BS2 to Sandisk MMC memory card?
I've been trying for sometime to interface a Sandisk 16MB
MultiMediaCard with a Parallax Basic Stamp 2 without success.
The 5v Stamp pin signals have been converted to MMC levels (~3.18v)
and using various application documents that I've found,
I think I've got the physical construction right (logic probe looks
good) but it doesn't act exactly the way it should. Specifically:
To power up the card and initialize it into SPI mode (which I need to
use), the documentations says to
1)send at least 74 (80 is suggested) clock pulses
2)set CS pin to LOW
3)send the reset command (CMD0), which is 0x4000 0x0000 0x0095 (I'm
using SHIFTOUT/MSBFIRST)
4)send 8 clock pulse as delay
5)SHIFTIN 8 bit response code
[noparse][[/noparse]until response code is 0x01, keep sending CMD0]
6)8 pulse delay
7)send the init command (CMD1), which is 0x4100 0x0000 0x0000
(SHIFTOUT/MSBFIRST)
8)8 pulse delay
9)SHIFTIN 8 bit response code
[noparse][[/noparse]until response code is 0x00, keep sending CMD1]
At this point, the MMC should be in SPI mode and awaiting a command
to read/write a block of data.
The problem is that I can't get to that point. First, I cannot get
ANY response from the card unless I
send 21 plus a multiple of 25 clock pulses (21, 46, 71, 96, etc...).
When I do that, I can send CMD0
and loop the SHIFTIN of 8bits. This is what is (always in this order)
shifted in:
1) 0111 1110
2) 0000 0011
3) 1111 1111
4) 1111 1111
5) 1111 1111
6) 1111 1111
7) 1111 1111
8) 1111 1111
9) 1111 1110
10)0000 1011
...bytes 3 through 10 then loop indefinitely.
If, instead of looping the SHIFTIN, I continue sending CMD0 in order
to get the 0x01 response code, I never get it.
If I just continue on to issuing CMD1, the same thing happens which
is shifting in that loop of blocks 3 through 10
as if it's ignoring my CMD0 and CMD1 commands.
I think I've exhaused every PDF and HTML document I could find on the
subject and I'm hoping someone might
have had the same problem and figured it out.
ANY HELP IS APPRECIATED!!!
thanks
Jim Swensen
[noparse][[/noparse]jswensen*volcanomail,com]
2)set CS pin to LOW
6)8 pulse delay
(SHIFTOUT/MSBFIRST)
8)8 pulse delay
shifted in:
1) 0111 1110
2) 0000 0011
3) 1111 1111
4) 1111 1111
5) 1111 1111
6) 1111 1111
7) 1111 1111
8) 1111 1111
9) 1111 1110
10)0000 1011
thanks
Jim Swensen
>2)set CS pin to LOW
>6)8 pulse delay
>(SHIFTOUT/MSBFIRST)
>8)8 pulse delay
Jim -
Try setting CS LOW right from the get go. With CS LOW on power-up the MMC is
automatically in SPI Mode. Hopefully that will get you started in the right
direction.
Just as a matter of curiosity, how are you intending to overcome the
(seeming) requirement of 512 byte reads ?
Bruce Bates
http://www.compsys1.com/workbench/On_top_of_the_Bench/MMC_Project/mmc_pr
oject.html
> subject and I'm hoping someone might have had the same problem and figured
> it out. ANY HELP IS APPRECIATED!!!
> thanks
> Jim Swensen
Mike, that's a cool site but I couldn't find any technical details. I
don't want to ask them for "trade secrets" if they're selling it.
Bruce, in playing around with then number of clock pulses and the
whether I sample data right before the "first" pulse or the "second"
pulse, I've found that if I run 96 clock pulses, set CS to low, send
CMD0, I do indeed get my 0x01 as the second byte of info.
When I power up with CS low, I get data but I can't get that 0x01!
Reverting back to CS low after power up, the problem now is that when
I try to issue CMD1, I get 0x101 which is to be expected when an
invalid CMD is issued. I don't know what is wrong with my CMD1 since
it takes no arguments and CRC isn't even turned on.
I've read that some old MMCs aren't manufactured to enter SPI mode,
only MMC mode even though the specifications call for it. The
information was dated early 2000, so I'm hoping that if that was the
case, it is no longer. It's all very frustrating.
