Dc motor controll w/bs2sx
I have sent two messages inorder to find out how to program the bs2sx
to control two dc motors and as yet have not seen any resonse.
""are there anyone one out thier who has worked on this type of a
program or am i trying to find infor on the wrong group""
mybe i am the only one working on this type of project??
Please help!!
Op
Please help!!
Op
these servos or ordinary DC motors? In your last message (I only saw 1)
you mention servo motors, but it wasn't really clear what you wanted to
do. The R/C receiver outputs a pulse that is probably about 1.5mS long
for the servos to be in center position. You could simulate this with
the BS2SX's PULSOUT command. Is that what you are asking?
Al Williams
AWC
* Control 8 servos at once
http://www.al-williams.com/awce/pak8.htm
> From: kuek24523 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ba48HRKjfVfPrIDVk3uClDzm3dMscTf9aOBczvN_xO3Owea6Ee3xv-by09-jB9OCnpDAdOw3]ops-@p...[/url
> Sent: Friday, December 07, 2001 8:55 AM
> Subject: [noparse][[/noparse]basicstamps] DC MOTOR CONTROLL W/BS2SX
> I HAVE SENT TWO MESSAGES INORDER TO FIND OUT HOW TO PROGRAM THE BS2SX
> TO CONTROL TWO DC MOTORS AND AS YET HAVE NOT SEEN ANY
> RESONSE. ""ARE THERE ANYONE ONE OUT THIER WHO HAS WORKED ON
> THIS TYPE OF A
> PROGRAM OR AM I TRYING TO FIND INFOR ON THE WRONG GROUP""
> MYBE I AM THE ONLY ONE WORKING ON THIS TYPE OF PROJECT??
> PLEASE HELP!!
> OP
> from the same email address that you subscribed. Text in the
off/on control?
forward/reverse?
variable speed?
What device(s), if any, do you have planned for between the Stamp and the
motors?
What are the motor characteristics (volts, amps)?
Daniel
> From: kuek24523 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=RPAokijxfVC7s4M0-T8intGJacSJU89iwQNoFuKYHVSVQyAajxbD6nacAttanLu1TSyTg5TTm6k]ops-@p...[/url
> Sent: Friday, 07 December 2001 09:55
> TO CONTROL TWO DC MOTORS AND AS YET HAVE NOT SEEN ANY RESONSE.
> ""ARE THERE ANYONE ONE OUT THIER WHO HAS WORKED ON THIS TYPE OF A
> PLEASE HELP!!
> OP
_________________________________________________________
Do You Yahoo!?
Get your free @yahoo.com address at http://mail.yahoo.com
Why not fine tune it and try again...
Now, what exactly are you trying to accomplish?
CL
> PLEASE HELP!!
> OP
Thanks for your reply to my e-mail. I have had a very hard time finding out
how to program the BS2sx to run the robot I built.
Here is the story on what I am trying to do. I have a robot that runs on
two Wiper Motors that run about 3 amps per motor. Currently I am operarting
the robot by a R/C system which is connected to a Basic Stamp !.
The R/C system (same as used in model airplanes) sends a signial to run
servos but rather than the output of the R/C receiver going to two servos
the two channels go to the Basic Stamp I which converts the servo inputs to
be used to run the DC motors.
The setup for the Basic Stamp 1 is the stamp is connected to a UNL2003A
driver which is connected to the 4 relays whch control the voltage to the DC
Motors. This all works very well but now comes the problem.
I have installed a second stamp to the system witch is the BS2sx. The
reason I installed the second stamp as I needed more I/O ports for other
operations. One of the operation is to run the robot byway of IR sensors.
I developed a program that will work with my Boe-Bot that have 2 servos as
the driving motors so what I want to do is instead of running the Basic
Stamp byway of the R/C receiver, I want to run it byway of the BS2sx.
The way I have the BS2sx connected to the BS1 is as follows:
The servo program of the BS2sx runs the servo output through P12 and P13
(which run to servso motors)
to P6 and P7 of the BS1. P6 and P7 were originally connect from the R/C
receiver.
If I cant find a program that will let me use to two stamps then I would
like to find out that I could control the robot motors using the BS2sx
connected to the UNL2003A which are connected to the relays. The relays
would be connect as follows:
Relay 1 Enable left motor
Relay 2 Enable right motor
Relay 3 Forward/Reverse left motor
Relay 4 Forward/Reverse right motor
Can you please help,
op
Sent: Friday, December 07, 2001 10:01 AM
Subject: RE: [noparse][[/noparse]basicstamps] DC MOTOR CONTROLL W/BS2SX
> Lots of folks here work on motors. However, what are the specifics? Are
> Al Williams
> AWC
> > From: kuek24523 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=zVBw-rFzSwMdf1ipB8FPvLBHGmT669WdoZf0EI4X7wGAGpaRoZuMmREd_o_bvvGwVQcLNApkXhg]ops-@p...[/url
> > THIS TYPE OF A
> > PLEASE HELP!!
