Communicating with a Palm
Has anyone done anything with downloading/uploading info using a Palm
PDA? Being able to download stored data to a Palm might be very handy
if someone is doing data acquisition. If so, where can I find info on
doing it?
doing it?
Palm. Helps if you know Java :-)
http://www.wabasoft.com -- In fact, I think I did an article on this for
Dr. Dobb's using an embedded controller (might have been a Stamp, or
something else) to talk to CE/Palm. Let's see.... There it is:
http://www.ddj.com/articles/2001/0102/ not online though :-(
Al Williams
AWC
* Control 8 servos at once
http://www.al-williams.com/awce/pak8.htm
> From: rcvehicles [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=jprRWmf-Wc08Z_ZFvs0okjHdOFAIAOL71sf26gpkUUl1hqZfi_uQ4KruZd99ZzihRC8JbFky_EZJpBvt]hankster@h...[/url
> Sent: Friday, December 14, 2001 12:44 PM
> Subject: [noparse][[/noparse]basicstamps] Communicating with a Palm
> doing it?
> from the same email address that you subscribed. Text in the
I have a basic serial interface running.
Just send serialout from Basic Stamp and have the Palm read it's
serial port.
I use a language called CASL (www.caslsoft.com) on the Palm which
gives you a nice IDE, objects, database, access to serial port, etc.
So far it works fine.
The Palm has a serial buffer and can process and save data from the
BS at 9600 baud.
The Palm is a data comm device (same as BS serial port) so you need a
null modem cable to attach to the serial port of the BS.
/Mark
Palm
handy
on
> doing it?
>doing it?
If you want instant gratification, try out 5-star rated "online" from
http://www.markspace.com/online.html
You can download data either to the memopad (4-k per memo) or to a
DOC file, or to a text file on external media.
A good general purpose programming language is NSbasic from
http://www.nsbasic.com/palm/
-- Tracy