But to answer your question, with the exception of Hitachi MMCs
(according to their documentation), the MMC can be set for variable
block lengths to write. Default is 512 bytes. If that doesn't work
for me, I guess I'll have to use a buffer chip.
Jim
Give Milford Instruments in the UK a call. I don't have their number to
hand, but download their catalogue..
www.milinst.com/fullcat.pdf
..they sell something called a Megastor, which is a small devt board,
sandisk 16Mb card
and BS2 working source code.
Costs about 50UKP.
Hope that helps if you can't solve it free!
Regards
Les
From: jswensen500 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=raiJX0XAOfcFsheCDcFVtMZ7aCzwFzT3oiwsP65cFuXlpH1Vsal0io4wbaYQI5iUDku0hzkfjw_LbbBoqw]jswensen500@y...[/url
Sent: 31 December 2001 11:03
Subject: [noparse][[/noparse]basicstamps] BS2 to Sandisk MMC memory card?
2)set CS pin to LOW
6)8 pulse delay
(SHIFTOUT/MSBFIRST)
8)8 pulse delay
shifted in:
1) 0111 1110
2) 0000 0011
3) 1111 1111
4) 1111 1111
5) 1111 1111
6) 1111 1111
7) 1111 1111
8) 1111 1111
9) 1111 1110
10)0000 1011
thanks
Jim Swensen
requires 512 byte writes and has PicBasic source code. Mr. Diol is on the
PicBasic
list and I don't think he is selling it.
He used a PIC at 3.3V to avoid the buffering.
On 1 Jan 2002 at 17:45, basicstamps@yahoogroups.com wrote:
> Thanks Bruce and Mike
websites looking for information on this that I only scanned through
looking for specific words and phrases and didn't pay enough
attention. After reading your message, I went back and the code
immediately jumped in front of my face. The only problem is that it's
written for a PIC16F876 with an external eeprom and I don't initially
see where his initialization process is different from mine. So I'm
going through the code and changing it to my configuration and
hopefully even if I don't see a difference in the CODE, I'll see a
difference in the output.
Thanks for the heads up!
--- In basicstamps@y..., "Mike DeMetz" <miked@t...> wrote:
> Really? He has a schematic, describes the need for an EEPROM
because the MMC
on the PicBasic
You know, that was one of the first websites I found while
researching whether or not to try this project. Seeing the picture of
the Megastor convinced me that I could do it (a few headaches
notwithstanding). I feel that I'm very close to getting this nut
cracked, and that's what is maddening about these obstacles.
If I can't get it done then I'm going to send MI an order for one!
Jim
--- In basicstamps@y..., "Les Otter" <lesotter@s...> wrote:
> Jim
number to
board,
> sandisk 16Mb card
> Costs about 50UKP.
> Regards
> Les
> From: jswensen500 [noparse][[/noparse]mailto:jswensen500@y...]
> To: basicstamps@y...
to
> 2)set CS pin to LOW
> 6)8 pulse delay
> (SHIFTOUT/MSBFIRST)
> 8)8 pulse delay
order)
> shifted in:
> 1) 0111 1110
> 2) 0000 0011
> 3) 1111 1111
> 4) 1111 1111
> 5) 1111 1111
> 6) 1111 1111
> 7) 1111 1111
> 8) 1111 1111
> 9) 1111 1110
> 10)0000 1011
the
> thanks
> Jim Swensen
> basicstamps-unsubscribe@y...
Subject and
other is brand new sealed. I will sell it to you for a bit cheaper than
Milford.
P.S. Contact me at my email if you are interested. rryerson@o...
Richard
Sent: Wednesday, January 02, 2002 1:09 AM
Subject: [noparse][[/noparse]basicstamps] Re: BS2 to Sandisk MMC memory card?
> Thanks Les,
> Jim
> > Jim
> number to
> board,
> > sandisk 16Mb card
> > Costs about 50UKP.
> > Regards
> > Les
> to
> > 2)set CS pin to LOW
> > 6)8 pulse delay
> > (SHIFTOUT/MSBFIRST)
> > 8)8 pulse delay
> order)
> > shifted in:
> > 1) 0111 1110
> > 2) 0000 0011
> > 3) 1111 1111
> > 4) 1111 1111
> > 5) 1111 1111
> > 6) 1111 1111
> > 7) 1111 1111
> > 8) 1111 1111
> > 9) 1111 1110
> > 10)0000 1011
> the
> > thanks
> > Jim Swensen
> Subject and
