At 11:42 AM 4/1/02 -0800, you wrote:
> I have a stamp powered device with a clock chip and a few other IC's
> in which I would like to add a battery backup. I am just looking to
> eliminate brown outs and short term power outages, nothing long term. I
> have tried adding a 4700uf cap but it only gives me about 2 seconds worth
> I was looking for about 10 seconds. The voltage is 5 volts. Is my best
> approach a battery and some type of charging circuit? Any
> recommendations on such an approach? Or I guess I could just add more
> capacitance on the 5 volt line.
Just a Thought:
In a data logger project I worked on a few years ago we implemented several
power saving schemes.
One was to run a RTC (Real Time Clock) in trickle charge mode, and then
upon an event request the
RTC was powered up to read the time, and then powered back down. Other
devices on the board
functioned in a similar way such as an I2C EEPROM, only to be powered up
when it was needed.
Since this project used a PIC instead of a Stamp, even the clock speed of
the PIC was altered
through its own software. The Data-logger was only recording two ON-OFF
switches and the duration
each switch remained in a particular position. When there was a change in
switch status open/close,
the PIC would power itself up from 30kHz to 4MHz, power up the RTC; read
the time; power down the
RTC, power up the I2C EEPROM; Write the Time and Switch states; power down
the I2C EEPROM, and
finally power down the PIC from 4MHz back to a resting 30Khz. This way a
single lithium 3V battery
would last for 4 or 5 Months. Without the "Power Saving Features" the 3V
lithium would only last
a few days!
Beau Schwabe Mask Designer IV - ATL
National Semiconductor Enterprise Networking Business Unit
500 Pinnacle Court, Suite 525 Wired Communications Division
Mail Stop GA1 Norcross, GA 30071
I have a stamp powered device with a clock chip and a few other IC's in
which I would like to add a battery backup. I am just looking to eliminate
brown outs and short term power outages, nothing long term. I have tried adding
a 4700uf cap but it only gives me about 2 seconds worth I was looking for about
10 seconds. The voltage is 5 volts. Is my best approach a battery and some
type of charging circuit? Any recommendations on such an approach? Or I guess
I could just add more capacitance on the 5 volt line.
You can get CAPs that store a lot of charge, ( www.maplin.co.uk ) they are good
for BEAM robots too
Ben
Ricky Konvicka <ricky@m...> wrote: I have a stamp powered
device with a clock chip and a few other IC's in which I would like to add a
battery backup. I am just looking to eliminate brown outs and short term power
outages, nothing long term. I have tried adding a 4700uf cap but it only gives
me about 2 seconds worth I was looking for about 10 seconds. The voltage is 5
volts. Is my best approach a battery and some type of charging circuit? Any
To UNSUBSCRIBE, just send mail to: basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and Body of
the message will be ignored.
Thanks Beau. The device I have though, normally runs on 110v ac. I guess
that is my downfall, power consumption was not a concern till now. I need
to run an LCD to so my power requirements are well above 100 ma to keep the
brains alive. There are also 12 volt valves and stepper motors that may be
running. Maybe a UPS is my best bet.
Sent: Monday, April 01, 2002 9:51 AM
Subject: Re: [noparse][[/noparse]basicstamps] Battery Backup
worth
> Just a Thought:
several
> when it was needed.
> the PIC was altered
> the I2C EEPROM, and
> a few days!
I would normally try a 1,2, or 3 Farad Cap myself. They use these as
non-volatile RAM backup sources. But then at your high current needs, it may
not be enough still. A long time ago they used to have analog power supplies
and huge 200k, 300k, 500k+ uF caps were common. I haven't seen any of these
for quite a while now.
Another method is to use a trickle charge on a battery pack of some sort.
Then use a Supervisor (or voltage detector) to detect when the voltage drops
below a certain point, and have a circuit switch power to the battery and
vice-versa.
Goto to www.digikey.com and do a search on "supervisor", then look for a
voltage detector IC that would meet your needs. They have a jillion of them
to choose from. Obviously everyone is doing it.
Another approach is to use a LM339 comparator and setup one input to watch
the voltage for a drop, the output from the comparator can be used to
trigger what needs to be done.
adding a 4700uf cap but it only gives me about 2 seconds worth I was looking
for about 10 seconds. The voltage is 5 volts. Is my best approach a
battery and some type of charging circuit? Any recommendations on such an
approach? Or I guess I could just add more capacitance on the 5 volt line.
Thanks Earl. I'll try and find a bigger cap first. If that doesn't work
then I will probably look at the supervisor IC's.
Sent: Tuesday, April 02, 2002 4:35 AM
Subject: RE: [noparse][[/noparse]basicstamps] Battery Backup
may
supplies
these
drops
> vice-versa.
them
> You can also feed the output from the supervisor IC or LM339 into a I/O
pin
> on the Stamp and have the Stamp turn the battery on or off too. But if
your
> tight on I/O pins having it run independently is probably better. You can
> have the output from the supervisor or LM339 drive a MOSFET (or even a
> simple reed relay if you like) or other transistor to supply power when
the
> main power goes down. Then switch back when power returns.
