm out of time for ordering!
-Martin
--- In basicstamps@y..., "Al Williams" <alw@a...> wrote:
> Hi Martin,
variable
compensate
duty
> accuracy.
temperature
good. A
don't
> know.
> Al Williams
> AWC
> > From: martin@s... [noparse][[/noparse]mailto:martin@s...]
> > To: basicstamps@y...
> > Thanks,
> > Martin Hebel
> > basicstamps-unsubscribe@y...
might be able to RSU them for you. Might take apart a cheap digital
clock and see if you could find one :-)
http://www.radioshack.com/category.asp?catalog%5Fname=CTLG&category%5Fna
me=CTLG%5F010%5F002%5F025%5F000&Page=1
If you need just a little pull, you can make your own variable capacitor
of unknown characteristics. Two wires twisted together are known as a
"gimmick" capacitor. The insulation of the wire is the dielectric. Two
pieces of metal tubing and an insulating sleeve will work if you have
one metal tube big enough to hold the insulating sleeve and the sleeve
large enough to hold the smaller tube. Adjust it to the right spot and
glue it together :-)
Believe it or not, I've either done these things or seen them done first
hand :-) A quick Web search shows I'm not the only one that remembers
the gimmick: http://www.shol.com/kuggie/cttip/pix/gimmic.jpg
This is one of those weird things that someone eventually applied for a
patent on it even though there were 50 years of prior art. Don't know
how that turned out :-)
Al Williams
AWC
* Floating point math for the Stamp, PIC, SX, or any microcontroller
http://www.al-williams.com/awce/pak1.htm
> From: selmaware [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Uuc732Tk3pdASlXo4HCafGhswtI7RzvPmvhBcsx-j9INdhyfb5D9AqFMGNuf1i7LCGVLumgQKPiEBg]martin@s...[/url
> Sent: Thursday, January 03, 2002 9:01 AM
> Subject: [noparse][[/noparse]basicstamps] Re: DS1302 RTC Accuracy
> Thanks Al,
> -Martin
> > Hi Martin,
> variable
> frequency. You
> and error
> or 20pf)
> compensate
> duty
> > accuracy.
> temperature
> good. A
> don't
> > know.
> > Al Williams
> > AWC
> > * Easy RS-232 Prototyping http://www.al-williams.com/awce/rs1.htm
> School. The
> > > time seems to be running a little fast (gains a couple seconds an
> accuracy? I have
> > > the crystal as close as I can wire-wrapping. Should I solder it
> > > Thanks,
> > > Martin Hebel
IIRC, crystals have a parabolic tempco curve.
Those designed to operate in an oven are cut so that the
inflection point of the curve is at the oven's operating
temperature.
Ordinary crystals are designed with the inflection point
nominally at room temperature. I think if you put one of
those in an oven, it will actually accentuate the frequency
change vs. temperature.
Of course if the oven's temperature regulation is good
enough, that won't make an difference.
Reg
One other way that works for both slow and fast crystals is to use a
software adjustment.
Your crystal's accuracy may be a bit off, your crystal's stability probably
isn't.
So if you monitor the clock for exactly 24 hour and find it is 96 seconds
fast (4 secs per hour),
you could compensate for that by waiting for the time to be hh[noparse]:mm:[/noparse]04 and
then
resetting the time to hh[noparse]:mm:[/noparse]00 (adjust per hour).
Regards peter
Oorspronkelijk bericht
Van: martin@s... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=aM92TOsXzQDTR4lavi6UbGnjRQT6jzrIDHx7LiWtzyAVGwoIuIzOX_LbEU5hel_GU4qr_b-SY95xsmnpgIw]martin@s...[/url
Verzonden: donderdag 3 januari 2002 6:34
Aan: basicstamps@yahoogroups.com
Onderwerp: [noparse][[/noparse]basicstamps] DS1302 RTC Accuracy
Martin Hebel
>The time seems to be running a little fast (gains a couple seconds
>an hour). Any good ideas on how I can increase the accuracy? I
>have the crystal as close as I can wire-wrapping. Should I solder
Hi Martin,
Soldering directly to X1/X2 might help. the wire-wrapping probably
adds inductance in series with the xtal as well as capacitance in
parallel, both of which will pull the frequency down.
The frequency of a watch xtal should fall within +/-30 ppm at 25
degrees C. That amounts to 30/1000000 * 3600 ~< 0.1 second per hour.
As Reg pointed out, the temperature response of tuning fork watch
crystals is parabolic downward, so they run slower at temperatures
either lower or higher than 25 degrees C. A wristwatch has the
luxury of operating in the constant temperature "oven" of a person's
wrist!
Other ideas (but not without ordering something):
-- The Dallas DS32kz oscillator is guaranteed within 4 minutes per
year over the entire industrial temperature range.
-- A link to WWVB transmissions should be possible there at SIU,
http://www.ulio.com/timepr.html. Unfortunately, I think Ultralink
has stopped offering the OEM time receiver that was most
Stamp-friendly.
Finally, both teachers and students will thank you if the bell rings
a couple of seconds early. ..so long as you correct it before school
starts each day so they won't be tardy!
-- best regards
Tracy Allen
http://www.emesystems.com
mailto:tracy@e...
With crystals there are two considerations: accuracy and stability.
On accuracy:
Remember the guiding principle that increased capacitance slows the xtal
down. Reducing it speeds it up. In the trade this is called 'pulling'.
I seem to remember the original posting was concerned with trying to slow it
down. So we are in the business of adding capacitance to pull the xtal down.
The trimmer capacitor concept is the most easily adjustable physical
solution. 2-10pf trimmers are good. For a temp test, a wire twist is also
good. If more pulling down is required then add a further fixed value across
the xtal.
Placing a capacitor across a xtal is also sometimes used to help temerature
compensation. If the right capacitor type is used - eg one which increases
capacitance at lower temperatures, then this helps mitigate the temperature
effect on the xtal. This is usually done by means of a fixed capacitor plus
a trimmer. This technique is a classic in radio systems where stability to
5Hz per minute is sometimes required.
On Stability:
In the real world, unless you have a lemon, the stability of the xtal is
probably sufficient for your needs and a trimmer will probably not detract
from the overall long-term stability.
However if the accuracy of the xtal is way out, a trimmer will probably make
things worse as it may be pulling the xtal out of its band stability. If you
can't subsitute another xtal for comparison, then the technique of applying
a software fix described in another post will have to do.
I hope this all makes sense!
Tony Wells
