simple question (pnp)
Yes, with the PNP you would connect the Emitter to 5volts, Collector to the
load, and a resistor (~4.7K - 47K) between the Base and the stamp pin, then
making the pin low would drive the load, high would turn it off.
It is usually done with NPN's in what is known as open collector or grounded
emitter configuration so that the load can be connected to a different
voltage say +12V and the Collector switches the ground side.
From: "Richard R." Re: [noparse][[/noparse]basicstamps] simple question
> Quick question, Can I use a PNP 2N3906 in place of a 2N3904 with a 50V 1A
> 1N4001 Diode to drive a small relay? What's the difference? I am only
asking
> because I have some 2N3906's
> Thanks Richard
asking
> Thanks Richard
Richard
<techsupport@f...>
Sent: Friday, December 14, 2001 10:04 AM
Subject: Re: [noparse][[/noparse]basicstamps] simple question (pnp)
the
then
grounded
1A
> asking
> > Thanks Richard
