Scratchpad Ram Weirdness
Archiver
I've been having a lot of problems with a scratchpad ram sorting routine with
my BS2p. So, I've made a little test program to read all the ram and I think
something is wrong with my stamp since the problem is repeatable with the
simple program.
The problem is that after I use the "Store" command, the value of ram position
110 turns to 59 and position 111 turns to 0, no matter what value was in there
before. I'm using many program slots and need the scratchpad ram to remain
unchanged between programs. I don't know if my stamp is bad or what, maby
someone on the list could try this little program to see if the problem happens
for them too.
Stewart
'{$STAMP BS2p}
x var byte
Y var byte
for x = 0 to 126 'PUT A VALUE OF 1 INTO ALL WRITEABLE RAM LOCATIONS
put x, 1
next
for x = 0 to 126 'READ AND DEBUG ALL WRITEABLE RAM LOCATIONS
get x, y
debug "Memory Position ", DEC3 X, " = ", DEC Y, CR
next
Store 7 'STORE COMMAND
Debug cr, cr, cr, cr, "Now After Store Command RAM Position 110 is messed.",
CR, CR
get x, y
next
END
Stewart Mayer, stewlist@k... on 12/17/2001
simple program.
for them too.
Stewart
'{$STAMP BS2p}
x var byte
Y var byte
put x, 1
next
get x, y
next
CR, CR
get x, y
next
END
Good (bad) observation! I tested it out, and sure enough, the same
dismaying result as yours. The STORE instruction always effects
locations 110 and 111 as you say. That is true also for STORE 0,
STORE 1 etc.; it always turns those locations to 59 and 0
respectively, no matter what was stored there to begin with.
-- best regards
Tracy Allen
http://www.emesystems.com
mailto:tracy@e...
>simple program.
>ram position
>problem happens
>for them too.
>Thanks,
> Stewart
>'{$STAMP BS2p}
>x var byte
>Y var byte
> put x, 1
>next
> get x, y
>next
>CR, CR
> get x, y
>next
>END
>Could you run the test with a for-next loop of say 121
>and check if the error occurs on the same location
>or location 121-16=105. Just to see if the for-next
>statement may be involved.
>Regards peter
Same result with FOR x=105 to 115
-- Tracy
(ouch!)
Marylou
_______________________________________________________
routine with
and I think
with the
> simple program.
ram position
was in there
remain
what, maby
problem happens
> for them too.
> Thanks,
> Stewart
> '{$STAMP BS2p}
> x var byte
> Y var byte
> put x, 1
> next
> get x, y
> next
messed.",
> CR, CR
> get x, y
> next
> END
least I don't feel so bad for failing to debug my code for over two days,
thinking I had caused the problem!
I get the same results when using any store location too, and it doesn't matter
where the read loop starts or stops. I hope parallax is listening.
Unfortunately, every byte of ram on the chip has been spoken for, but since the
ram is OK for PUTting and GETting without the STORE command, it would be fairly
easy to copy the data in EEPROM temporarily while switching slots, just slower
and more code to take up valuable program space.
Anyway, this is a first for me. Cool [noparse]:)[/noparse]
Stewart
On Tue, 18 Dec 2001 03:04:21 -0800, peter verkaik wrote:
>Hi,
>Well.. congratulations to Stewart, I guess, for discovering this hidden bug.
>Now Parallax has to fix this.
>I advice to mark locations 110 and 111 off limits when using STORE.
>Wonder if there are more statements that generate such an error.
>Regards peter
Oorspronkelijk bericht
>Van: Tracy Allen [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=tiz0Eq00ZZzMMHiyyg764_MiSWeWF1ljhq7xfMnkFMHCDx-cgd5sCragsmC38Sth1-_ypVm9Ai4-CbfH]tracy@e...[/url
>Verzonden: maandag 17 december 2001 17:37
>Aan: basicstamps@yahoogroups.com
>Onderwerp: RE: [noparse][[/noparse]basicstamps] Scratchpad Ram Weirdness
>>Hi,
>>Regards peter
>-- Tracy
>(ouch!)
>basicstamps-unsubscribe@yahoogroups.com
>from the same email address that you subscribed. ·Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
>from the same email address that you subscribed. ·Text in the Subject and Body
of the message will
>be ignored.
