DC Voltage Filter
I have a sensor (air flow) that generates a signal from 0 to 5 volts
dc. I am looking for an op amp (or other simple) circuit that will
essentially act as a voltage follower, but which will not let the
voltage drop below a preset minumum, such as .5 volts. Ideally, the
minimum would be adjustable via a pot. In other words, I want a
circuit that produces a signal that mirrors the input, except that
the output should never fall below a set minimum even if the input
does. Any ideas?
does. Any ideas?
>does. Any ideas?
I've not built this circuit, but I think it should work (famous last
words). View with monospace font.
input-|+\ 1N4148
| |/ o
output
o
100k |
100k |
o
| | 10k
| |\ o-/\/\-common
0.5V--|+/ 1N4248
dual op-amp
LM358 or LT1078
This is like gating two signals with diodes to select the largest:
input1 --->|---;
o--- output
input2 --->|---o-/\/\- common
The output is the higher of the two input voltages, except there is a
diode drop in series with each signal. The op-amp circuit puts the
diodes in the feedback loops, so the output should clamp right at 0.5
volts, that is, pick whichever input is the higher voltage.
-- regards
Tracy Allen
http://www.emesystems.com
mailto:tracy@e...
offset terminals to dial in the offset.
If the op-amp doesnt have offset terminals then make a voltage divider bias
the input terminals ?
richard
Sent: Thursday, December 13, 2001 2:16 PM
Subject: [noparse][[/noparse]basicstamps] DC Voltage Filter
> does. Any ideas?
Thanks for your note. That all sounds good, but I'm just a hobbiest
(with mostly digital projects under my belt) and need some serious
hand-holding (i.e., a circuit diagram with part numbers). I'm told
that national has an op amp data sheet with this exact circuit, but
have not been able to find it. The circuit just replicates the input
voltage, without letting the output drop below a preset minimum
voltage.
--- In basicstamps@y..., "Richard Friedrich" <rfriedrich@a...> wrote:
> couldnt you use a voltage follower - (no gain opamp)- then use
the dc
divider bias
> richard
> From: "tomatlarge" <tomatlarge@y...>
> To: <basicstamps@y...>
volts
the
> > does. Any ideas?
> > basicstamps-unsubscribe@y...
Subject and
Many thanks for this. (Couldn't format it for a while, then "saw" the
picture when I hit reply...go figure.) I will try this out and let
you know how it works. What is the defference between the two diodes?
volts
> >does. Any ideas?
last
> input-|+\ 1N4148
> | |/ o
output
o
> 100k |
> 100k |
o
> | | 10k
> | |\ o-/\/\-common
> 0.5V--|+/ 1N4248
> dual op-amp
> LM358 or LT1078
> input1 --->|---;
> o--- output
a
0.5
> -- regards
> Tracy Allen
> mailto:tracy@e...
spots (and Tracy will correct me if I'm wrong).
Al Williams
AWC
* 8 channels of PWM
http://www.al-williams.com/awce/pak5.htm
> From: tomatlarge [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=CFwz0Im3G_8SCE27j8XbviT6l1uJJ14vVNXt2mDKbchAtdZfWS6ykq1mcHSaixD6OpG-CBK3PL1mCuMnxTs3]tomatlarge@y...[/url
> Sent: Sunday, December 16, 2001 1:18 PM
> Subject: [noparse][[/noparse]basicstamps] Re: DC Voltage Filter
> Tracy,
> volts
> Ideally, the
> > >does. Any ideas?
> last
> > input-|+\ 1N4148
> > | |/ o
output
o
> > 100k |
> > 100k |
o
> > | | 10k
> > | |\ o-/\/\-common
> > 0.5V--|+/ 1N4248
> > dual op-amp
> > LM358 or LT1078
> > input1 --->|---;
> > o--- output
> a
> 0.5
> > -- regards
> > Tracy Allen
> > mailto:tracy@e...
You already have the LM358 op amp, so use that, and as you discovered
in "voltage follower mystery", you get the best results when you run
it on a 9 volt power supply (to pins 4[noparse][[/noparse]-] and 8[noparse][[/noparse]+]).