> > OP
havn't explained your project's
hardware and goals or your experience in programming. I found these six lessons
helpful in starting:
http://www.stampsenclase.com/downloads/wam1.pdf
http://www.stampsenclase.com/downloads/wam2.pdf
http://www.stampsenclase.com/downloads/wam3.pdf
http://www.stampsenclase.com/downloads/wam4.pdf
http://www.stampsenclase.com/downloads/wam5.pdf
http://www.stampsenclase.com/downloads/wam6.pdf
> PLEASE HELP!!
> OP
Do You Yahoo!?
You need some sort of motor control between the stamp and the motors.
Examples are the MotorMindB, the Mondotronics H-bridge, or any of the
Allegro H-bridge modules.
Your code will depend on which motor control method you use. Have you looked
on the Parallax web site for any suggestions?
It seems that you have an functioning robot, basically:
<RC receiver> ---> <Stamp1> ----> <relays> ----> <motors>
Thus, the Stamp1 is already properly interpreting RC signals.
Is this what you want, replacing the <RC receiver>?
<Stamp2> ---> <Stamp1> ----> <relays> ----> <motors>
In other words, just have the Stamp1 still run the motors, and use the
Stamp2 to provide the command signals instead of the <RC receiver>.
Application Note 4 for BASIC Stamp I, provides some guidance in generating
the signal to drive a RC servo; could not this be adapted to command the
Stamp1 in the place of the RC receiver?
Otherwise, just wire the existing UNL2003A to the Stamp2 in place of the
Stamp1. Move the Stamp1 code to the Stamp2 (watching for the occasional
differences in the command sets), and drive the '2003A from the Stamp2.
Perhaps I've missed something.
Daniel
> From: O.P. Stancer [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Xnr43KGPp0SlnZp7wct-LUhgTbExMIUspRIJV3GDZbEwZ6qyIHXjFiah1WeCPXDsn-X5y7f6yvzy4w]ops-@p...[/url
> Sent: Friday, 07 December 2001 11:24
> Subject: Re: [noparse][[/noparse]basicstamps] DC MOTOR CONTROLL W/BS2SX
> Hi Al,
> finding out
> operarting
> inputs to
> voltage to the DC
> servos as
> receiver.
> op
Do You Yahoo!?
Thanks again for your reply. You are correct execpt that I want to continue
to use the RC receiver when I want to operate Radio Controll but then be
able to switch the RC receiver out are put the BS2sx in its place thru a
switch, then I can switch my two systems in and out at will.
The only thing that is stopping me is how to wright the SEROUT command for
the BS2sx and the SERIN command for the BS1. I have read the book on it but
still have not made it work.
Can you tell me what the full command would be for SEROUT in the BS2sx
program and the full command for SERIN for the BS1?
op
Sent: Saturday, December 08, 2001 11:29 AM
> Op,
> Regards,
> Daniel
> > From: O.P. Stancer [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=OQRXGs9no1J4149c6Uqb8Nmn_8v2RxoGJcrOnXzn-3UoxqTcC5TPysYGYSHnmW5nHR2x5bWHMw]ops-@p...[/url
> > Hi Al,
> > finding out
on
> > operarting
servos
> > inputs to
> > voltage to the DC
sensors.
> > servos as
> > receiver.
> > op
> Do You Yahoo!?
op
> Op,
> Regards,
> Daniel
> > From: O.P. Stancer [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=7Czkd9XAmpN_iTqBhx5eap2uHdsvilID1-TVRHZpWnyIF5YYb4Xr3WW9IuCWvozgqPB6Jsqe1TCZK7Y]ops-@p...[/url
> > Hi Al,
> > finding out
on
> > operarting
servos
> > inputs to
> > voltage to the DC
sensors.
> > servos as
> > receiver.
> > op
> Do You Yahoo!?
If you want to have either RC receiver OR Stamp2 controlling, then I would
do something like:
<Stamp2>
V
<RC Receiver>
> <Switch>
> <Stamp1> ...
This way, there would be no changes required in the Stamp1 software. Use
something like PULSOUT in the Stamp2 to allow it to pretend to be the RC
receiver--see BASIC Stamp I App Note 4.
If you want to have both RC receiver and Stamp2 simultaneously active, you
could still have the Stamp2 just generate the RC-style pulses and then mix
them in the Stamp1.
