Pulse Conditioning for BS2
I am in the process of building a data logger for my car. It has an
onboard computer already, so many of the signals are there just
waiting to be logged. One of the more challenging channels has
turned out to be the rpm's. After toying with other ideas, I found
the signal going to the tach as the likely (relatively transient
free) signal source.
Here is what I know about the signal:
It is a square wave of some kind (per the cryptic manual), although I
do not know if it drives the tach via pulse width modulation or
frequency of pulses.
I probed the signal and found this:
at 850 rpms: 9.5vdc per multimeter, 85% duty cycle, 30ms positive
pulse, 5.2ms negative pulse
at 2000 rpms: 8.4vdc on multimeter, 75% duty cycle, 11.2ms pos pulse,
3.8ms neg pulse
at 3000 rpms: 7.2vdc, 63.5% duty cycle, 6.4/3.7 pos/neg pulses.
4 cylinder car, two sparks per revolution. Can anyone tell me how
the signal relates to rpms? Once I understand the signal, I need to
scale it down to fit into a BS2 input pin. ANy suggestions there?
Two resistors in series and a zener diode?
p.s. I am not sure I understand my multimeter pulse units. It
says "ms" but also seems to be auto-ranging (range 4? --Fluke), so it
may be some multiple of 10 times the readings quoted above.
3.8ms neg pulse
cycle for each half revlotion of the motor. The math works perfectly.
(At 2k rpms for example, the cycle is 15ms. Since there are 60k ms in
a minute, there are 4k cycles in the signal per minute, or 2k rpms
per minute. Same math works for other data given below as well.)
BS2 questions:
1) I would like to use pulsin to measure the pulse width on this
signal, although I will need to read the entire cycle and not just
the "on" time. How do I read the complete cycle time on a BS2? (I
want to measure the time it takes go from one "low to high" to the
next "low to high." ) Do I need to set up a flip flop? Any easier all-
software way?
2) The peak voltage of the signal is probably 12vdc, although the
pulsing makes it read lower on the multimeter. Is it safe to read
this signal directly to a BS2 input pin for the pulsin command?
Assuming not, can anyone suggest a means of reducing the peak voltage
to 5 volts without affecting the pulse cycle time?
Thanks!
I
pulse,
> 3.8ms neg pulse
it
Take two Pulsin measurements, one with the hi/low setting set to 0, and the
other set to 1. Add the values, and you'll have a cycle length. Those two
measurements won't be from the same cycle, but they'll be close enough for
what you are doing.
Use a voltage divider, a series of diodes, or an attenuator to drop the
voltage. You'll want to make sure your circuit doesn't affect your tach.
By the way, for solving problems you mentioned in your first email, I've
found that Excel helps a lot to find out if signals are linear. You can
punch in the pulse times for your three tach readings and look at a graph.
Cliff
Sent: Friday, December 28, 2001 8:04 PM
Subject: [noparse][[/noparse]basicstamps] Re: Pulse Conditioning for BS2
Ok, sorry I rambled below. The signal I found generates one full
BS2 questions:
software way?
Thanks!
I
pulse,
> 3.8ms neg pulse
it
>BS2 questions:
>software way?
It is really a question of two full cycles. That could be handled by
a divide-by-four circuit, or by one of the available pulse
measurement modules. To do it all-software, you have to do four
pulse measurements in succession and then combine them,assuming that
the rpm does not change much in 2 revolutions.
pulsin 0,0,[noparse][[/noparse]H1]
pulsin 0,0,[noparse][[/noparse]H2]
pulsin 0,1,[noparse][[/noparse]L1]
pulsin 0,1,[noparse][[/noparse]L2]
totalpulse=H1+H2+L1+L2
You can connect it to the stamp through a voltage divider
12v---/\/\-o-/\/\---Vss
20k | 10k
p0
In a pinch you can connect it through a single resistor
12v
P0
47k to 100k
But do _*not*_ connect it direct without a resistor or some kind of
protection. If there is noise on the signal, you can put a small
capacitor (~100pf or 1000pf) from the Stamp input to Vss to help.
