LCD + keypad + PAK 1 + PAK 8 =Frequency Generator
I am using a 16X2 LCD and a keypad to input data. I need to be able to input
6 digits and store them so that I can enter and display 100,000 to 1 and
everything in-between. I am trying to use the RAM present in the LCD to store
the digits then convert them to the correct total after the entry has
terminated. I am keeping track of the number of digits entered then going
back and scaling the digits that are stored in the LCD memory. Example:
digits entered 123456 which is 6 digits so the leftmost digit is then
multiplied by 100,000 then added to the next digit which is multiplied by
10,000 etc.. I then have the total value entered and displayed correctly on
the LCD. I am using Al Williams Pak 1 to compute 1/x and also the PAK 8 to
output specific frequency pulse trains. The number entered and displayed is
frequency which is then used to calculate pulse width (period). Can anyone
point me to some links or example code that will help me accomplish this
task. Thanks!
AZEASI
task. Thanks!
AZEASI
I don't have specific code for you, but I do have a few observations you
might find helpful. Your keypad code would be simpler if you do it like
this (this is just pseudo code):
PAK1_X = 0
Loop:
key = read_key ' returns 0-9 or ENTER
if key = ENTER then done
PAK1_X=PAK1_X *10 ' load Y with $82200000 and call MULT
PAK1_X=PAK1_X + key
goto Loop
Done:
' PAK1_X now has your number
Compute recip
Convert to PAK-8 units (5uS or whatever you have it set to)
Divide by 2 ' 50% duty cycle
Convert to integer
Read value and send to PAK-8 ' Since 50% send same number for on and
off time
There are a few items in the document library
(http://www.al-williams.com/awce/doclib.htm) that might help:
http://www.al-williams.com/awce/paklib.htm - Using the PAK library
http://www.al-williams.com/awce/pak1bas.htm - Simple PAK-I program
http://www.al-williams.com/awce/paktemp.htm - Measure temp with a PAK-I
http://www.al-williams.com/awce/servo_bot.htm - PAK-VIII example (with
servos, so not quite what you are doing).
Good luck!
Al Williams
AWC
* Easy RS-232 Prototyping
http://www.al-williams.com/awce/rs1.htm
> From: azeasi@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=CI1h58GQEN4DrRDDZm7W4F4oVvELDK31BOXij6FnDYAUKCIPfNobis4m3RM-sqraAg4F3b3A]azeasi@a...[/url
> Sent: Thursday, December 06, 2001 11:24 PM
> Subject: [noparse][[/noparse]basicstamps] Re: LCD + keypad + PAK 1 + PAK 8
> be able to input
> 100,000 to 1 and
> the LCD to store
> entered then going
> memory. Example:
> multiplied by
> the PAK 8 to
> and displayed is
> accomplish this
> task. Thanks!
> AZEASI
> from the same email address that you subscribed. Text in the
Thanks for the reply. I am unclear on the pseudo code you provided. What is
the: PAK1_X=PAK1_X *10 ' load Y with $82200000 and call MULT segment do.
Where does the $82200000 come from? I am definitely interested in making the
code simpler. Thanks!
AZEASI
The $82200000 is from fconvert (on the PAK-I disk). You put 10 in and it
will tell you that 10 is $82200000 in the PAK-I's world.
Same thing for the next line, you'd add the integer key to PAK1_X which
would really require you to move X to Y, load X with the integer,
convert to floating point, and then call Fadd.
Al Williams
AWC
* Floating point math for the Stamp, PIC, SX, or any microcontroller
http://www.al-williams.com/awce/pak1.htm
P.S. I just got finished cleaning up the PDF versions of most of the PAK
manuals. If you were getting PDF errors or missed having bookmarks, go
get the latest from the site!
> From: azeasi@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=V8rlxhqmCP3Dr2cegYWJ1aCk5j5bpIJlFdsEzzdMQ-M-nVrladR3anYjceGkwCx_ebS3FQ]azeasi@a...[/url
> Sent: Friday, December 07, 2001 8:04 PM
> Subject: Re: [noparse][[/noparse]basicstamps] Re: LCD + keypad + PAK 1 + PAK 8
> Al
> provided. What is
> MULT segment do.
> AZEASI
Is it possible to get 1 us pulsewidths out of the PAK 8? Could a special
version be made available if some minimum order was placed? I only need 4
channels or less.
AZEASI
