A - D with PCF8591
We recently purchased a couple of the BS2p24 Demo Boards. We also
purchased the BS2p Plus Pack application kit.
One of my current major interests is for A - D conversion. I am
trying to develop an application to control 24 antenna rotators. 12
for azimuth, 12 for elevation (they're for satellite use).
The control box will allow me to interface to it with simple dry
contact closures to energize the rotator. The position outputs a 0 -
5 VDC signal. I wanted to use the PCF 8591 for this.
Two of us wired up the application in the Plus Pack (individual
efforts). Neither of us got it to work as described. I always have
an indication of 2.5 volts coming in, no matter where the actual
input is set to.
I haven't broken out the meter yet to start tracing through but
thought perhaps I'd ask if I missed something. I searched through
the archives but found nothing.
Has someone else tried this application? I'll start over from
scratch again today...just trying to figure out if I'm all messed up
(surely wouldn't be the first time!)
Thanks!
Tim
input is set to.
Thanks!
Tim
tim@t... writes:
> input is set to.
You've got a loose connection somewhere. I know this because I saw the same
thing when I was developing the "Plus Pack" code. I promise -- that code
does work when all the connections are secure.
-- Jon Williams
-- Parallax
between the A/D, the Stamp, and the control box. If your ground is
"floating" that could cause the problem.
Just to take the opportunity, I hope all on the Stamp list have a nice
holiday season -- whatever holiday you are celebrating.
Al Williams
AWC
* NEW KIT: Need a 5V Supply?
http://www.al-williams.com/awce/ps1.htm
> From: jonwms@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=rTtPZ0nQZOlqNBa3MchPpmOmSyr9bRrj550BXCWXmCO2uPm3SpUzBCvxjMsrfUgDlfOTbg]jonwms@a...[/url
> Sent: Sunday, December 23, 2001 8:14 AM
> Subject: Re: [noparse][[/noparse]basicstamps] A - D with PCF8591
> In a message dated 12/23/01 7:32:10 AM Central Standard Time,
> tim@t... writes:
> outputs a 0 -
> always have
> > input is set to.
> messed up
> I saw the same
> -- that code
> -- Jon Williams
> -- Parallax
> from the same email address that you subscribed. Text in the
