Need Help on this power supply.
I am designing a supply with 6V battery and a 9 Volt DC Source, what
I want is that when I connect the circuit on the 9 V DC, the 6 V
Battery supply will diconnect and when I disconnect the 9 V DC the 6
V Battery will reconnect, this will happen without variation in the
output voltage of the circuit.
Please help.
Please help.
battery to the load thru a diode. This will leave about 5.3 volts available
to the load. When the 9 volt source is connected directly to the load, load
voltage will rise to 9 volts; the battery will be "off" because the diode is
reverse biased. When you disconnect the 9 volts, the battery will again
take over. The diode must be rated for your load current.
Hope this helps,
Ray McArthur
Sent: Thursday, January 03, 2002 12:33 AM
Subject: [noparse][[/noparse]basicstamps] Need Help on this power supply.
--- In basicstamps@y..., "Ray McArthur" <rjmca@u...> wrote:
> If you can afford approx. 0.7 volts diode drop, you can connect the
6 volt
available
load, load
diode is
again
> Hope this helps,
> Ray McArthur
> From: mysemicon2000 <semiconductor@p...>
> To: <basicstamps@y...>
what
the 6
the
Rectifier site, these diodes comes 2 in a TO-220 package, common
cathode) and a low dropout regulator.
the 9v and the 6V sources at the anodes of the or'ing diodes.
what
6
> Please help.
another post suggested, you can gain a few tenths of a volt with a schottky
diode.
Ray McArthur
Sent: Thursday, January 03, 2002 2:30 AM
Subject: [noparse][[/noparse]basicstamps] Re: Need Help on this power supply.
> Have you tried this circuit already?
> 6 volt
> available
> load, load
> diode is
> again
**************** etc.