>I'm guessing that was a typo. A 1N4148 or 1N914 should be OK in both
>Al Williams
>AWC
>* 8 channels of PWM
> > From: tomatlarge [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=8lDVZ7Xoz8lhsfQPKMRuri0nNvAVd47yvah8bWdSp5nYl-FzDjf4YufwaxljhvMxx1Jpf4K2IUdH59FybYA]tomatlarge@y...[/url
> > Tracy,
> > volts
> > Ideally, the
> > > >does. Any ideas?
> > last
> > > input-|+\ 1N4148
> > > | |/ o
output
o
> > > 100k |
> > > 100k |
o
> > > | | 10k
> > > | |\ o-/\/\-common
> > > 0.5V--|+/ 1N4248
> > > dual op-amp
> > > LM358 or LT1078
> > > input1 --->|---;
> > > o--- output
> > a
> > 0.5
> > > -- regards
> > > Tracy Allen
I finally tried to breadboard this circuit yesterday and had curious
results. It seemed to work, but only to a point. When I set the input
voltage very low (like .08 volts, using a pot to step down 5 volts),
this circuit would maintain a higher minimum, like .2 volts. Above
that it seemed to track the input voltage perfectly. Should this
circuit work even with low input voltages? If so, any guess what I'm
doing wrong?
> Ah yes, a typo. Just about any small diode will work fine there.
discovered
run
both
> >Al Williams
> >AWC
> >* 8 channels of PWM
> > > From: tomatlarge [noparse][[/noparse]mailto:tomatlarge@y...]
> > > To: basicstamps@y...
> > > Tracy,
then "saw" the
let
diodes?
5
> > > volts
that will
let the
> > > Ideally, the
want a
except that
input
> > > > >does. Any ideas?
(famous
> > > last
> > > > input-|+\ 1N4148
> > > > | |/ o
output
o
> > > > 100k |
> > > > 100k |
o
> > > > | | 10k
> > > > | |\ o-/\/\-common
> > > > 0.5V--|+/ 1N4248
> > > > dual op-amp
> > > > LM358 or LT1078
largest:
> > > > input1 --->|---;
> > > > o--- output
there is
> > > a
puts the
right at
> > > 0.5
> > > > -- regards
> > > > Tracy Allen
I'm not as ssmart as Tracy but my guess is that the device you are using
bottoms out at .s volts. Chips will not go to 0 volts. If you need to go to
0 for a readout, use a bucking voltage ciruit in series with a 10K pot to
force the output to 0.
Sid
Be sure you have the 10k pulldown resistor to common at the output.
I quickly built the circuit myself with pots on both inputs and an
LM358, and it worked as advertised down to less than one millivolt on
either input. That is, the output is equal to whichever input is
higher. What do you have the output hooked up to?
-- best regards
Tracy Allen
mailto:tracy@e...
>Tracy,
>doing wrong?
>> > > > input-|+\ 1N4148
>> > > > | |/ o
output
o
>> > > > 100k |
>> > > > 100k |
o
>> > > > | | 10k
>> > > > | |\ o-/\/\-common
>> > > > 0.5V--|+/ 1N4248
>> > > > dual op-amp
> > > > > LM358 or LT1078
action (it feeds a voltage to a 8051-based controller), but for
testing purposes, I just put a volt meter on the output pin. Of
course, I did this on my lap while watching TV, so maybe I need to
try again?
> Hi tomate
on
> -- best regards
> Tracy Allen
> mailto:tracy@e...
> >Tracy,
curious
input
volts),
I'm
> >doing wrong?
> >> > > > input-|+\ 1N4148
> >> > > > | |/ o
output
o
> >> > > > 100k |
> >> > > > 100k |
o
> >> > > > | | 10k
> >> > > > | |\ o-/\/\-common
> >> > > > 0.5V--|+/ 1N4248
> >> > > > dual op-amp
> > > > > > LM358 or LT1078
about .2volts lower than the input. I just realized I've been using
1megohm resistors instead of 100k (and don't have 100k handy). Would
that explain it? Thanks again for your help.
--- In basicstamps@y..., "tomatlarge" <tomatlarge@y...> wrote:
> I had planned to use a 10k resistor before putting the circuit in
> try again?
> > Hi tomate
output.
an
millivolt
> on
> > -- best regards
> > Tracy Allen
> > mailto:tracy@e...
> > >Tracy,
> curious
> input
> volts),
Above
> I'm
> > >doing wrong?
