Dallas DS2404 EconoRam Time Chip
Jason-
IMHO, the '2404 is a reasonable choice with the BS2p. It provides
you a lot of capability for only one pin. If you can fit your data
storage requirements into its 512 bytes of nonvolatile ram it makes
a lot of sense. It's not the most convenient clock to use, but it
does the job and offers some nifty features.
One possible way to save space would be to store only the time
interval since the previous sample versus the complete time stamp
for each sample. You pick whether to use the 1/256 second units or
the more significant register values depending on your resolution
requirements. If you store 12 bits of ADC data and 12 bits of time
interval data for each sample, that gives you ~170 samples.
Here are some working DS2404 routines that may save you some
aspirin and hair-pulling.
Steve
'{$STAMP BS2p}
' DS2404 4 KBit RAM + Time Chip
' - for simplicity, SKIP ROM used throughout
' Universal 1-Wire ROM commands (see Dallas Semiconductor documentation)
READ_ROM CON $33
SKIP_ROM CON $CC
MATCH_ROM CON $55
SEARCH_ROM CON $F0
SEARCH_FUNC CON $EC
' I/O pin constants
BUS CON 15 ' 1-Wire bus pin
' OWIN, OWOUT constants
RESET_NONE CON 0
RESET_PRE CON 1
RESET_POST CON 2
RESET_BOTH CON 3
' conventional variables
memory_address VAR WORD
CRC8 VAR BYTE
in_byte VAR BYTE(10)
i VAR BYTE
j VAR BYTE
this VAR BYTE
' read ROM-based identifier...this will work with any 1-Wire device...
' also serves as means to determine identifier if unknown...must be
' only device on the bus or READ ROM will not work right...
' 1-Wire transactions summary:
' ---> [noparse][[/noparse]reset]
' ---> READ ROM
' <--- 8 Serial # identifier bytes
OWOUT BUS,RESET_PRE,[noparse][[/noparse]READ_ROM] ' send READ ROM
OWIN BUS,RESET_NONE,[noparse][[/noparse]STR in_byte\8] ' read 8-byte serial identifier
DEBUG CR,"Serial # "
FOR i = 7 TO 0 ' display identifier high order
DEBUG HEX2 in_byte(i) ' byte first
NEXT
FOR i = 0 TO 7 ' compare xmit'ed with calc CRC
this = in_byte(i): GOSUB addToCRC8
NEXT
IF crc8 > 0 THEN badCRC
DEBUG CR,"CRC for serial # valid"
' turn oscillator on by writing $10 to the control register at $0201...
' ---> SKIP ROM
' ---> WRITE SCRATCHPAD command
' ---> 2-byte starting address
' ---> 1 data byte = $10
' ---> SKIP ROM
' ---> READ SCRATCHPAD command
' <--- 2-byte address
' <--- ending offset/status
' ---> SKIP ROM
' ---> COPY SCRATCHPAD command
' ---> ending offset/status
memory_address = $0201
OWOUT
BUS,RESET_PRE,[noparse][[/noparse]SKIP_ROM,$0F,memory_address.LOWBYTE,memory_address.HIGHBYTE,$10]
OWOUT BUS,RESET_PRE,[noparse][[/noparse]SKIP_ROM,$AA]
OWIN BUS,RESET_NONE,[noparse][[/noparse]STR in_byte\3]
DEBUG CR,"DS2404 E/S register: ",HEX2 in_byte(2)
OWOUT BUS,RESET_PRE,[noparse][[/noparse]SKIP_ROM,$55,in_byte,in_byte(1),in_byte(2)]
' read control register at $0201 to confirm realtime counter set to
' increment...
' ---> SKIP ROM
' ---> READ MEMORY command
' <--- 1 data byte
OWOUT
BUS,RESET_PRE,[noparse][[/noparse]SKIP_ROM,$F0,memory_address.LOWBYTE,memory_address.HIGHBYTE]
OWIN BUS,RESET_NONE,[noparse][[/noparse]in_byte]
DEBUG CR,CR,"DS2404 Control register: ",HEX2 in_byte
' disable interrupts by clearing int enable bits in status register
' at $0201...
' ---> SKIP ROM
' ---> 1 data byte = $38
' ---> SKIP ROM
' ---> SKIP ROM
memory_address = $0200
OWOUT
BUS,RESET_PRE,[noparse][[/noparse]SKIP_ROM,$0F,memory_address.LOWBYTE,memory_address.HIGHBYTE,$38]
' read status register at $0200 to confirm interrupts disabled...
' ---> SKIP ROM
' <--- 1 data byte
OWOUT
DEBUG CR,CR,"DS2404 Status register: ",HEX2 in_byte
' set alarm for 15 seconds from now by reading current realtime counter,
' setting this value + 15 seconds as alarm value...
