Frustration
Hello everyone! How are you? Good? Me too.
Here's my problem: The program that I am writing is a large one, but I won't
bother you with the details, just the ones that I know are significant. It is
stuck in a loop at this one spot and I can't figure it out. Please help me!! I'm
kinda new at this, and I think my problem may be the array, as I have not used
it in this way before.
Background:
y is a Byte value, as is x. They do NOT write over ANYTHING. They are
pre-defined by me. The array is a 10 WORD array, starting at B0. z is stored at
B0, which is where the array starts(the array is defined by the BS), but I dont
think there's a problem because the first time I write to z is here (z = x), and
I've already written the lowbyte of the array to the EEPROM and don't have any
use for the space. You see, after the array is written to the EEPROM, The space
it occupied can be written over (you see that ( "value(z) = 0" sets the entire
space occupied by the array to 0). "snap" simply goes to the rest of the
program. Feel free to ask any additional questions of me if it will help. The
debug shows me that there is a loop, y brings up something like this:
20, 22, 24, 26, 28, 30, 0, 2, 4, 6, 8, 10, 0, 2, 4, and repeats 0-10 forever.
x repeats 0-10 also, starting at 0. I'm stumped on this one!
y = 20
x = 0
here3:
DEBUG DEC y, CR
WRITE y, value.LOWBYTE(x)
z = x
y = y + 1
x = x + 1
x = x + 1
y = y + 1
value(z) = 0
PAUSE 100
IF x = 19 THEN snap
GOTO here3
Background:
y = 20
x = 0
here3:
DEBUG DEC y, CR
z = x
y = y + 1
x = x + 1
x = x + 1
y = y + 1
value(z) = 0
PAUSE 100
IF x = 19 THEN snap
GOTO here3
Sid
Sid
You increment x by 2 each time before the IF X=19 THEN SNAP
and you start with x=0 so x will never be 19.
Change the if then line into
IF X>19 THEN SNAP
Now you should escape the loop
Regards peter
Oorspronkelijk bericht
Van: Astro Fizzix [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=gdiiXMLkOmWPoj3Aw6Dz8xcbmmcoS_FwxYLM-_1DQBsqppE-6AXfINulyyLtav1Ayvbu0_mn8IiZ-9frjA]astro_fizzix@y...[/url
Verzonden: dinsdag 11 december 2001 12:29
Aan: Post BS Message
Onderwerp: [noparse][[/noparse]basicstamps] Frustration
won't bother you with the details, just the ones that I know are
significant. It is stuck in a loop at this one spot and I can't figure it
out. Please help me!! I'm kinda new at this, and I think my problem may be
the array, as I have not used it in this way before.
Background:
at B0, which is where the array starts(the array is defined by the BS), but
I dont think there's a problem because the first time I write to z is here
(z = x), and I've already written the lowbyte of the array to the EEPROM and
don't have any use for the space. You see, after the array is written to the
EEPROM, The space it occupied can be written over (you see that ( "value(z)
= 0" sets the entire space occupied by the array to 0). "snap" simply goes
to the rest of the program. Feel free to ask any additional questions of me
if it will help. The debug shows me that there is a loop, y brings up
forever.
y = 20
x = 0
here3:
DEBUG DEC y, CR
z = x
y = y + 1
x = x + 1
x = x + 1
y = y + 1
value(z) = 0
PAUSE 100
IF x = 19 THEN snap
GOTO here3
is not getting above 10 for some reason. Here's the debug:
2, 4, 6, 8, 10, 0, 2, 4, 6, 8, 10, 0, etc.
I've tried the exact values of 20, 21, 22 but nothing. Is my syntax
right? I think so, for I have been running test programs on byte
addressing word arrays, so that's all good. I'm going to upload the
entire code to
http://www.geocities.com/astro_fizzix/documents/AF_LIGHT2.txt
so if you want to take a look at the whole thing go there. I also
have a pic on my site(leave out everything after the x to visit) of
the circuit, but I probably won't do you much good because I've
change some of the buttons and connections. What is the deal???
rcB VAR W11
rcA VAR W12
value VAR WORD(10)
y VAR B21
x VAR B20
z VAR B0
oldpin VAR B4.LOWNIB
lowbytey VAR B2
highbytey VAR B3
Usually you should use the VAR WORD/BYTE syntax OR the VAR Wxx/Bxx
format, but not both. Are you sure you aren't overlyaing some variables
here?