-- regards,
Tracy Allen
mailto:tracy@e...
http://www.emesystems.com
system failed I did a search for the model number and came up with a whole
pile of info about the diagnostics, including pinout details.
Tony Wells
Sent: Saturday, December 29, 2001 3:20 AM
Subject: [noparse][[/noparse]basicstamps] Pulse Conditioning for BS2
> 3.8ms neg pulse
the time from one "low to high" to the next "low to high"? Isn't
that just two pulsin commands? (Maybe I confused things by using the
word "cycle" -- I meant one high pulse and one low pulse.) As for a
voltage divider, my concern is that I not draw current from the car's
signal. I'd like the stamp to behave as much like a high-impedance
multi-meter as possible, to avoid any issues with the car's computer.
How much current does the stamp need to register a high state?
Could I, for example, use resistors near 1meg for the voltage divider?
perfectly.
in
> >BS2 questions:
all-
> >software way?
by
that
voltage
> 20k | 10k
p0
> 12v
P0
> 47k to 100k
> -- regards,
> Tracy Allen
> mailto:tracy@e...
I thought what you want is the time for one revolution. According to
your data, the electrical signal has two full cycles during each
revolution of the shaft. So to get the time for one full revolution,
you have to measure two LOW times and two HIGH times.
Here was your data:
>3.8ms neg pulse
The 11.2ms plus 3.8 ms add up to 15 ms. But the time for one
revolution at 2000rpm is 30 milliseconds. That is where the factor
of two comes from. I don't know how this is tied together
mechanically. You might get away with timing one cycle and
multiplying by two.
The program works by sampling low and high pulses over two revolutions:
(view with monospace font)
|.....2 revs....|
---_---_---_---_---_---_---_---_---_
a b c d e f g h
pulsin 0,1,[noparse][[/noparse]H1] ' measures HIGH pulse a
pulsin 0,1,[noparse][[/noparse]H2] ' measures HIGH pulse c
pulsin 0,0,[noparse][[/noparse]L1] ' measures LOW pulse f
pulsin 0,0,[noparse][[/noparse]L2] ' measures LOW pulse h
that should be the same as a+b+c+d for one revolution.
>As for a
You can try an experiment by putting a 100kohm resistor across the
tach signal, and see on your voltmeter if there is any change. (This
is another instance of measuring output resistance of the "black
box", like we talked about earlier in this thread.) My guess is that
the tach signal is at a low impedance level and 100kohm would not
load it significantly. Its sourcing and sinking capabilities may be
different. A bigger issue is ground loop noise in the nasty
automotive environment. It might be wise to use an opto isolator;
the tach would have to be able to source or sink a couple of
milliamps to make that feasible.
The stamp input is very high impedance, which means it needs
practically zero current to register a high state. You can try it
with one megaohm, but the signal might be too sluggish, due to stray
capacitance in the circuit.
-- regards,
Tracy Allen
mailto:tracy@e...
high" to the next "low to high") and you were trying to get the time
for the complete revolution. I think I'll be fine just multiplying
the half rev time by 2, but I think I understand it now, so thank you
very much.
When we last spoke of impedance, we were talking about an input on a
black box. I put a resistor between my voltage signal and the black
box and confirmed that there was no difference in voltage on either
side of the resistor, and concluded it was a high impendance input,
which gave me comfort that I would not blow it out by feeding it too
much current. This time around, we are talking about an output on the
same black box. Where are you suggesting I put the 100k resistor for
this purpose? Just hang it off the end of the tach signal and see if
I get less voltage on either side of the resistor? If the voltage is
the same, then are you saying that the output from the black box
is "low impendance?" And, if so, does that necessarily mean it can
handle a voltage divider using resistors more in the 10k range? To
me, logically, it just means that the voltage divider will not throw
off the voltage signal running to the rest of the original circuit,
but does not necessarily mean the black box's output can provide the
current needed to run the voltage divider.
And, to check my understanding, when I ran the first test to conclude
the black box input was high impedance, then I think I also obtained
evidence (unknowingly at the time) that the output of the voltage
follower ciruit was low impedance. Yes?
