a: synchronous comms and b:stopwatch function info needed
Hello all:
I am looking for info on two subjects
1: Synchronous comms between two stamps. I want to do this to get
high speed comms between two stamps. Reading the manual, both the
shiftin and shiftout commands set a clock pin to output. I would have
thought one command would output a clock pulse, the other would
receive it. Not so? This doesn't make sense to me. Can comms be
established this way?
2: Part of my app is a lap timer function. I have thought of doing
this with a stamp for the timer, and another to do everything else,
(hence the comm link above) but would prefer to use something more
accurate. I need to be able to reset the watch and restart it every
few minutes. Looking for 10 millisecond resolution. Any other
hardware I should be looking at?
Thanks in advance
Duncan Potter
Thanks in advance
Duncan Potter
No, the stamp SHIFTIN and SHIFTOUT are designed to function as the
Master in spi or microwire exchanges. The Stamp cannot function as a
slave, unless you bit-bang the exchange (slow, but do-able.)
Here are external event timer chips that work with the stamp:
http://www.al-williams.com/awce/pak7.htm
8 channels, 5 microsecond resolution
http://home.earthlink.net/~parkiss/tm1summ.txt
many functions, resolution to 1 microsecond in hours
http://www.phanderson.com/timer_1_2.html
10 microsecond resolution in one minute, or 1 milliscond in 1 hour
-- regards,
Tracy Allen
mailto:tracy@e...
http://www.emesystems.com
(im my case, a Basic Stamp2 and a SitePlayer). Can someone explain
the "bit-banging" technique? Speed is not critical for my
application.
Thanks!
Wayt
--- In basicstamps@y..., Tracy Allen <tracy@e...> wrote:
> >Hello all:
have
as a
else,
every
hour
> -- regards,
> Tracy Allen
> mailto:tracy@e...
>application.
>Thanks!
>Wayt
Hi Wayt,
There are examples of a bit-banged SPI master in BS1 app-notes 22 and
23. (The old BS1 does not have a built-in SPI command, so
bit-banging is the only way it can be made to talk with SPI devices.)
It is really very simple to bit bang either the master or the slave,
and you can make the BS2 a slave if speed is not the object. On the
master device, you put a 8 bits of data out in succession on one pin,
while on a second pin you generate a series of pulses. On the slave
device, you listen for the series of pulses, and in conjunction with
each pulse, you read one bit of data and assemble it into a byte at
the end. The master usually also generates a "Chip select" signal
on a third pin, and the slave uses that as a signal to start
listening. You have to decide where to sample the data in relation
to the pulses and the chip select--this is why there are several
flavors of SPI.
When you do this by bit-banging on a BS2, the exchange of 8 bits of
data is going to take something like 5 to 10 milliseconds. In
contrast, the serout command transfers the whole 8 bits in about 0.5
millisecond. Some SPI masters and slaves can operate very
fast--microseconds. The BS2 will not be able to listen as a slave to
anything except something that you can program yourself to be slow.
-- regards,
Tracy Allen
mailto:tracy@e...