Just looking at this part in the Stamp editor, the value variable is
consuming all but W0-W2. So you are overlaying almost all your variables
over value.
Does that help?
Al Williams
AWC
* Floating point math for the Stamp, PIC, SX, or any microcontroller
http://www.al-williams.com/awce/pak1.htm
> From: astro_fizzix [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=DHco-ak-5yRz8lAeYTHR-T007KN-l-kQsOe23JT8ehaC7BoAdv3O1y59YSDLFOLFtwelJdeOXueA8f1ZPavq]astro_fizzix@y...[/url
> Sent: Wednesday, December 12, 2001 9:51 AM
> Subject: [noparse][[/noparse]basicstamps] Re: Frustration
> It still doesn't work guys. I've tried the greater than thing, but x
> entire code to
But when the loop came around again, x had added two, so z = 2. z was made to
reset the array to zero values, but it was a 10word array. when x = 10, so did
z, which made: values(10) = 0; z should've equaled 4 at this point. the array
can only be address from 0 to 9, so the bs must've made W10 = 0, which was where
x was stored and reset it to 0! Thanks for all your help, I appreciate it!
stored into the EEPROM, and so I can write over the array. oldpin is set to zero
below the array, and it is overwritten by the array declarations at the
beginning. It's a complicated code, and I don't know FOR SURE if the whole thing
works, but I know my variables, and have gone through great pains to ensure a
short program and non-overlapping variables! The main problem I've been having
is that the program has been looping in that one spot, which I have remidied. If
I have any more problems, I'll let you guys know. And when I'm finished, I'll
give everyone an address to see the finished product!
I rewrote your loop using the predefined names,
And then summarized the actual changes.
I noticed that the IF THEN line still holds
the 19. I changed that.
This loop should exit at B20=20. (x=20)
I could not detect overlapping variables.
Regards peter
y VAR B21
x VAR B20
z VAR B0
value var word(10) 'W0-W9 or B0-B19
original fixed names chsnged variables
y = 20 B21 = 20 B21 = 20
x = 0 B20 = 0 B20 = 0
here3: here3: here3:
write y, value.lowbyte(x) write B21,B0(B20)
z = x B0 = B20 B0 = B20
y = y + 1 B21 = B21 + 1
x = x + 1 B20 = B20 + 1
x = x + 1 B20 = B20 + 1 B20 = B20 + 2
y = y + 1 B21 = B21 + 1 B21 = B21 + 2
value(z) = 0 B0(B0) = 0 B0(B0) = 0
B0(B0+1) = 0 B0(B0+1) = 0
pause 100 pause 100
IF x = 20 THEN snap if B20 = 20 then snap IF B20 = 20 THEN snap
goto here3 goto here3 goto here3
I spotted your error.
It is the line value(z)=0.
When x reaches 10, so does z,
But value(10) cleares B20 and B21, hence the loop
You should change it to value.lowbyte(z)=0
Regards peter
Van: peter verkaik [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=WiFcsJYvXYcsKv9NYar6Non2Dr9nsGLCVNGHHhp6jshTga1pOm7y93_JqWpK2FUkVIew2NhOJ19Vp-LB4XsrXg]peterverkaik@b...[/url
Verzonden: woensdag 12 december 2001 18:13
Aan: basicstamps@yahoogroups.com
Onderwerp: RE: [noparse][[/noparse]basicstamps] Re: Frustration
Regards peter
y VAR B21
x VAR B20
z VAR B0
chsnged variables
2
2
B0(B0+1) = 0
B0(B0+1) = 0
pause 100 pause 100
THEN snap
The change alone is not sufficient as value.lowbyte(20)=0
is executed before the IF statement, clearing B20.
So you must move that line up as in the code below.
Regards peter
original
y = 20
x = 0
here3:
z = x
y = y + 1
x = x + 1
x = x + 1
y = y + 1
IF x = 20 THEN snap
value(z/2) = 0 'divide z by two, if z is 0-18 then z/2 is 0-9
pause 100
goto here3