> >Thanks for the suggestions. Why would I need 4 pulsin commands to
get
the
to
revolution,
> Here was your data:
pulse,
> >3.8ms neg pulse
> multiplying by two.
revolutions:
> |.....2 revs....|
> a b c d e f g h
> >As for a
car's
computer.
divider?
(This
that
be
stray
> -- regards,
> Tracy Allen
> mailto:tracy@e...
a .1volt difference on the voltmeter on either side of the resistor.
(The volt reading reflects an 85% "on" pulsed 12vdc signal, so the
actual voltage drop may be slightly greater.) For reference, the tach
signal is still fully functioning in its circuit. It goes from the
black box directly to the tach, and also directly to another black
box that uses it to create the ignition timing signal. I just tapped
into it to check the voltage/pulse. The voltage was .1vdc lower when
I checked it through a 100k resistor.
> I see. I was content timing half a revolution (i.e. from one "low
to
time
you
> very much.
a
too
the
for
if
is
throw
the
conclude
obtained
to
> get
using
> the
> to
> revolution,
> > Here was your data:
> pulse,
> > >3.8ms neg pulse
factor
> > multiplying by two.
> revolutions:
> > |.....2 revs....|
> > a b c d e f g h
> > >As for a
> car's
impedance
> computer.
> divider?
the
> (This
> that
> be
isolator;
it
> stray
> > -- regards,
> > Tracy Allen
> > mailto:tracy@e...
That experiment allows you to estimate the input resistance. I think
you added the 100k resistor as follows:
"black box 1 output" ----/\/\---- "black box 2+3 input"
100k
The voltage on the left side of the resistor was about 0.1 volt
greater than the voltage on the right, say 10 volts and 9.9 volts.
Yes? That lets you estimate the input resistance of black box 2+3.
The current through the 100kohm resistor is V/R = 0.1/100000 =~ 1
microamp. That 1 microamp also flows through the input resistance of
black box #2+3, which has 9.9 volts across it. So the input
resistance is, R=V/I=9.9 megaohms. Roughly 10 megaohms, give or take
a few. Pretty high.
To measure the output resistance of black box 1, connect the 100kohms
as follows:
"black box 1 output" --o
Vss---/\/\
100kohm
That is, direct from the output to ground. What is the voltage
before and after you connect in the resistor? E.g., 10.0 before, 9.9
after. If there is no change, then try 10k or even 1k. If there is
no change at all, then the output resistance is much much less than
the value of resistance you are trying. If the output drops to 1/2
of its original value, then the output resistance equals the added
resistance. The point is, if you add your own "black box" to the
circuit, you do not want to load it down too much. The test give you
an estimate of how much is too much.
-- regards,
Tracy Allen
mailto:tracy@e...
to the tach signal going from one black box to the other. Using a
multimeter on the tapped line (red lead to tapped line, black lead to
ground), I found the pulse and voltages I listed yesterday. Today, I
put a 100k resistor on the end of the tapped line (in series between
the tapped line and the red lead of the multimeter). With the
resistor in place, I have about.1vdc less than without the resistor.
I thought about doing it like your second suggestion (100k to ground)
but got paramoid. At any rate, I ended up making a voltage follower
out of an LM358, and sent my tach signal to it through a 100k
resistor. I then used a voltage divider on the 12v output of the
LM358, and everything seems to be working fine. I assumed (hopefully
correctly) that the LM358 with 100k resistor would have virtually no
effect on the rest of the circuit, and that the votage divider on the
output side of the LM358 (using 10k and 20k resistors) would not over-
tax the LM358 output. At least it all seems to work...sound ok? I am
reading up on basic electronics and am admittedly a bit stumped on
the impedance concept. Your help has been invaluable...I'll get
there. Now, I am starting to struggle with BS2 math calculations to
turn my pulse readings into actual rpms. I found your write-up in the
FAQ, but may be looking for help soon. I need to divide 30000 by the
pulse width (in milliseconds) I measure, and I'm trying to do it
without taking up too much cpu time. I'll play with that tomorrow.