Very strange indeed.
I do not own a bs2p so I cannot test it,
but does it occur for all store values or only 7?
Maybe a coincidence but I noticed that location 110 is exactly
16 positions (10H) below 126. If it is a random error how would
the odds be so the location involved would be a power of 2 below
the top position?
Regards peter
Van: Stewart Mayer [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=9pgTqwySAaIp-DaSAD-lBNoGCEG7zMXIjsDCfU6LAc6nD-o-4G9QtaQa7o2YtIME0jHyKUoeZzjk4Wud8S3ojWUbHBA]stewlist@k...[/url
Verzonden: maandag 17 december 2001 16:02
Onderwerp: [noparse][[/noparse]basicstamps] Scratchpad Ram Weirdness
with
think
simple program.
position
there
happens
for them too.
Stewart
'{$STAMP BS2p}
x var byte
Y var byte
put x, 1
next
get x, y
next
CR, CR
get x, y
next
END
Regards peter
Van: Stewart Mayer [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=9QezpHR74PNuELoquf4YENlukY0_20nEadti_zbmpaOzEqMPfiwUdA8aoijUKGEly8UG23B9miVqh8nM6mDA03q8cv_M]stewlist@k...[/url
with
think
simple program.
position
there
happens
for them too.
Stewart
'{$STAMP BS2p}
x var byte
Y var byte
put x, 1
next
get x, y
next
CR, CR
get x, y
next
END
Regards peter
Van: Tracy Allen [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=aI09gopjVCDiJBavhzlOBfiCDUxYaj13maXWGVQGfeIlMFlWNdpNq1Tj5vodda3TiTL4inx9tnGuaQ]tracy@e...[/url
>Hi,
>Regards peter
-- Tracy
(ouch!)
If you have two (temporary) variables ram bytes available
you can just save the two location with get,
do store and then put the values back.
You don't need the eeprom that way.
(to save the values you already need one ram byte
even if you want to store them in eeprom)
regards peter
Van: Stewart Mayer [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=RuVbOdqnC_kAt_rN5EW9xuffrMnNe-sU7hfb74X_tJcsyp21jJllYJWxSoICA2URLkZB_y37mYahSWpIijx17nc]stewlist@k...[/url
Verzonden: maandag 17 december 2001 21:00
Oh no! I was totally hoping it was only my chip that had the problem. But
at least I don't feel so bad for failing to debug my code for over two days,
matter where the read loop starts or stops. I hope parallax is listening.
the ram is OK for PUTting and GETting without the STORE command, it would be
fairly easy to copy the data in EEPROM temporarily while switching slots,
just slower and more code to take up valuable program space.
Stewart
>Hi,
bug.
>Regards peter
>Van: Tracy Allen [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=-KVszyUz9w1g-mQGhBuObHKaPyl6JFAveAeFHdmgyy3a7uOCG84yqlQa6g2arVV9vTivGfHsoXex1D8BqA]tracy@e...[/url
>>Hi,
>>Regards peter
>-- Tracy
>(ouch!)
>be ignored.
stewart
On Tue, 18 Dec 2001 07:01:32 -0800, peter verkaik wrote:
>Hi Stewart,
>regards peter
>Van: Stewart Mayer [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=um9BYXw8wxq_UZ6ogmPqSnltwCY4gfyX6UUIV9DnBCJZm1bRQJprZKdwqrn1XYAGf6O88-Df6zPDijq84Mci2-D0Sj0]stewlist@k...[/url
>Stewart
>>Hi,
>bug.
>>x
>>Regards peter
>>Van: Tracy Allen [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=9T53DwWFDaLJYbGsojajI1IdXL6Dn3zsJaIawAqfEVVUz69JOD0xPY0TOLZtJ0eKBZ-Qp28VGUGT3GxdDA]tracy@e...[/url
>>>Hi,
>>>Regards peter
>>-- Tracy
>>(ouch!)
>>be ignored.
>from the same email address that you subscribed. Text in the Subject and Body
of the message will
>be ignored.
Stewart Mayer, stewlist@k... on 12/18/2001
Do you know if this bug with the BS2p Scratchpad and the STORE
command is resolved? The STORE command was blasting locations 110
and 111. This is from a thread last December.
-- Tracy
>Hi Stewart,
