voltage follower mystery
I am trying to make a very simple voltage follower that generates an
output voltage equal to its input voltage (over a 0 to 5 vdc range).
I tried using an LM358 (from the analog/digital Basic Stamp kit) and
wired it up as a voltage follower, as described in the Analog and
Digital manual (page 13. i.e., 5vdc power to pin 8, ground to pin 4,
connected pin 1 and 2, put input voltage to pin 3 and read output at
pin 1). THe circuit works fine up to 3.75 volts, but the output will
go no higher then 3.75, even when the input is a full 5 volts. What
am I doing wrong, and/or can I use this op amp to follow the voltage
across the whole 0 to 5vdc range?
voltage (usually ground), but the amount of current you draw will push
the upper limit away from the supply voltage. If you want the voltage to
vary between 0 and 5, you need (for a normal op amp) a larger supply
voltage like -5 to 10V or something. However, as I said, many op amps
can go to ground so a 0-9 or 10 or 12V supply would be OK for those.
The LM358 is a "single supply" op amp. If you get the data sheet look at
http://www.national.com/ds/LM/LM158.pdf and read the chart labeled
Output Characteristic Current Sourcing.
Hope that helps.
Al Williams
AWC
* Floating point A/D
http://www.al-williams.com/awce/pak9.htm
> From: tomatlarge [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=B5tuY0EvMDm20CZgJSdi6018EVaB_XjpIxaTmR_yL_s_nSB7SdfuEis-ubAkHoG94iqkXQJMpXOJ0XtFGQQ]tomatlarge@y...[/url
> Sent: Sunday, December 16, 2001 12:48 PM
> Subject: [noparse][[/noparse]basicstamps] voltage follower mystery
> from the same email address that you subscribed. Text in the
typing and indeed a 9 vdc power supply fixes the problem--as verified
on the breadboard. Thanks!
--- In basicstamps@y..., "Al Williams" <alw@a...> wrote:
> Most op amps will not go "to the rail". Some can go to one supply
push
voltage to
amps
those.
look at
> Hope that helps.
> Al Williams
> AWC
> > From: tomatlarge [noparse][[/noparse]mailto:tomatlarge@y...]
> > To: basicstamps@y...
an
range).
and
4,
at
will
What
voltage
> > basicstamps-unsubscribe@y...