> From: Ricky Konvicka [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=qU56-C0SGXrokIDe-zmmJLQ0ezc_b6pCUPqm6X2MqYwIhXF5W2QjEps_TRX89btVAD0rqlhYCdCM28RBpsOleQ]ricky@m...[/url
> Sent: Monday, April 01, 2002 1:43 PM
> Subject: [noparse][[/noparse]basicstamps] Battery Backup
in
eliminate
looking
line.
The trick here is to use a diode for blocking such that when the power
from the system is removed, the clock can run on it's own power. The
way to do this is to break the line at a point before the cap you have
chosen is in parallel with the chip. Put a diode in series with this
arrangement such that the anode is towards the supply source. This way
when external power is removed the diode will be reverse biased.
+ diode
Power _+ Clock circuit
_ cap goes here
I did this but only on the main power line to keep from feeding power to
another board. I did not think about doing it to isolate the components on
one board. I think I will give this a try. Thanks Leroy!
> + diode
> _ cap goes here
> HTH
> Leroy Hall
some weeks ago someone posted how a battery can be connected to a stamp to
serve as a backup in case the power supply fails. It was something very
simple, I guess it was you, Tracy.
Can't find it anymore, could someone repeat it for me?
Thanks very much for help,
Uli
I want to implement a battery backup for a Stamp. Can I just hook both the
DC voltage supply and the batteries together with a diode to protect the
batteries? Eventually I will probably put a charger in the device and use
NiCad batteries, but for now I want to be able to use either alkalines or
NiCads that I charge away from the device. Any simple charging circuits that
anyone has would be great too :-) .
>Hi All,
>Thanks,
>Jonathan
>www.madlabs.info
not too long ago there was a thread here on this . . .
I implemented two 1004 diodes in parallel, one diode
gets a 12v wall wort, the other a nine volt alkaline
battery. The joining diodes then have an electrolytic
cap to ground, and also go into a 7805.
Works great. The higher voltage from the transformer
eliminates any current flowing from the battery. To
check I put a 1 ohm resistor on the battery lead, and
sure enough, no voltage drop across it (1 ohm makes
for easy math conversion to ma).
Pull the transformer, and the battery conducts, no
hicups on the stamp or other devices I have running of
the 7805.
Regards, John.
--- Jonathan Peakall <jpeakall@m...> wrote:
> Hi All,
> Thanks,
> Jonathan
> www.madlabs.info
> Text in the Subject and Body of the message will be
> ignored.
__________________________________________________
Do you Yahoo!?
Yahoo! Tax Center - forms, calculators, tips, more http://taxes.yahoo.com/
Thanks Tracy. That's what I had in mind, just wanted to be sure!
Jonathan
Sent: Friday, February 21, 2003 11:23 AM
> >Hi All,
the
that
> >Thanks,
> >Jonathan
> >www.madlabs.info
> diode diode
> +battery --->|
o
|<----+DC supply
stamp Vin
>willing to share?
How about:
power 1 --->|---;
1N4001s o--- Vdd
battery --->|---'
Vss common
-- regards,
Tracy Allen
mailto:tracy@e...
http://www.emesystems.com
Just a Thought:
when it was needed.
the PIC was altered
the I2C EEPROM, and
a few days!
for BEAM robots too
Ben
BEN (TEAM DBR)
http://www.geocities.com/temdbr
Do You Yahoo!?
Get personalised at My Yahoo!.
worth
> Just a Thought:
several
> when it was needed.
> the PIC was altered
> the I2C EEPROM, and
> a few days!
vice-versa.
You can also feed the output from the supervisor IC or LM339 into a I/O pin
on the Stamp and have the Stamp turn the battery on or off too. But if your
simple reed relay if you like) or other transistor to supply power when the
From: Ricky Konvicka [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=u-JmEkzGHYY1dpkF1sKXmxHmlwHgad4x4qFsJWS9TvZjwAdlUr9qH7K6owQzdBOYLH6ibKJ_Yaiyqj58wgW_9Q]ricky@m...[/url
may
supplies
these
drops
> vice-versa.
them
pin
your
the
in
eliminate
looking
line.
+ diode
_ cap goes here
HTH
Leroy Hall
To: <basicstamps@yahoogroups.com>; <ricky@m...>;
<earlwbollinger@a...>
Sent: Tuesday, April 02, 2002 10:18 AM
> + diode
> _ cap goes here
> HTH
> Leroy Hall
Uli
Jonathan
www.madlabs.info
>Thanks,
>Jonathan
>www.madlabs.info
diode diode
+battery --->|
o
|<----+DC supply
stamp Vin
the 7805.
Regards, John.
> Hi All,
> Thanks,
> Jonathan
> www.madlabs.info
> ignored.
Do you Yahoo!?
Jonathan
> >Hi All,
the
that
> >Thanks,
> >Jonathan
> >www.madlabs.info
> diode diode
> +battery --->|
o
|<----+DC supply
stamp Vin
