Scaling voltage measurment cct.
Two series resistors. Voltage divider.
ACJacques
moparjody gravada:
> Dunno what happened to my last post?
> Anyways, what I want to do is measure a voltage using a similar
> circuit as is in
> http://www.parallaxinc.com/downloads/Resources/Stampworks/StampWorks_E
> xperiment_27.PDF
> This uses a national semi. Serial ADC to read in a variable voltage.
> This is for 5 volts, but the problem is, I want to read 12VDC.
> What is a quick and dirty way to scale this before putting it into
> the ADC?
> Thanks
> Jody
ACJacques
moparjody gravada:
> circuit as is in
> xperiment_27.PDF
> the ADC?
> Thanks
> Jody
circuit as is in
xperiment_27.PDF
the ADC?
Jody
Connect a pot across your 12VDC input and ground. Take the wiper of the pot
to the ADC input, and set the ADC input at 5VDC with a full 12VDC across the
pot. At full scale - 12VDC the ADC will think it is seeing 12V.
In the processing section of your ADC read routine, the output of the ADC
will appear as "result" or something similar. For instance
AD0 = result
Now then you have to increase AD0 until it equals 12 VDC.
AD0 = AD0 * 2.4
The Stamp can't handle a decimal so you have to trick it a little by writing
AD0 = 48*/2 ' This will give you the equivalent of AD0 * 24.
At this point your ADC output will be something like 12000 if you are using a
12-bit ADC. To get this to a usable value, write:
serout 16, N9600, [noparse][[/noparse]"Voltage = ", dec AD0/1000, ".", dec3 AD0]
This is the general approach. It you are using an 8-bit or 10-bit ADC then
the numbers will have to be adjusted accordingly. If I can be of further
help let me know.
Sid
Where I wrote 48*/2. change it to
AD0 = 240*/100
That will make it a bit more manageable.
Sid
jody.gallant@s... writes:
> the ADC?
Create a voltage divider with a precision (1%) resistors.
-- Jon Williams
-- Parallax (Author of "StampWorks")
Jody
--- In basicstamps@y..., Newzed@a... wrote:
> For Jody
of the pot
across the
the ADC
> AD0 = result
> AD0 = AD0 * 2.4
by writing
are using a
ADC then
further
> help let me know.
> Sid
Sid
use a zener diode connected to the positive point and a resistor to ground,
the connection point between the 2 will read the input voltage minus the
zener voltage this method gives higher resolution. For example a 1N4741 and
a 4.7K resistor to ground will give a range of about 10 to 15 volts.
KF4HAZ - Lonnie
> circuit as is in
> xperiment_27.PDF
> the ADC?
> Thanks
> Jody
