bs2p auxiliary pins
There is no way (at this point) to determine the current state of IOTERM.
Checking it would probably require as much code as just setting it to what
you want. Of course, you can keep your own bit-sized variable for use of
IOTERM and just check that. If you have to cross program slots, you can use
GET to push your IOTERM variable into the SPRAM.
When you switch program slots, MAINIO is active.
-- Jon Williams
In a message dated 12/23/01 10:12:34 AM Central Standard Time,
peterverkaik@b... writes:
> Hi,
> I've got two questions regarding the BS2p auxiliary pins.
> (I do not have a 2p yet, but am already writing code for it)
> Q1.
> Is there a way to retrieve the current IOTERM setting?
> (like the STORE value and active program slot) or do I need to track this
> myself?
> Q2.
> When I run another program, is the current IOTERM setting retained,
> or is it reset to MAINIO or AUXIO?
-- Jon Williams
> Hi,
> Q1.
> myself?
> Q2.
I've got two questions regarding the bs2p auxiliary pins.
Q1.
myself?
Q2.
Regards peter
