Temp chip
Ricky-
Can't speak from experience on this one, but the way I read the
datasheet it looks like this lets you "assign" an address to slaves
via jumpers, hook them all up to the same master, then select one of
up to eight via the control byte.
Steve
On 20 Dec 01 at 16:34, Ricky Konvicka wrote:
> Has anyone used a DS1621 temp sensor from Dallas Semi? If so on the
> chip there are 3 address input pins, what are these for?
> Ricky Konvicka
> Electronic Engineer
> BioTech International Inc.
> www.biotechintl.com
> [noparse][[/noparse]Non-text portions of this message have been removed]
> from the same email address that you subscribed. Text in the
Steve
> Ricky Konvicka
> Electronic Engineer
> www.biotechintl.com
Ricky Konvicka
Electronic Engineer
www.biotechintl.com
You can use up to 8 DS1621 on the same bus. Then you need to assign each
chip a different address (3 bits -> 8 combinations).
Phil.
Sent: Thursday, December 20, 2001 11:43 AM
Subject: Re: [noparse][[/noparse]basicstamps] Temp chip
> Ricky-
> Regards,
> Steve
> > Ricky Konvicka
> > Electronic Engineer
> > www.biotechintl.com
NEED to be tied low or high depending on what control code you use. I kept
getting 255 for a reading and I tied them all low and it works perfect now.
Sent: Friday, December 21, 2001 12:18 AM
> Hi Ricky,
> Regards,
> Phil.
> From: "S Parkis" <parkiss@e...>
> > Ricky-
> > Regards,
> > Steve
> > > Ricky Konvicka
> > > Electronic Engineer
> > > www.biotechintl.com
and