> > >> > > > input-|+\ 1N4148
> > >> > > > | |/ o
output
o
> > >> > > > 100k |
> > >> > > > 100k |
o
> > >> > > > | | 10k
> > >> > > > | |\ o-/\/\-common
> > >> > > > 0.5V--|+/ 1N4248
> > >> > > > dual op-amp
> > > > > > > LM358 or LT1078
The 1M resistors might explain it, but 0.2 volt seems high even so.
The op-amp bias current has to flow through the resistor. That is
one reason it has to have the 10kohm pulldown resistor on the output.
The bias current has to find a path to ground. If you have some more
10k resistors, you could substitute those where you have the 1Mohms
now. Come to think of it, the circuit should even work fine with zero
ohms in that feedback path:
Output equals highest of two inputs.
input1 -|+\ 1N4148
| |/ o
output
o
o
| | 10k
| |\ o-/\/\-common
input2 -|+/ 1N4148
dual op-amp
LM358, pin 4 to Vss, pin 8 to +9 volts.
You should expect the input and the output to be within 1 or 2
millivolts of one another at worst. It goes without saying, check
the wiring. What kind of voltmeter do you have (high input
impedance)? And where do your input voltages come from? In my
version I am getting the two input voltages from the wipers of 10kohm
pots connected across 5 volts.
-- regards,
Tracy Allen
mailto:tracy@e...
>ok, It almost works almost perfectly now, except the output is
> > try again?
> > > Hi tomate
>output.
>an
>millivolt
> > on
> > > -- best regards
> > > Tracy Allen
> > > mailto:tracy@e...
> > > >Tracy,
> > curious
> > input
> > volts),
>Above
> > I'm
> > > >doing wrong?
> > > >> > > > input-|+\ 1N4148
> > > >> > > > | |/ o
output
o
> > > >> > > > 100k |
> > > >> > > > 100k |
o
> > > >> > > > | | 10k
> > > >> > > > | |\ o-/\/\-common
> > > >> > > > 0.5V--|+/ 1N4148
> > > >> > > > dual op-amp
> > > > > > > > LM358 or LT1078
Note, I corrected the typo on the schematic: both diodes are 1N4148.
without the resistors. (A regulated power supply also helped!) I'll
let you know once I get my project going to see how it works in the
field. [noparse]:)[/noparse] Thanks again.
> Hi tom
output.
more
zero
> input1 -|+\ 1N4148
> | |/ o
output
o
o
> | | 10k
> | |\ o-/\/\-common
> input2 -|+/ 1N4148
> dual op-amp
10kohm
> -- regards,
> Tracy Allen
> mailto:tracy@e...
Would
in
to
> > > try again?
> > > > Hi tomate
> >output.
and
> >an
> >millivolt
> > > on
is
> > > > -- best regards
> > > > Tracy Allen
> > > > mailto:tracy@e...
> > > > >Tracy,
> > > curious
the
> > > input
> > > volts),
> >Above
this
what
> > > I'm
> > > > >doing wrong?
> > > > >> > > > input-|+\ 1N4148
> > > > >> > > > | |/ o
output
o
> > > > >> > > > 100k |
> > > > >> > > > 100k |
o
> > > > >> > > > | | 10k
> > > > >> > > > | |\ o-/\/\-common
> > > > >> > > > 0.5V--|+/ 1N4148
> > > > >> > > > dual op-amp
> > > > > > > > > LM358 or LT1078
1N4148.
> From: Chris Loiacono [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=qQCN5OqT25jwlHwhrxGs7_P2nkjNUrkY6BaLjVYfgvdf_FL3HcD8dMCtN2dacvFaWqSNGQ0u9FLZlJPQZw]chris@m...[/url
> Sent: Friday, December 21, 2001 8:41 AM
> To: 'basicstamps@yahoogroups.com'
> Subject: RE: [noparse][[/noparse]basicstamps] Re: DC Voltage Filter
> In fact, if there were a "Stamper of the Year" award based on
> knowledge and generosity with it, I would have to nominate
> Tracy. Many others contribute regularly in an unselfish way
> also and are appreciated as well, and this is one of the
> things that makes this list so special. I am glad you all let
> me play too. My thanks to all....
