RC Flight Data Recorder Help
I would like to make a Flight Recorder for my R/C helicopter. We have had
quite a few guys crash from "lockouts" and cant figure out what happened.
Is this possible to do? Here is what I would like it to do:
1. Record all inputs to the servos and make info available to download to
PC and analyze later on
2. Record Radio glitches
3. Track battery power and show if it peaks, slumps or goes dead.
It would be nice to see this information over a time line so you can
analyze it later ans see that a spike in battery caused a glitch, etc. Is
this possible, and can anyone help me with resources on getting started?
Matt Johnson
Matt Johnson
suddenly and for so short a duration, that the stamp chip would likely miss
it. Next, would be memory requirements as to how many samples per second you
want to store, and then how much memory you need to hold that data. Then you
would multiply that by the number of channels for the things you want to
monitor. That would give you an idea as to how much memory you need.
The problem is EEprom or Flash RAM may be too slow to receive this much data
as you do need it to be non volatile as well?
In RC, the transmitter sends a series of pulses, one for each channel in
sequence, pauses for a tiny bit and repeats the process. The width of the
pulse tells the server how much to move left or right. Usually 1.5 ms pulse
is center and 1 ms is full right and 2 ms is full left or vice versa. The
Receiver simply uses a simple circuit to decode the pulses and send them to
their appropriate servo channels. You would need to tap into this main
signal going to the decoder and monitor it. But then what are you wanting to
monitor and how much RAM do you need to do it.
From my calcs, you'd probably need something like 2 to 6 gigabytes of
datastorage to hold several minutes of information, if you want detailed
coverage, so maybe a 2.5 inch HD might work, or lots of flash ram, maybe
using the one wire large capacity chips in series would do. But at the
sampling rates you may still miss glitches, so the microntroller would need
to be really fast, maybe a BS2sx, but probsbly something faster even.
From what you stated in your message, it sounds like radio interference
from some other source. First you need to eliminate the other potential
sources, such as other flyer's turning on their radios on the same
frequency. Switch to FM (for rc choppers you should not be using AM at all).
Get a scanner for RC frequencies, and monitor all the channels your
interested in to see which ones have signals on them (eg, construction site
cranes being operated by radio control, warehouse overhead lift operated by
radio). If you find some, avoid those channels. You may find that someone is
running RC cars or boats down the street on the same channels you are
(instead of car's on one set, and planes on another).
Lockouts usually mean someone turned on their radio on the same channel
someone else is using jamming out the signal in the receiver with
contradicting pulses. I would get a scanner or build a scanner to monitor
the channels I am interested in. Now this would be a better use for a Stamp.
You could maybe get a receiver, and several crystals for the channles your
interested in, setup a crystal switchin circuit, so you can change channels
programatically, and hook into the decode input circuit to monitor the pulse
trains and/or RF signal strength. Then display and or print that out. Using
a printout saves RAm as you don't have to store the info in precious memory
(Stamps don't have a lot of this).
Anyway, that's my two bits worth.
Good luck
Earl
From: Matt Johnson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=iHgXUxakd4C7MhwpSYmu_9dtvLkFovmO2EinXnND-K0OpL50ZaX_RuHGGtXRWxgsp8z9kqUqXA]matt@m...[/url
Sent: Saturday, December 01, 2001 12:22 AM
Subject: [noparse][[/noparse]basicstamps] RC Flight Data Recorder Help
Matt Johnson
generate a huge amount of data. probably the better way to do it would be to
analyze every pulse received by the radio and if a problem is found then log
the data that is bad and maybe when that bad stream of data began.
http://www.inetport.com/~davisele/fc.html
Richard
Sent: Saturday, December 01, 2001 12:21 AM
> Thanks,
> Matt Johnson
much HD space. We are flying PCM by the way, not FM or AM. We have had
these lockouts at different fields with no people flying, so I am not sure
about interference. Common lockouts for RC Heli's is metal on metal
vibrating or other airframe type problems. I was thinking of trying to
trap those. We have also thought that maybe it was a battery suddenly
dying or a switch short circuiting because the heli that locked out this
last time had failsafe set to put throttle to idle and when it locked out
it didnt go to idle making us think that maybe it didnt loose frequency
since it didnt go to failsafe... Would it be more possible instead of
logging to just record 'glitches' and show the time of the last glitch or
something like that?
Does anyone have schematics to build a Spectrum analyzer like you were
talking about at the end? that would be nice to have regardless. I think
the RC channels for helis are 75mhz...
- Matt
On Sat, 1 Dec 2001, Earl Bollinger wrote:
> Yes it's doable. But the problem is spikes in voltage (glitches) happen so
> Good luck
> Earl
> From: Matt Johnson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=66suwgxnwCdzTWEGmJoJubEKQIBb3mPn-Rz-ihqM0Wd2gUAXBebIGjqD0r1feHpk9jucyQ]matt@m...[/url
> Thanks,
> Matt Johnson
Nice site! It is neat to see someone who is doing stamp/electronics
projects with RC Helicopters. That night blade project has got to be the
coolest. The link for your 'Flight Data from my on-board computer data
logger' seems to be broken though. I would like to see that. does it do
what I am talking about? I am sure you have already thought out the
scenerio that I proposed.
Also, where is the fly-by-wire project? I didnt see it in your list?
- Matt
On Sat, 1 Dec 2001, Richard Friedrich wrote:
> It would be easy to change my fly-by-wire system . . . But you would
> Richard
> From: "Matt Johnson" <matt@m...>
> > Thanks,
> > Matt Johnson
with all that metal to metal contact going on.
