Qprox 113
I took the great suggestions I received from this list and purchased
the E11x demo board from Quantum, and it works great. But I have
the following problems:
1- I can activate the board by getting my finger close to or on the
sensing area. I can do the same with a piece of metal, certain type
of plastic but not with a piece of wood, a pencil or fork???? I
don't understant why?
2 What is the correct set up for the QT113 for my application which
consist of a rotating drum with rows of pegs sticking out of it. I
am placing a QT113 under each row. The analogy is a jewlery music
box. When there is a peg, the QT113 triggers a relay, when nothing,
nothing happens. The rows are about 1" apart.
Hope you can help.
Al
Hope you can help.
Al
Hope you can help.
Al
The metal or your finger are relatively good conductors and can act
as the plates of a large capacitor. The certain type of plastic may
also be metalized. But the wood, pencil or fork (plastic fork??) are
not. You can turn a living plant into a touch switch, because it is
as much water as wood. Read the Qprox literature. It has pretty
good explanations.
What is the wheel made of? The pegs must cause a significant change
in capacitance. Why a QT113 and not an optical or magnetic method?