> > Tracy, you are a genius. Thank you soooo much. It works
> like a champ
> helped!) I'll
my circuit (thanks Tracy), I wanted to take the output voltage and
send it to an 8051 based controller. I was planning on putting a 10k
resistor on the output of this circuit, in series, to avoid too much
current flow. I just looked at the National datasheet for the LM358,
however, and it shows a circuit for "driving TTL" gates. (Not sure is
car's computer is TTL or CMOS or ?) That they show is the output
connected to ground via a 240 ohm resistor and directly to the TTL
gate without a resistor. Does that make sense? If I did without the
240 resistor to ground and put a 10k in series between this circuit
and the 8051-based controller, I'd be ok, no?
> Tracy, you are a genius. Thank you soooo much. It works like a
champ
I'll
> > Hi tom
so.
is
> output.
> more
1Mohms
> zero
> > input1 -|+\ 1N4148
> > | |/ o
output
o
o
> > | | 10k
> > | |\ o-/\/\-common
> > input2 -|+/ 1N4148
> > dual op-amp
check
> 10kohm
> > -- regards,
> > Tracy Allen
> > mailto:tracy@e...
using
> Would
circuit
> in
for
Of
need
> to
> > > > try again?
> > > > > Hi tomate
> > >output.
> and
> > >an
> > >millivolt
> > > > on
input
> is
> > > > > -- best regards
> > > > > Tracy Allen
> > > > > mailto:tracy@e...
> > > > > >Tracy,
had
> > > > curious
set
> the
> > > > input
5
> > > > volts),
volts.
> > >Above
Should
> this
guess
> what
> > > > I'm
> > > > > >doing wrong?
> > > > > >> > > > input-|+\ 1N4148
> > > > > >> > > > | |/ o
output
o
> > > > > >> > > > 100k |
> > > > > >> > > > 100k |
o
> > > > > >> > > > | | 10k
> > > > > >> > > > | |\ o-/\/\-common
> > > > > >> > > > 0.5V--|+/ 1N4148
> > > > > >> > > > dual op-amp
> > > > > > > > > > LM358 or LT1078
> 1N4148.
I'm not clear on the purpose. The goal of the LM358 circuit was to
provide an analog voltage, so it makes more sense to talk about
putting that voltage into an analog-to-digital converter (ADC).
Maybe the controller has one?
It does not really make sense to talk about interfacing it to TTL or
CMOS, which are digital logic families. The interface circuit you
saw in the LM358 data sheet is probably for a comparator, not an
analog amplifier. And forget about the TTL interface with the 240
ohm resistor. The original full-fledged TTL is history.
It _is_ usually wise to put a resistor between the output of one
circuit and the input of another when they are different modules.
Doing so can save a lot of grief.
-- Tracy
what I am connecting the voltage to. [noparse]:)[/noparse] This is for my car. It has
an air flow meter that generates a signal from 0 to 5, which feeds
the engine management computer (Bosch DME circa 1983, I'm told based
on 8051 technology--i.e., a black box) to drive fuel injectors and so
forth. The black box takes the signal and uses it to generate duty
cycles for the fuel injectors. More air means higher voltage means
longer duty cycles and more gas. I know that the engine computer uses
an EPROM with maps of duty cyles for various conditions. (In addition
to the signal from our circuit, it looks at engine temp, air
dentsity, etc.) So, I assume the signal generated by this circuit
goes to an A/D converter so that the cpu can process it with the
other information and then pick just the right duty cycle off the
EPROM maps. SO, I figured a 10k resistor would be prudent, but was a
little confused by the TTL circuit shown by National. Was TTL dead in
the early 80's? Either way, I think you are right when you say the
voltage is not driving digital circuitry anyway (directly).... so it
sounds like I should stick with the 10k resistor in series and stop
confusing myself. [noparse]:)[/noparse]
> >No good deed goes unpunished. I have another question. Now armed
with
10k
much
LM358,
is
> -- Tracy
electronics (which I don't!) so maybe they will chime in on the topic
of engine management computers.
