Small Problem
You should use only one resistor: the pullup.
Low is read with direct contact with GND
ACJacques
At 17:07 11/02/02 +0000, you wrote:
>I am trying to detect whether an input pin is floating or shorted to
>ground. Right now I have a 10k pull-up resistor on the pin so I
>should normally read a HIGH and when it is shorted to ground I should
>read a LOW while pulling 500uA through the resistor. The problem is
>that when it is floating, there is only about 1.5V on the pin, not
>5V. Any suggestions as to how I could get it to read a high when the
>pin is floating?
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
ACJacques
>pin is floating?
pin is floating?
consigli@p... writes:
> pin is floating?
Make sure your pin is in INPUT mode and then double check. It is possible
the pin is damaged. Test your circuit on another pin to confirm.
-- Jon Williams
-- Parallax
