Multi-channel ADC
I am looking to use a multi-channel ADC that has at least 2 input channels as I
want to monitor 2 different analog sensors. What would be good to use instead of
using 2 separate 0831's? Are there any other things to look out for when using
something like this?
Hank
Hank
Try the TLC2543 from TI. 11 channel 12-bit. Easy to program. Price is
better than a 2- or 4- channel.
Sid
The LTC-1298 is a 2 chan 12 bit A/D that would work. Microchip also
has an 8 chan 12 bit A/D thats a bit more complicated but both can be
easily used with a BS2 using the shiftin and shiftout instructions.
(See page 353 of v1.9 manual) or Stamp aplication #22 for a BS1 on
page 183.
The chips can be had a Digikey.com for a few bucks each.
Hope this helps,
Mark
channels as I want to monitor 2 different analog sensors. What would
be good to use instead of using 2 separate 0831's? Are there any
other things to look out for when using something like this?
> Hank
edit out most of the "quoted" part of the message. This list seems to
have an inordinate amount of one-line messages followed by two hundred
lines of quoted text. Thanks.]
You could try the ADC0838, and 8-channel version of the 0831. There's
code for it in the archive, you can find it at:
http://www.jamesrusso.com/stamp/archive/1997/stamps.9701/msg00311.html
---- o.o___.