Thanks again.
> >Well, I put a 100k resistor on the tach signal and there was about
resistor.
tach
tapped
when
think
> 100k
of
take
> a few. Pretty high.
100kohms
> as follows:
> Vss---/\/\
> 100kohm
9.9
is
you
> -- regards,
> Tracy Allen
> mailto:tracy@e...
Perhaps I've missed something here. Forgive me if I have.
Wouldn't it be easier to count the number of cpu cycles between each pulse?
If the pulses are too short an interval, use a divide by 10 or divide by 100
counter.
Yes, you would have to calibrate it, but the code would be simpler, and you
can choose when to sample - say once per second.
Tony
Sent: Sunday, December 30, 2001 10:43 AM
> Oops, I think I mistook your original suggestion. I connected a wire
> Thanks again.
> resistor.
> tach
> tapped
> when
> think
> > 100k
> of
> take
> > a few. Pretty high.
> 100kohms
> > as follows:
> > Vss---/\/\
> > 100kohm
> 9.9
> is
> you
> > -- regards,
> > Tracy Allen
> > mailto:tracy@e...
You have measured the input resistance of your multimeter!
>but got paramoid.
All advice here is taken strictly at your own risk!
Yes.
E.g., 30000/15=2000 rpm, but 30000/14=2143rpm, quite a big unit step
of 143, no? What resolution do you expect?
The pulse width from the pulsin commnad will be in units of 2
microseconds, e.g. 15 milliseconds will come out as PW=7500 counts.
The measurement of pulse width has lots of resolution, 4 digits. On
the face of it, 15000000/7500 = 2000 but the numerator is too big for
the Stamp to handle in one step. The Stamp can handle it as
(shortcut #2 at <http://www.emesystems.com/BS2math2.htm>)
' 150000/(PW/100) = 600000/(PW/25)
PW=PW/25 ' scale down
RPM = 60000/PW*10+(60000//PW*10/PW)
Thus when PW=7500, PW/25=300, RPM=2000
and when PW=7475, PW/25=299, RPM=2006
A unit step of 6.
There are more accurate methods, but they would take more CPU time.
-- regards,
Tracy Allen
mailto:tracy@e...
enough. I seem to be having some real word "issues" however,
probably relating to my voltage follower. First, the program does not
want to work in the car unless I touch either or both of the power
supply leads...makes me think I need a capacitor somewhere. Second,
when the program is running, the pulsin command generates slightly
smaller pulse times than is actually on the tach signal (according to
my Fluke), resulting in slightly higher than real rpms. As I
mentioned, I used an LM358 as a voltage follower, and split the
output of the LM358 with a 10k and 20k resistor. Could that be
throwing off the timing? I am measuring one low and one high pulse
and adding them together, so I would think the result should be the
same even if the output is shifted a bit. For what it is worth, I may
try smaller resistors on the voltage dividers, since I cannot get my
Fluke to pick up the pulse at all when measuring in the middle of the
divider (which is where the Stamp is getting the pulse). I'm getting
there! Thanks.
> >Today, I
between
resistor.
ground)
> >but got paramoid.
(hopefully
no
the
over-
> Yes.
the
the
step
On
for
> A unit step of 6.
> -- regards,
> Tracy Allen
> mailto:tracy@e...
for 30ms and off for 5ms, repeating, or faster. SO, I think I measure
the on or off pulses, or some collection of on and off pulses, and
calculate an rpm from that. I'm not sure what you mean when you
say "between each pulse"? The signal is plus 12 volts for a few ms
and 0 volts for a few milliseconds, over and over. Am I missing your
point?
--- In basicstamps@y..., tony.wells@a... wrote:
> Hi ,
each pulse?
divide by 100
> counter.
and you
> Regards,
> Tony
> From: "tomatlarge" <tomatlarge@y...>
> To: <basicstamps@y...>
wire
lead to
Today, I
between
resistor.
ground)
follower
(hopefully
no
the
over-
I am
to
the
the
> > Thanks again.
about
> > resistor.
the
the
> > tach
the
black
> > tapped
> > when
> > think
> > > 100k
volts.
