Pressure Transducer Sought
Can anyone recommend an inexpensive and readily available pressure
transducer for use in an automotive application. Ideally, it would
measure vacuum to about 25hg and pressure to about 30psi, with +/- 2%
precision or so, and produce a linear 0-5 volt dc output. I want to
use it with a Basic Stamp to measure vacuum and boost on a turbo
charged car. The vacuum reading is not as important as the pressure
reading, if there is a handy pressure only sensor out there. Thanks
in advance.
in advance.
will need to register to see the tech info. The equipment is not cheap tho,
it is designed for factories.
Tony
Sent: Monday, December 10, 2001 11:37 PM
Subject: [noparse][[/noparse]basicstamps] Pressure Transducer Sought
> in advance.
JOHN
>in advance.
>from the same email address that you subscribed. Text in the Subject and Body
the 140PC series of pressure
sensors. They're available as absolute, differential, gage, vacuum
gage/amplified. Very easy to implement with
an LTC1298 ADC. Cost varies, you may try Mouser, Newark or sometimes on E-bay.
Ben
> in advance.
nominal 0 to 5 VDC output. One that comes to mind is the MPX5700.
However, there are many in the range from 1.5 to 150.
I have found Newark (http://www.newark.com) to be a good source.
Peter H Anderson, http://www.phanderson.com
2%
> in advance.
0-5V across the full scale range, less a small offset. These are small
micromachined parts in plastic molded packages. They are intended for use
with clean air or water, and there are models that range up to 100 psig or
so. Forget about trying to get an absolute model number - it seems only the
gauge types are stocked. They are on the shelf at Allied Electronics.
Motorola has a nice selection brochure on their web site also.
I don't know how well the plastic barb pressure inlet will do with high
temperatures though. If you want a $20 solution, it may be worth working out
a way to keep it cool.
I'm not sure if these devices will handle vacuum, of if so how.
Chris
> in advance.
Motorola actually makes a pressure sensor specifically designed to measure
manifold pressure (MAP). The MPX4115A series works from 2.2 (vaccum) to 16.7
(just above ambient pressure). The key feature is that it is temperature
compensated and works from -4 to +125 deg C. It has built-in signal
conditioning and outputs 0.2 to 4.8 volts DC. Check out
http://e-www.motorola.com/brdata/PDFDB/docs/MPX4115A.pdf
Tim
In a message dated 12/10/01 4:39:35 PM, tomatlarge@y... writes:
<< Can anyone recommend an inexpensive and readily available pressure
in advance. >>
