CAT 5e
I am going to use CAT 5e cable to hook two stamps together. I just
want to know would this work to send info 30ft.
blue = Ground
blue / white = VCC (12 V)
orange = Ground
orange / white = SERIN
green = Ground
green / white = SEROUT
brown = Ground
brown / white = VDD (5 V)
I want to make it so I have little cross talk. Will this work, or
dose anyone have any ideas? I want to use CAT 5e because I get it
free from my boss
A.j.
blue = Ground
orange = Ground
green = Ground
brown = Ground
free from my boss
A.j.
this application does nothing to reduce crosstalk between circuits. If
crosstalk reduction is a parameter that you wish to achieve then use
balanced drivers and receivers for serial in and serial out. If you need
both 5 volts and 12 volts at each stamp separated by thirty feet then
consider using isolated supplies at each stamp and avoid the presence of
common mode power currents on common grounds.
Steve
Sent: Sunday, December 16, 2001 8:00 PM
Subject: [noparse][[/noparse]basicstamps] CAT 5e
> blue = Ground
> orange = Ground
> green = Ground
> brown = Ground
> free from my boss
> Thanks
> A.j.