2+3.
1
resistance
> > of
> > take
> > > a few. Pretty high.
> > 100kohms
> > > as follows:
> > > Vss---/\/\
> > > 100kohm
before,
> > 9.9
there
> > is
than
1/2
added
the
give
> > you
> > > -- regards,
> > > Tracy Allen
> > > mailto:tracy@e...
> > basicstamps-unsubscribe@y...
Subject and
I may have missed some earlier postings, and I am a bit sleepy today (5
day-old baby). So if I'm just talking rubbish or repeating other posts then
just ignore me ;-)
This is a long posting......
What I'm trying to say is that for a given engine speed, the pulses are
occuring at a rate which is related to the engine speed - which you know
already. Using your example, you get an ON for 30ms then an OFF for 5 ms at
say 1000 rpm. If the speed is 2000 rpm then the pulses occur as an ON at
15ms and OFF for 5ms.
If this is the case, what you *can* do, is to cycle the CPU (eg count up
some variable) during the ON period and count the CPU cycles when the pin is
ON, and stop when the pin is OFF.
The CPU cycles, or count variable value then has a relationship to the
rpm.
Now the Basic stamp is slower than Mr. Tortoise in Tortoiseville. It is
entirely likely that it won't be able to cycle a counter many times at 30ms
or less, so the accuracy will be poo. The classic way of solving this is to
put the On/Off pulses into a divider chain - say a divide by 100.
This has three effects. Firstly it makes the on-off ratio of the pulses
50:50 - which can be quite handy when counting numbers. Secondly, and more
importantly, the pulses are now streeeeeeched out, and the slow CPU can
increment a counter more times during the ON period.
The third effect is extremely interesting. Because it will take 100 on/offs
as input before you get an output, and because the on/offs are never going
to be the same value (as the engine revs are never constant) then the
divider chain will sort of average up the values. This will produce a sort
of hysteresis effect, similar to a real needle on a analogue tacho.
Now, once you have installed the divide by 100 counter and identified the
count values for given rpms, you can then work out the relationship between
counts and RPM. You might have to fiddle with a timing constant when
counting to make the values neat.
Once the counting routine is ok, all you have to do is (say) once a second
run the counting routine - make the routine wait until a new pulse comes in,
then do your counting.
I hope all this makes sense.....
Toyn Wells
Sent: Sunday, December 30, 2001 11:12 PM
> I'm not sure I follow this suggestion. The pulse is, for example, on
> point?
> > Hi ,
> each pulse?
> divide by 100
> > counter.
> and you
> > Regards,
> > Tony
> wire
> lead to
> Today, I
> between
> resistor.
> ground)
> follower
> (hopefully
> no
> the
> over-
> I am
> to
> the
> the
> > > Thanks again.
> about
> > > resistor.
> the
> the
> > > tach
> the
> black
> > > tapped
> > > when
> > > think
> > > > 100k
> volts.
> 2+3.
> 1
> resistance
> > > of
> > > take
> > > > a few. Pretty high.
> > > 100kohms
> > > > as follows:
> > > > Vss---/\/\
> > > > 100kohm
> before,
> > > 9.9
> there
> > > is
> than
> 1/2
> added
> the
> give
> > > you
> > > > -- regards,
> > > > Tracy Allen
> > > > mailto:tracy@e...
> Subject and
with a 5 day old baby. I assumed that the pulsin command was the most
accurate way of timing a pulse in the 30ms range, so it did not occur
to me to bypass that command in favor of manual counting. Stretching
the pulse is an appealing idea. I started toying with a flip flop
circuit yesterday, but managed to fry the only chip I had for that. I
do like the idea of taking many pulses at a time, to smooth out the
reading, but do worry about using too much cpu time. The overall plan
is to build a data logger for my car (DME controlled Porsche), so I
would not want to hamper the sampling rate just to calculate rpms.
Right now, I want to get a BS2 tach working in the car (have LCD
panel for read-out) so I know there are no issues with the sampling.
