low level serial - addendum
Forgot to mention, the incoming signal swings from -250mv to +250mv relative
to ground.
I am in need of a device for converting low level serial to ttl levels.
The incoming serial data is only a few hundred milivolts p-p squarewave.
Does anyone know of a chip designed for this purpose, or am I going to have
to resort to using a comparator?
I figure a 139, 239, 2901, or 3302 would handle the temp extremes this app
calls for (339's tend to malfunction below 32'f, 0'c)
to ground.
volts unless you provide a positive offset voltage so the input
signal never goes below zero.
--- In basicstamps@y..., "FalconWireless Tech Support - KF4HAZ"
relative
> to ground.
levels.
squarewave.
to have
this app
>to ground.
2 NPN transistors, 2 resistors.
1st NPN: Emitter grounded, Base & collector tied together and to the Base
of the 2nd NPN and a 10K pullup resistor. Input signal goes to the Emitter
of the 2nd transistor. Collector of the 2nd transistor is output to stamp:
should also use a 10K pullup resistor.
Make sure that you place the transistors close together or even touching:
they require thermal coupling to reduce the effects of temperature changes.
This should work over the industrial temperature range: -40C to +70C.
dwayne
Dwayne Reid <dwayner@p...>
Trinity Electronics Systems Ltd Edmonton, AB, CANADA
(780) 489-3199 voice (780) 487-6397 fax
Celebrating 17 years of Engineering Innovation (1984 - 2001)
Do NOT send unsolicited commercial email to this email address.
This message neither grants consent to receive unsolicited
commercial email nor is intended to solicit commercial email.
