Newbie BS2 user w/ Newbie Question
I just hooked up my BS2 for the first time, and tested it by
connecting this simple circuit (the cimplest one I could find) from
the manual:
+5v
LED
220 Ohm Res.
I/O Pin 0
The circuit works, and I am really excited about getting into
STAMPs. What I don't get is, why is the 220 Ohm resistor there? I
also connected the circuit without it, and it still works just as
well. The voltage across the LED w/o the resistor is 5v, and with it
is 3.7v. Is the sole purpose of the resistor to lower the voltage a
little, dimming the LED a little? Or does it serve some other
purpose?
Thanks in advance. Any info on good online resources would be
appreciated.
the manual:
+5v
LED
220 Ohm Res.
I/O Pin 0
purpose?
appreciated.
http://www.al-williams.com/wd5gnr/stampfaq.htm#s2.4
http://www.al-williams.com/wd5gnr/basiccir.htm
Al Williams
AWC
* NEW KIT: Need a 5V Power Supply?
http://www.al-williams.com/awce/ps1.htm
> From: apecitydotcom [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=PMWsAotT7aXbEsyM-Ji_wtduWgPHglcgB59buUlYxd21CoBg4y4u7if4OSKp_HdPhsPKvTBitFD65Ve8aQ]fines@m...[/url
> Sent: Monday, December 24, 2001 10:06 AM
> Subject: [noparse][[/noparse]basicstamps] Newbie BS2 user w/ Newbie Question
> the manual:
> +5v
LED
220 Ohm Res.
I/O Pin 0
> purpose?
> appreciated.
> from the same email address that you subscribed. Text in the
protects the LED and the Stamp. As you get more involved in electronics,
you'll learn to calculate proper resistor values for your unique circuits.
LEDs have a specified forward voltage that is usually in the range of 1.2 to
1.7 volts. The resistor, if you will, soaks up the rest (since the circuit
voltage is 5 volts). Lets say, for example that your LED had a forward
voltage of 1.4 volts (very typical). That would leave 3.6 volts across the
resistor. Using Ohm's Law, we can determine that the current flow through
the circuit is about 16 milliamps.
Since you can't light too many LEDs at 16 mA, you might consider changing
your resistor value to 470 ohms or 1 kOhm. That will let the Stamp light
more at the same time.
You might consider Scott Edwards' book "Programming And Customizing The BASIC
Stamp Microcontroller." It will help you get started in Stamps and give you
some fundamentals in electronics as well.
-- Jon Williams
-- Parallax
In a message dated 12/24/01 10:06:32 AM Central Standard Time,
fines@m... writes:
> the manual:
> +5v
LED
220 Ohm Res.
I/O Pin 0
> purpose?
Typically LED's require 1.7 to 2.1 volts to operate and any higher voltage
will cause it to burn out. It sounds like you lucked out not smoking the LED
or Stamp. In the future I would follow the directions so won't damage
anything.
As far as the resistor value, knowing how much power the LED consumes and
what voltage it requires, along with a simple formula allows you to
determine what resistor to use.
> the manual:
> +5v
LED
220 Ohm Res.
I/O Pin 0
> purpose?
resistor you exceed the power dissipation of the LED.
Sent: Monday, December 24, 2001 8:05 AM
> the manual:
> +5v
LED
220 Ohm Res.
I/O Pin 0
> purpose?
> appreciated.
(you can pump amps thru the LED for short perios of time) but what is
more important the current out of the stamp, you could fried it.
--- In basicstamps@y..., "Stephen H Chapman" <chapman@t...> wrote:
> The 220 ohm resistor is to limit the current thru the LED. Without
this
> From: "apecitydotcom" <fines@m...>
> To: <basicstamps@y...>
from
> > the manual:
> > +5v
LED
220 Ohm Res.
I/O Pin 0
I
with it
voltage a
> > purpose?
> > appreciated.
> > basicstamps-unsubscribe@y...
Subject and
flow in all other branches.
Sent: Monday, December 24, 2001 12:44 PM
Subject: [noparse][[/noparse]basicstamps] Re: Newbie BS2 user w/ Newbie Question
> The 220 ohms resistor is to limit not only the current thru the LED
> this
> from
> > > the manual:
> > > +5v
LED
220 Ohm Res.
I/O Pin 0
> I
> with it
> voltage a
> > > purpose?
> > > appreciated.
> Subject and
My point is that the LED can take amps, the stamp does not.
> In a series ckt the current in any one branch is the same amount of
current
> From: "acatano2002" <acatano2002@y...>
LED
what is
Without
> > this
> > from
> > > > the manual:
> > > > +5v
LED
220 Ohm Res.
I/O Pin 0
there?
> > I
just as
> > with it
> > voltage a
> > > > purpose?
> > > > appreciated.
> > Subject and
Subject and