But, once I put the rest of the pieces in place, I may just have the
data logger capture the raw data (pulse time--raw or stretched), and
let a PC do the calculations after the fact at the time the results
are displayed. I'm still working on getting reliable data using 2
pulsin commands, but if that proves too unstable, I may very well
think along the lines you are suggesting.
Thanks!
--- In basicstamps@y..., <tony.wells@a...> wrote:
> Hi Tom,
today (5
posts then
> just ignore me ;-)
are
know
5 ms at
ON at
count up
the pin is
the
> rpm.
It is
at 30ms
this is to
pulses
and more
can
on/offs
never going
the
a sort
identified the
between
second
comes in,
> Regards,
> Toyn Wells
on
measure
ms
your
> > point?
> > > Hi ,
> > each pulse?
> > divide by 100
> > > counter.
simpler,
> > and you
> > > Regards,
> > > Tony
a
> > wire
Using a
> > lead to
> > Today, I
> > between
> > resistor.
> > ground)
> > follower
the
> > (hopefully
virtually
> > no
divider on
> > the
not
> > over-
ok?
> > I am
stumped on
get
calculations
> > to
up in
> > the
by
> > the
it
tomorrow.
> > > > Thanks again.
was
> > about
> > > > resistor.
signal, so
> > the
reference,
> > the
> > > > tach
from
> > the
another
> > black
just
> > > > tapped
lower
> > > > when
resistance. I
> > > > think
> > > > > 100k
volt
> > volts.
box
> > 2+3.
0.1/100000 =~
> > 1
> > resistance
> > > > of
give or
> > > > take
> > > > > a few. Pretty high.
> > > > 100kohms
> > > > > as follows:
> > > > > Vss---/\/\
> > > > > 100kohm
voltage
> > before,
> > > > 9.9
> > there
> > > > is
less
> > than
drops to
> > 1/2
> > added
to
> > the
> > give
> > > > you
> > > > > -- regards,
> > > > > Tracy Allen
> > > > > mailto:tracy@e...
> > Subject and
Subject and
resistors (both in the voltage divider and on the signal from the
black box), and added a cap across the BS2 input as Tracy suggested,
and the tach now reads extremely stable and accurate on my LCD. The
timing problem I mentioned earlier was a software glitch (forgot to
add the negative pulse.) Many thanks for all the help. Next up:
injector pulse timing, and a host of switch and voltage-based
sensors. Then I'll need to tackle writing data to BS2 memory for
later PC processing. [noparse]:)[/noparse]
> Ah, I see what you are saying. Very clear. Thanks. Not bad for a
guy
most
occur
Stretching
I
plan
sampling.
the
and
> Thanks!
> > Hi Tom,
> today (5
> posts then
> > just ignore me ;-)
pulses
> are
you
> know
for
> 5 ms at
an
> ON at
> count up
> the pin is
to
> the
> > rpm.
> It is
times
> at 30ms
> this is to
> pulses
> and more
CPU
> can
100
> on/offs
> never going
> the
produce
> a sort
tacho.
> identified the
relationship
> between
when
a
> second
pulse
> comes in,
> > Regards,
> > Toyn Wells
example,
> on
> measure
and
few
> ms
> your
> > > point?
> > > > Hi ,
between
> > > each pulse?
> > > divide by 100
> > > > counter.
> simpler,
> > > and you
> > > > Regards,
> > > > Tony
connected
> a
> > > wire
> Using a
black
> > > lead to
> > > Today, I
> > > between
the
> > > resistor.
to
> > > ground)
> > > follower
100k
of
> the
> > > (hopefully
> virtually
> > > no
> divider on
> > > the
would
> not
> > > over-
> ok?
> > > I am
> stumped on
> get
> calculations
> > > to
> up in
> > > the
30000
> by
> > > the
do
> it
> tomorrow.
> > > > > Thanks again.
> was
> > > about
the
> > > > > resistor.
> signal, so
> > > the
> reference,
> > > the
> > > > > tach
goes
> from
> > > the
> another
> > > black
> just
> > > > > tapped
was .1vdc
> lower
> > > > > when
> resistance. I
> > > > > think
> > > > > > 100k
0.1
> volt
9.9
> > > volts.
