Earl''s LCD''s....
If anyone is interested, I had recently acquired from EBAY a bunch of LCDs
of a unknown type. reference a auction under way now
http://cgi.ebay.com/aw-cgi/eBayISAPI.dll?ViewItem&item=1680086874
Although the items were unused and new, there was a very large percentage of
them that had defective spots or splotches that detract from their use from
something other than testing, or experimentation purposes. The defects don't
affect their operation, but it does affect the readability of the digits,
depending on the defects. I do not know if other boxes have these defects or
not.
Anyway they are basically a two digit, with two decimal points, and seven
segments each.
They are a relatively slow LCD in that it takes a bit for the matrix to go
transparent after excitation. They are also very low voltage low power
units, less than a volt seems to activate a segment quite well.
The pinouts is straightforward, pin one is VSS, pin 2 is the first decimal
point, pins 3,4,5 make up the lower half of the first segment, pin 6 is the
next decimal point, 7,8,9 the next lower half of the second digit,
10,11,12,13 the top half of the second digit and 14,15,16,17 the top half of
the first digit. Pin 18 is not used.
regards,
Earl
From: Timothy Medema [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=KWNvcM-pXt-WjssMnaP4gVKHcYz8x-er10QD71AZ--MbMlYQCDRuIlV019A78EjElSo-eVWNpcU3egRfTA]timm@c...[/url
Sent: Thursday, December 13, 2001 11:58 AM
Subject: Re: [noparse][[/noparse]basicstamps] Earl's LCD's....
Thanks for the information Tracy,
Thanks also for your ongoing support of all of us on this
list. You give so very much of your time and knowledge resources - it's
much appreciated. Where do you come up with the time to provide all of
this help? I seem to just keep up with the volume of list e-mail much less
the time for the depth of contribution that you provide on a regular basis!
Tim Medema
At 09:16 AM 12/13/2001 -0800, you wrote:
> >Thanks Earl,
> >I've tried many search engines using various combinations of the Part
> >Number: I 3984-4211-222-01 as shown on the LCD box label on the eBay item
> >page, but to no avail. No pin-out or driver information yet. Do know who
> >the manufacturer of the LCD is? That would help greatly. Do any portions
> >of the part number look familiar to any of you professionals on the list?
> >Tim
> >Timothy Medema
> >CrystaLite, Inc.
> >3307 Cedar St. (425) 745-6000 800-666-6065
> >Everett, WA 98201 Fax: (425) 257-0232
> >www.crystaliteinc.com
> ><mailto:timm@c...>timm@c...
>Hi Tim,
> My guess is that the part was produced on a custom contract, and
>the part number is for internal tracking. The fact that there were
>182 in the lot, as stamped on an overseas shipping container suggests
>that it was a prototype that didn't work out. They didn't even hold
>back one of them from your purchase. Maybe the project it was to be
>a part of was scuttled. These small LCD panels are almost always
>custom, and there is very little standard or "off-the-shelf"
>available.
>Where does that leave you? Does the chip have anything that looks
>like an ASIC, a blob of epoxy on the bottom or any chips? It doesn't
>look like it from the photo. If not, that may be better. It is a
>raw screen. If it is a raw screen you can start by applying an AC
>voltage to one pair of pins at a time, and see if any segments (or
>icons!) light up. (say, 5 volts square wave from a stamp at about
>1khz, through a 0.001uf capacitor).
>Good luck! It is a "black box" problem!
> -- regards,
> Tracy Allen
> electronically monitored ecosystems
> mailto:tracy@e...
> http://www.emesystems.com
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
not.
segments each.
regards,
Earl
Tim Medema
> >Thanks Earl,
> >Tim
> >Timothy Medema
> >CrystaLite, Inc.
>Hi Tim,
>available.
> -- regards,
> Tracy Allen
> mailto:tracy@e...
