Infra-Red Temperature sensors
I am developing race car telemetry systems, and am being pestered
by a potential customer to give him the facility to monitor tyre
temperatures whilst his race cars are on the circuit.
We would like to monitor all 4 tyres, and the inner, middle and outer edges
of each tyre.
Infra red sensors I presume are my only viable non-contacting option, but
here in the UK the cheapest
I can get them is about ?150 each - or ?70 if I dismantle some cheap
handheld temp guns!
Anyone know of a source of good quality sensors at a much lower cost than
this?
?840 for the sensors (I'll need 12) makes it a non-starter.
Also, are they fairly straightforward to read from - eg variable duty cycle
pulses or something?
Thanks for any help
Les Otter
of each tyre.
handheld temp guns!
this?
Thanks for any help
Les Otter
> From: Chris Loiacono [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Uh-XeTOxUiREhvUTjpMcr6beUPhQoh1VvsOjvGp4PEmJ7Wg4eXORRLkUbMD5gntC0wx-ZFw6Y2Y]chris@m...[/url
> Sent: Wednesday, December 26, 2001 10:22 PM
> To: 'basicstamps@yahoogroups.com'
> Subject: RE: [noparse][[/noparse]basicstamps] Infra-Red Temperature sensors
> Les:
> Try www.exergen.com for Frank Pompei's patented PIR sensors,
> dubbed IR/TC's.
> The lowest cost version runs about $90USD per. This is a
> fairly common application for them, and it is listed in the
> application section of their catalog. You can tell your
> client that this is commonly done, and that this is what it
> costs. I have tried many different sensors, including some of
> my own design, and have found nothing that works as reliably.
> I have used hundreds if not thousands of IR/TC's with very
> few hitches over the years. Their design consists of a heap
> of thermopiles on a non-conductive substrate enclosed in a
> shielding gas with simple optics. There are no emmissivity
> compensations to make and they output as any thermocouple
> would. They are basically plug-N-play devices.
> If you find a cheaper sensing method, please share with us!!!
> Chris
> > From: Les Otter [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=zqVXQe1G6IP5XUYhBf1xDQLk93pWbTFeJSJgKHd6wUnC-CNXH321s4ohg4X7N-fbf8UGgSUMEJci3CGNI9jLupxn2no]lesotter@s...[/url
> > Sent: Wednesday, December 26, 2001 2:27 PM
> > To: basicstamps@yahoogroups.com
> > Subject: [noparse][[/noparse]basicstamps] Infra-Red Temperature sensors
> > and outer edges
> > of each tyre.
> > option, but
> > handheld temp guns!
> > lower cost than
> > this?
> > variable duty cycle
> > Thanks for any help
> > Les Otter
> > To UNSUBSCRIBE, just send mail to:
> > basicstamps-unsubscribe@yahoogroups.com
> > from the same email address that you subscribed. Text in the
> > Subject and Body of the message will be ignored.
> > Your use of Yahoo! Groups is subject to
> > http://docs.yahoo.com/info/terms/