> box
> > > 2+3.
> 0.1/100000 =~
> > > 1
> > > resistance
> > > > > of
input
> give or
> > > > > take
> > > > > > a few. Pretty high.
the
> > > > > 100kohms
> > > > > > as follows:
> > > > > > Vss---/\/\
> > > > > > 100kohm
> voltage
> > > before,
> > > > > 9.9
If
> > > there
> > > > > is
> less
> > > than
> drops to
> > > 1/2
the
> > > added
box"
> to
> > > the
test
> > > give
> > > > > you
> > > > > > -- regards,
> > > > > > Tracy Allen
> > > > > > mailto:tracy@e...
the
> > > Subject and
> Subject and
Hi again Tom,
There should be a good bypass capacitor between pins 4 and 8 of the
LM358. Be sure all the grounds are well connected.
> Second,
How much slightly?
>As I
The LM358 is a relatively slow op-amp, when used in this way as a
comparator. Since this is a simple digital switch, a small signal
mosfet would be simpler and faster to translate the levels:
BS2 pin
o----/\/\----+5
0- ||-; 5k
+12--/\/\--||-o- Vss
1k VN10
Another option is the CD4050 hex cmos buffer. It can easily
translate high speed signals from 12 volts down to 5 volts.
-- regards,
Tracy Allen
mailto:tracy@e...
Thanks again for all your help. I may indeed try the other circuits
you suggest below, but in the meantime, I was able to make things
work very well. The timing issue was my own fault (silly me, forgot
to add the neg pulse). And the capacitors seemed to fix the other
problems. It is amazing to me how much can be done with the Stamp and
the help of this list, with virtually no electronics training. I'm
working on the other input channels now, and should have a
functioning data logger shortly (with a little signal conditioning
tossed in for drivability)! --Tom
> Hi again Tom,
> > Second,
to
> How much slightly?
> >As I
BS2 pin
o----/\/\----+5
> 0- ||-; 5k
> 1k VN10
> -- regards,
> Tracy Allen
> mailto:tracy@e...
After reviewing all of the responces of this thread I believe you would be
very interested in Al Williams Pak VII. I have only reviewed these devices
but I believe they are exactly what you need. It is a co-processor that can
monitior the length of 8 diffeent pulses, HI/LO/ ,DURATION ,TOTALS,ETC. The
stamp can then retrieve this info as neede with a serin command, useing very
little of the stamps processing resources.
Shannon
--- In basicstamps@y..., moretraction@a... wrote:
> Tom,
would be
devices
that can
useing very
> Shannon
>Sounds interesting. Do you have a link?
> http://www.al-williams.com/awce/pak7.htm
PAKs, use SHIFTIN/SHIFTOUT for communications. People often ask why the
PAKs don't use SERIN/SEROUT (the PAK-V and VI do because they have
different requirements). One of the benefits of a PAK is that it allows
a level of multitasking. If they used SERIN, the Stamp (and other non
interrupt processors) would have to listen for incoming data. With the
Shift scheme, you can issue a command, go do something, and then read
the results later. You can read the result at your own speed, stop in
the middle and result later, etc. You can't do that with SERIN.
The PAK-V only accepts input, so SEROUT is fine. The PAK-VI's whole
point is to convert PS/2 to RS232, so again, SERIN/SEROUT works there
too. Otherwise, all the PAKs use the same protocol.
You can find the manual and example code on our site.
Al Williams
AWC
* 8 channels of PWM
http://www.al-williams.com/awce/pak5.htm
> From: moretraction@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=iA5rf9Yi9Yum4khoxEUhd_jI7aCDKgvxL0-5_WB0zVcJZZSvdYdkuqx0RHkzQbNqYbu5Ri-SzPcqRw]moretraction@a...[/url
> Sent: Monday, December 31, 2001 11:10 PM
> Subject: Re: [noparse][[/noparse]basicstamps] Re: Pulse Conditioning for BS2
> Tom,
> you would be
> these devices
> ,TOTALS,ETC. The
> Shannon