' ---> SKIP ROM
' ---> 2-byte starting address (real time counter registers)
' <--- 4 data bytes
' ---> SKIP ROM
' ---> 4 data bytes (real time counter alarm registers)
' ---> SKIP ROM
' ---> SKIP ROM
memory_address = $0202 ' realtime counter register group
OWOUT
OWIN BUS,RESET_NONE,[noparse][[/noparse]STR in_byte\5]
in_byte(1) = in_byte(1) + 15 ' add 15 seconds
memory_address = $0210 ' realtime counter alarm register group
OWOUT
BUS,RESET_PRE,[noparse][[/noparse]SKIP_ROM,$0F,memory_address.LOWBYTE,memory_address.HIGHBYTE,STR
in_byte\5]
' read status register at $0200 looking for realtime counter alarm
' condition...
' ---> SKIP ROM
' <--- 1 data byte
readStatus:
PAUSE 2000
OWOUT
IF in_byte & $01 = 0 THEN readStatus
x:
' fill all 512 bytes of general purpose memory with stuff...
' 1-Wire transactions summary (x's 16):
' ---> SKIP ROM
' ---> 32 data bytes
' ---> SKIP ROM
' ---> SKIP ROM
memory_address = $0000
FOR i = 0 TO 15
OWOUT
BUS,RESET_PRE,[noparse][[/noparse]SKIP_ROM,$0F,memory_address.LOWBYTE,memory_address.HIGHBYTE]
FOR j = 0 TO 31
OWOUT BUS,RESET_NONE,[noparse][[/noparse]i * j] ' write data to scratchpad
NEXT
OWOUT BUS,RESET_PRE,[noparse][[/noparse]SKIP_ROM,$AA] ' read scratchpad parameters
memory_address = memory_address + 32
NEXT
' read all 512 bytes of general purpose memory
' ---> SKIP ROM
' <--- 32 data bytes
FOR i = 0 TO 15
DEBUG CR,HEX4 memory_address,": "
OWOUT
FOR j = 0 TO 31
DEBUG HEX2 in_byte," "
NEXT
NEXT
DEBUG CR,"Program complete"
STOP
addToCRC8:
FOR j = 1 TO 8
IF this.LOWBIT ^ crc8 & 1 THEN feedBack1_8
feedBack0_8:
crc8 = crc8 >> 1 & ~$80: GOTO nextBit_8
feedBack1_8:
crc8 = crc8 ^ $18 >> 1 | $80
nextBit_8:
this = this >> 1: NEXT: RETURN
badCRC:
DEBUG CR,"CRC mismatch--data invalid"
DEBUG CR,"CRC result: ",HEX2 crc8
STOP
On 18 Dec 01 at 22:55, jbirnsch wrote:
> Hi all,
> I am new to all of this so bear with me. I want to use the time
> function if this IC as well as the Sram to store data that will be
> collected by an ACD(MAX186)...
Steve
'{$STAMP BS2p}
READ_ROM CON $33
SKIP_ROM CON $CC
MATCH_ROM CON $55
SEARCH_ROM CON $F0
SEARCH_FUNC CON $EC
' I/O pin constants
RESET_NONE CON 0
RESET_PRE CON 1
RESET_POST CON 2
RESET_BOTH CON 3
CRC8 VAR BYTE
i VAR BYTE
j VAR BYTE
this VAR BYTE
' ---> READ ROM
NEXT
NEXT
' ---> SKIP ROM
' ---> SKIP ROM
' ---> SKIP ROM
OWOUT
' increment...
' ---> SKIP ROM
' <--- 1 data byte
OWOUT
' at $0201...
' ---> SKIP ROM
' ---> SKIP ROM
' ---> SKIP ROM
OWOUT
' ---> SKIP ROM
' <--- 1 data byte
OWOUT
' ---> SKIP ROM
' <--- 4 data bytes
' ---> SKIP ROM
' ---> SKIP ROM
' ---> SKIP ROM
OWOUT
OWOUT
in_byte\5]
' condition...
' ---> SKIP ROM
' <--- 1 data byte
readStatus:
PAUSE 2000
OWOUT
x:
' ---> SKIP ROM
' ---> SKIP ROM
' ---> SKIP ROM
FOR i = 0 TO 15
OWOUT
FOR j = 0 TO 31
NEXT
NEXT
' ---> SKIP ROM
FOR i = 0 TO 15
OWOUT
FOR j = 0 TO 31
NEXT
NEXT
STOP
addToCRC8:
FOR j = 1 TO 8
feedBack0_8:
feedBack1_8:
nextBit_8:
badCRC:
STOP
> Hi all,
collected by an ACD(MAX186). What I want to do is take the 12 bits
from the ADC store that to an address in sram and then store the 4
byte count of seconds from the Real time clock in the next 2 address
locations as a time stamp from when the data was collected. I need
the time stamp and I need to do this remotely without the PC
connected. Am I going at this the wrong way. Should I use a serial
E^2 with a seperate RTC connected to the BSP40?
Jason
jbirnsch@v... writes:
Personally, I wouldn't go with the DS2404. There are dozens of I2C EEPROMs
and the PCF8538 RTC is a breeze to use (no decoding seconds to determine time
-- you get everything as registers).
There's code on the Parallax web site. GOTO the BS2p "Plus Pack" page:
http://www.parallaxinc.com/html_files/products/BS_Accessories/plus_pack.asp
-- Jon Williams
-- Parallax
