Controling a step motor, need help!
I need help controlling a bipolar geared step motor (4 leads) with a
basic stamp 2. i know that you cant just hook them directly you need
some kind of a motor driver to control the step motor.
What motor driver should i use? can i build one or do i have to buy
it? i need a simple solution so that i could make the step motor do
the following:
- forward rotation
- reverse rotation
i dont need it 2 do any other fancy things just simple forward and
reverse (at about 60 rpm). i need the simplest motor driver to do this
that interfaces with basic stamp 2!
thanks alot!
the following:
- forward rotation
- reverse rotation
thanks alot!
I use and L293D it's very easy to use. check out
http://focus.ti.com/docs/prod/productfolder.jhtml?genericPartNumber=L293
http://www.seattlerobotics.org/encoder/may98/steppers.html
Rod
Tuesday, January 01, 2002, 8:56:16 PM, you wrote:
e> I need help controlling a bipolar geared step motor (4 leads) with a
e> basic stamp 2. i know that you cant just hook them directly you need
e> some kind of a motor driver to control the step motor.
e> What motor driver should i use? can i build one or do i have to buy
e> it? i need a simple solution so that i could make the step motor do
e> the following:
e> - forward rotation
e> - reverse rotation
e> i dont need it 2 do any other fancy things just simple forward and
e> reverse (at about 60 rpm). i need the simplest motor driver to do this
e> that interfaces with basic stamp 2!
e> thanks alot!
e> To UNSUBSCRIBE, just send mail to:
e> basicstamps-unsubscribe@yahoogroups.com
e> from the same email address that you subscribed. Text in the Subject and
e> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Best regards,
a.rodriguez mailto:stuff@m...