Alternatively, you could set up the serial communications that you
mentioned.
To prevent damage to your Stamps, you SHOULD to review the principles of
BASIC Stamp I App Note 14 "Networking multiple Stamps", and also the BASIC
Stamp II manual treatment of SEROUT, especially the section "Networking with
Open Baudmodes".
You would also want to work out the communication protocol--how the Stamp2
tells the Stamp1 to operate the motors, whether the communication is one-way
or if the Stamp1 sends information back to the Stamp2, etc. You will also
have to deal with issues regarding the synchronization of the two
processors, timeouts, etc--perhaps just have the Stamp2 continuously send
the commands to the Stamp1, and have the Stamp1 synch up on a special
lead-in character of the transmission.
To your specific question, from my reading of the book, I think the
following should let the Stamp2 send the letter 'A' to the Stamp1 ( 'x'
stands for the pin you have chosen on each Stamp to connect) using 8-bit
characters, no parity, 1 stop bit:
Stamp2 (transmitting): SEROUT x,16780,[noparse][[/noparse]"A"]
Stamp1 (receiving): SERIN x,N2400,b2
Be aware of the fact that program execution is blocked until the SERIN
completes. You may also need to explore pacing on the Stamp II.
I'm not an expert on Stamp serial communications--maybe someone else on the
list might chime in here, or you could check out Jan Axelson's book, "Serial
Port Complete" (http://www.lvr.com/spc.htm) for a lot of information on
serial Stamp networks.
BTW, be aware that the parameters on the SERIN / SEROUT have significant
differences between Stamp I & II.
Daniel
> From: O.P. Stancer [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=z2jfZ-5mBW6SoUmtvYKW1yGWKWYnNRfPERta8MMkc8A5draR8hX5pZEDEZava4GMOEC9MYeY]ops-@p...[/url
> Sent: Saturday, 08 December 2001 14:56
> Daniel,
> to continue
> command for
> book on it but
> op
> From: "D. Daniel McGlothin" <ddm_stamps@y...>
> > Op,
> generating
> > Regards,
> > Daniel
> > > Hi Al,
> > > finding out
> on
> > > operarting
> signial to run
> servos
> > > inputs to
> a UNL2003A
> > > voltage to the DC
> BS2sx. The
> ports for other
> sensors.
> > > servos as
> the Basic
> P12 and P13
> from the R/C
> > > receiver.
> then I would
> the BS2sx
> The relays
> > > op
Do You Yahoo!?
Thanks for all the great info....I had already programed the BS2sx to
pulsout and had connected the BS2sx to my BS1 and damaged two ports of the
BS1. I had not used the command SEROUT at that time.
I will read the manual regarding networking before I do it again...
I will let you know how I make out Daniel.
Thanks op
Sent: Saturday, December 08, 2001 3:45 PM
> op,
> do something like:
> <Stamp2>
V
> <RC Receiver>
> <Switch>
> <Stamp1> ...
> them in the Stamp1.
> mentioned.
with
> Open Baudmodes".
one-way
the
"Serial
> Regards,
> Daniel
> > From: O.P. Stancer [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=71QUpx57ErZqP3X3Ln7ANtHs6dZOAeFFn9q_EqqlzGQ8zLNfEuvvbyEsXlIOS_spIa4eXpoOB0WYtQ]ops-@p...[/url
> > Daniel,
> > to continue
> > command for
> > book on it but
> > op
> > > Op,
> > generating
the
the
occasional
Stamp2.
> > > Regards,
> > > Daniel
> > > > Hi Al,
> > > > finding out
runs
> > on
> > > > operarting
> > signial to run
> > servos
> > > > inputs to
> > a UNL2003A
> > > > voltage to the DC
> > BS2sx. The
> > ports for other
> > sensors.
> > > > servos as
> > the Basic
BS2sx.
> > P12 and P13
> > from the R/C
> > > > receiver.
> > then I would
> > the BS2sx
> > The relays
> > > > op
> Do You Yahoo!?
Just to be complete, I suppose I should have mentioned that the protections
discussed for serial networking the Stamps should be considered when
interconnecting them for PULSOUT as well. Essentially, you need to be
concerned about potentially shorting +5VDC to Ground through the pin(s).
Daniel
> From: O.P. Stancer [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=1NBKck9Mzs9No9aq4RNZ-7rSE-L2iKWEsz2ENgrPd4hzbhPhpoU3d1svlOF4pAd1kgAZvKKqfgs]ops-@p...[/url
> Sent: Saturday, 08 December 2001 17:07
> Daniel,
> ports of the
> Thanks op
Do You Yahoo!?
