Interesting problem with programming BS2
Gentlemen,
I have a small problem when I am trying to program a BS2. I have not used
this setup in a while but the last time I used it, things worked properly.
Anyway, I am trying to program a BS2 in a circuit and I have all the same
equipment as last time (about 2 months ago). The cables are the same, etc.
It is the only cable I have to program these chips.
What is happening is when I go to program the chip, it 'shorts' it out for a
short period of time (the meter on the power supply goes to 2.5A) and then
it returns to normal. The chip takes the program and works properly before
and after.
The really interesting thing is that I got a new laptop (Dell) and it
actually has a com port, not strictly USB. When I just hook up the cable to
it, it 'shorts' out the power supply too. I cannot get it to work at all on
the new one. It 'shorts' the chip out whenever you try to program, or even
hook it up.
Does anyone have any ideas? I am stumped and I really wanted to use my new
laptop.
Mark
and after.
hook it up.
laptop.
Mark
used to act nasty with some popular UPS's because it
would look for a mouse on the serial port. Just one
possible clue.
Bob Pence
--- Mark Adams <madams@a...> wrote:
> Gentlemen,
> and after.
> hook it up.
> laptop.
> Thanks,
> Mark
> from the same email address that you subscribed.
> Text in the Subject and Body of the message will be
> ignored.
__________________________________________________
Do You Yahoo!?
Check out Yahoo! Shopping and Yahoo! Auctions for all of
your unique holiday gifts! Buy at http://shopping.yahoo.com
or bid at http://auctions.yahoo.com
From: Pence Bob [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=mZJ2gctDpHiJrGQeF6ADDNEfuJVDVrx5f_dlUOzokYmjGjXvMEuqlg8B_fdJpMefvQj8e_ieBBCAe3N8-7kA5f2c]bobpence_2000@y...[/url
Sent: Monday, December 17, 2001 3:15 PM
Subject: Re: [noparse][[/noparse]basicstamps] Interesting problem with programming BS2
Does your new laptop have Windows XP, 2000, or NT? NT
possible clue.
Bob Pence
> Gentlemen,
> and after.
> hook it up.
> laptop.
> Thanks,
> Mark
> ignored.
Do You Yahoo!?
one will program a chip that is out of the circuit perfectly. The old one
will program the chip in the circuit, but it shorts the source out for the
period of time while it is programming, then works fine after that.
Question: Do the pins of the stamp revert to some default input or output
during programming?
The last observation is the new laptop (win 2000) shorts the souce out
immediately by just hooking up the cable.
I appreciate everyone's help on this one.
Mark
From: Pence Bob [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=7ZiKsE3IdZgLYObM82vl5bvBpJH5TxU4ziyAtFbU_0tkXxk0clhNj2_r7A-ZJcJr0nq_VFtf2r5IJa9mbHV4jJBE]bobpence_2000@y...[/url
possible clue.
Bob Pence
> Gentlemen,
> and after.
> hook it up.
> laptop.
> Thanks,
> Mark
> ignored.
Do You Yahoo!?
>Ok.. update. I have figured it out to differences in the laptops. The new
>during programming?
The pins are cleared and set as follows, upon reset of the Stamp. From page
numbered 47 in Stamp Manual Version 2.0C :
quote
When the BASIC Stamp is powered up, or reset, all memory locations are
cleared to 0, so all pins are inputs (DIRS = %0000000000000000). Also, if
the PBASIC program sets all the I/O pins to outputs (DIRS =
%1111111111111111), then they will initially output low, since the output
latch (OUTS) is cleared to all zeros upon power-up or reset, as well.
end quote
>Mark
>From: Pence Bob [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=qinQFC8d_FkTLQdR_0jtWHS8xEKKDpXeztLETrP_Qgyn05aQvLdOTp6UkDDS3M6sXClc3coQ9_zxWX9jhqzMEIc]bobpence_2000@y...[/url
>possible clue.
>Bob Pence
> > Gentlemen,
> > and after.
> > hook it up.
> > laptop.
> > Thanks,
> > Mark
> > ignored.
>Do You Yahoo!?
Regarding your last observation:
Did you check your boards connector (DB9 socket I presume)
Some times the socket pins get a bit worn out and if there
is a bit too much solder plugging in a cable could lead
to shorting pins to other tracks which could explain the
increase in current. Do check it out and wiggle your cable
and see (on the solder side of the connector) how the connector behaves.
Also check your cable, just to be sure.
Regards peter
Oorspronkelijk bericht
Van: Mark Adams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=VZvvlrEbaksjFwm1G1UwSPSubXw6YK1jVLygGDy0RbMgZ3bf591gqyMTGFKI7jmyEWAo8KBQIrVI]madams@a...[/url
Verzonden: maandag 17 december 2001 14:09
Aan: basicstamps@yahoogroups.com
Onderwerp: RE: [noparse][[/noparse]basicstamps] Interesting problem with programming BS2
during programming?
Mark
From: Pence Bob [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=rMNdgTP1klhRtofS7_uXDktJHCktIdYNNV-o4uuXK1HpjW4j_CFG2kR1aB3GF4_t0zfdxiqTcNjPzOpjmHtF]bobpence_2000@y...[/url
possible clue.
Bob Pence
> Gentlemen,
> and after.
> hook it up.
> laptop.
> Thanks,
> Mark
> ignored.
Do You Yahoo!?