If the signal feeds an ADC in the engine computer, the the ADC
_probably_ has a high input impedance. But not necessarily. What I
mean by that is, try it with a 1000 ohm resistor between the output
of your LM358 circuit and the input to engine computer, and measure
the voltage on both sides of the resistor (referenced to common). If
they are the same, then it is okay and prudent to leave the resistor
in place. If the voltages are different, that means that the ADC
has a low input impedance, and you should use a lower value of
resistor, 100 ohms or 10 ohms. When dealing with "black boxes", you
have to probe the black box characteristics by doing experiments!
If you were doing this with a Stamp, you would feed the signal into
an ADC and then write your own formula or lookup table for the duty
cycle. I recall several projects along that line have appeared here
on the list.
>was a little confused by the TTL circuit shown by National. Was TTL
>dead in the early 80's?
The circuit: TTL (transistor-transistor-logic) was a relatively
power hungry logic family, that sat there pulling a milliamp or more
per gate even when it was not doing anything. The inputs of true TTL
are "current sinking". What that means is that if you leave the
input open or tie it through resistor to +5 volts, it acts like a
HIGH logic level, and little or no current is needed to maintain the
high level at the input. To bring the input low, you have to short
circuit it to ground, and in that condition a good fraction of a
milliamp will flow out of the input pin into ground. That is current
sinking. If you connect a resistor from the input to ground, there
is a certain minimum resistance, or else it won't work. It is kind
of like bringing a telephone off-hook, if you are familiar with that;
the line has to be brought to a low impedance state. If you put a
resistor from a true TTL input to ground, the voltage at the input is
not zero, due to the current flowing through the resistor. If the
voltage at the input is above about 1.4 volts, the input will be
interpreted as HIGH instead of LOW.
Sooooo, the point of the 240 ohm resistor in the LM358 circuit was
this. The LM358 by itself has a relatively weak output and cannot by
itself sink quite enough current to turn on a TTL input gate
reliably. The 240 ohm resistor sinks the extra current needed, when
the LM358 output is LOW. When the LM358 output is high (as a
comparator), it pulls the TTL input high, but also wastes a lot of
current into the 240ohm resistor. A bad compromise. But that is
history. Although a lot of legacy systems are still out there. It
has nothing to do with what you are doing.
There is still an important vestige of TTL in the phrase "TTL logic
levels". This has to do with the 1.4 volt threshold that is
interpreted as LOW and HIGH. In modern circuitry the inputs are high
impedance and do not draw DC currents in either the HIGH or the LOW
states. It is CMOS circuitry faking TTL logic levels. The BASIC
Stamp uses TTL logic levels at its inputs, but the Stamp inputs are
definitely not true TTL. They are high impedance CMOS.
ADCs usually have quite a high input impedance, but not necessarily.
Older ones might have a 100kohm or even 10kohm input impedance, in
which case you can't put a resistor in series without losing some of
your signal!
I hope that clears things up some.
-- regards,
Tracy Allen
mailto:tracy@e...
>Thanks and sorry to be unclear. My problem is that I am not 100% sure
>with
>10k
>much
>LM358,
>is
>or
> > -- Tracy
thing. If the input on the black box is high impedance, why would I
want a bigger resistor? Is it because a high impedance input does not
draw much current and therefore should not be fed much current? (If
the input is high impedance, then I would have thought it acted as
its own current limiter, no?) If it has a lower impednace, and I use
a smaller resistor, don't I risk sending too much current to the
input? (I think I'm confused about the defference between resistance
and impedance.) You are being extremely helpful to me, but if you
are getting tired of the pestering, feel free to say so. [noparse]:)[/noparse]
I
If
resistor
you
necessarily.
of
> your signal!
> -- regards,
> Tracy Allen
> mailto:tracy@e...
sure
based
so
uses
addition
a
in
it
armed
> >with
and
putting a
> >10k
> >much
> >LM358,
sure
> >is
output
TTL
without the
circuit
to
TTL
> >or
you
240
modules.
> > > -- Tracy
No problem!
There are two separate issues in the problem you are facing. One
issue is protection of the the two circuit modules from one another.
The second issue is the impedance, get the signal intact without
error from the amplifier to the car computer. For protection, you
want to put a relatively high resistance between the two modules.
That is so that if some glitch happens in the voltage in one circuit,
it can not cause a potentially bad glitch current in the other
module. But you cannot make the resistance too large, because of
potential signal loss due to the impedance losses.
The concept of input and output impedance is one of the most
important Basics to understand in electronics. Both of the issues
above are in a way related to the concept, but under different
conditions that can occur in your circuit, one normal and one
abnormal.
It all comes down to voltage dividers. Impedance also includes
capacitance and inductance, but you can often ignore them for the
first approximation in a DC voltage filter and just say, input and
output "resistance" instead of "impedance".
V result
V input
/\/\-o--o---/\/\---- common
R output ' R input
The voltage source on the left is your LM358 amplifier, and the extra
resistor "R output" is the one you put in its output. The circuit on
the right is the car computer module with an unknown input resistance
"R input". The voltage V result is what the car computer actually
measures. It is given by the voltage divider equation:
V result = V input * (Rinput/(Routput+Rinput))
If Rinput>>Routput, then the term in parentheses equals one, and
Vresult=Vinput, which is what you want. In practice, if Rinput=10
megaohms, then using Routput=10000 ohms would give only
10000/10000000 * 100% = 0.1% error. But if Rinput in the "black box"
happens to be only 100kohms, then the error would be 10000/100000 *
100% = 10% error. That is what it comes down to. Rinput>>Routput.
The other issue is input protection. Take for example the case where
you turn on your amplifier before the car module. Under that
condition Rinput might (black box!) be much less than its normal
value. In fact, it will likely look like this, while the car
computer is turned off:
V result
V input
/\/\-o--o--->|---- common
R output ' R input=10 ohms
with a diode to common
The diode is an intrinsic part of the circuit, a "substrate diode".
The input resistance is now close to zero, because diodes can conduct
a lot of current in the forward direction, once the input voltage is
greater than 0.7. So now the current is limited mainly by Routput:
I = (Vinput-0.7)/(Routput+10)
If you have Routput=0, and Vinput is 5 volts, you could potentially
have 5volts/10 ohms = 0.5 amp. But that will never happen, because
the LM358 itself will limit the current to 10s of milliamps. Still,
even 10s of milliamps could have (black box!) a bad effect and cause
the car computer to "lock up". Unlikely, but it is always good to
play it safe. If you can put 1000 ohms in there (without causing
signal loss as explained in the previous paragraph) then go for it.
But if 1000 ohms would cause too much error in normal operation, then
100 ohms would still be a help.
The protection issue goes the other way too. Let's say you are
working under the hood in a cramped space and you accidently hook up
the output of your amplifier directly to the 12 volt car battery
terminal instead of to the car computer input. (ouch!). If you have
that Routput=1000 ohms installed, then no worries. The current flow
from the 12 volts back through the diodes in the output circuit of
the LM358 will be limited to 12 ma. But without the 1000 ohms,
SMOKE.
-- regards,
Tracy Allen
mailto:tracy@e...
> >Thanks again Tracy. I guess I am confused by the high impedance
not
(If
use
resistance
> No problem!
another.
circuit,
> abnormal.
V result
> V input
> R output ' R input
extra
on
resistance
box"
where
V result
> V input
conduct
is
Still,
cause
then
up
have
flow
> SMOKE.
> -- regards,
> Tracy Allen
> mailto:tracy@e...
That all makes sense, I think. The good news is that I took the
circuit live this afternoon and drove the car while running off the
LM358 output (with a 1k resistor in series). Although the voltage
fluxuates when the car is idling, there was no obvious or noticable
difference in voltage on either side of the resister, so I assume the
black box is high impendance and all is good. Now, on the other side
of the circuit -- the sensor input into the LM358, should I use a
resistor there too? In other words, is the LM358 high impendance
itself? The sensor voltage is another black box really -- no idea
how much current it might be able to flow. I tied it straight to the
LM358 without thinking about it, and it worked fine, but I'm thinking
I should do the same thing on that side of the circuit as well. yes?
not
(If
use
resistance
> No problem!
another.
circuit,
> abnormal.
V result
> V input
> R output ' R input
extra
on
resistance
box"
where
V result
> V input
conduct
is
Still,
cause
then
up
have
flow
> SMOKE.
> -- regards,
> Tracy Allen
> mailto:tracy@e...
>itself?
Yes, and yes.
-- Tracy
The LM358 and other op-a or comparator have is called input bias
current.
Granted is small but with a large resistor in the input, may create
un undesirable offset voltage.
> >itself?
> Yes, and yes.
> -- Tracy