In my experiences, I always use a new on/off switch, I check it out
carefully before I do that even.
The servos are new, and tested carefully as well. I build my own battery
packs, as the store bought ones
tend to be sloppily made as well. I run the receiver off a separate battery
pack from the servos, I put in diodes across each cell, so I a cell
dies/opens the batter pack will still work at reduced volatage, especially
important if you use retracts in a airplane. If a servo stalls it doesn't
kill the receiver. If possible the receiver should be able to operate down
to 3 volts, important if you lose a cell in flight. Watch out for the six
volt packs some receivers and servos act flaky at the higher voltages, but
six volts can be a plus too.
If you have a lock out and crash hard, chunk the flight pack, as the crystal
or the ceramic filters may be cracked, causing intermittent operation, or a
coil may be damaged. I am amazed at the large number of people who try and
reuse radio equipment after a crash, it always leads to more grief. I'd
rather replace stuff than having to replace and straighten all those little
metal parts after a crash. It's a lot of hassle getting the rotor head and
such all working again just right. The radio is cheaper. That leads to
another point, the radio gear could be bad, or caused to go bad. The
transmitter could be defective. I had a transmitter once with a bad joystick
pot flake out if you happened
to move to just the right spot.
Glitch checking is a definite possiblity, but the system has to be
readable after a crash. So you have to make it survivable. I have no scanner
schematic, the last scanner I built, used a Airtronics receiver, and several
crystals for the frequencies I wanted to monitor. I would use the MCU to
swap out Xtals and check each channel for a signal.
I put in LED's to light up if a signal was detected. I used the decoder to
check the servo/channel pulses. Another approach would be to use several
receivers and just check the signal for each one. Receivers are pretty
economical nowadays. Many years ago when I was the QC guy at Proline (if
anyone remembers them), this stuff was really expensive. Servos were
repairable way back then, but today they are all throwaway items. The
scanner's nice as a MCU could output data to a serial port to a lap top
where you could run a VB program to store the data on a HD. You could even
monitor your own transmitter signal to see what it;s doing.
A glitch detector could be a op amp with it's threshold set slightly above
VCC (out of the noise) and you watch for the trigger (maybe a latch to catch
it, if it's really fast). Another op amp can be set to look for VCC going
down as well, in case you have a bad connection or a intermittent short
someplace.
Sent: Saturday, December 01, 2001 10:59 AM
Subject: RE: [noparse][[/noparse]basicstamps] RC Flight Data Recorder Help
> Thanks Earl, that really helps. I didnt realize that logging would take so
> - Matt
happen so
miss
you
you
data
in
the
pulse
The
to
wanting to
need
interference
all).
site
by
someone is
monitor
Stamp.
your
channels
pulse
Using
memory
> > Good luck
> > Earl
> > From: Matt Johnson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=AygBSrU4Zsckp5KLgua8LNSb-5_vXKizt7BmqgdF3fXZvZ1v2RKPm06lKukPVZp6AhAErA]matt@m...[/url
had
happened.
to
Is
> > Thanks,
> > Matt Johnson
and
and altitude
the fly by wire is part of the uav project
http://www.inetport.com/~davisele/uav.html
have you checked out the bc-6 glitch counter?
richard
Sent: Saturday, December 01, 2001 11:08 AM
Subject: Re: [noparse][[/noparse]basicstamps] RC Flight Data Recorder Help
> Richard,
> - Matt
be to
log
> > Richard
had
happened.
to
Is
started?
> > > Thanks,
> > > Matt Johnson
and
www.rchelicopters.org which has a reviews area. I will check it out.
- Matt
> the flight data is broken but it was not what you wanted - it was airspeed
> and altitude
> richard
> > Richard,
> > - Matt
> be to
> log
> > > Richard
> had
> happened.
> to
> Is
> started?
> > > > Thanks,
> > > > Matt Johnson
> and
I am curious how you put a diode across each cell in the battery pack such
that if a cell dies the battery pack continues to operate at a reduced
voltage. If the diode you use is forward biased it will drain current from
the battery cell. If it is reversed biased it will not be conducting any
current. open ckt. Please explain, tnx Steve.
Sent: Saturday, December 01, 2001 10:28 AM
> In my many years of RC'ing, helos were always pretty picky about RF noise,
battery
crystal
a
little
joystick
scanner
several
above
catch
> someplace.
so
sure
out
> > - Matt
> happen so
> miss
second
> you
Then
> you
to
much
> data
channel
> in
> the
> pulse
> The
them
> to
> wanting to
of
detailed
maybe
> need
> interference
potential
> all).
> site
operated
> by
> someone is
channel
> monitor
> Stamp.
> your
> channels
> pulse
> Using
> memory
> > > Good luck
> > > Earl
> > > From: Matt Johnson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=aqTXPrMPTBjHvE9AChjXnDuY-wTf1Ez0bSbGI1Y1_UYmrNmpySyyDjfMLa5y-KmL-A6c0A]matt@m...[/url
> had
> happened.
> to
> Is
started?
> > > Thanks,
> > > Matt Johnson
> and
and
The Basic circuit has a diode in series with the cell, and another diode
across the cell to the end of the diode.
Sort of like this:
Cell Diode
diode *
Thus the series diode blocks the flow back into the cell, and if a cell
opens the outer diode allows
power to still flow through the pack. If a cell shorts, it could block the
flow if it reverses, or still let current through.
Sorry, for taking so long, I had to open up a pack to see the circuit again.
I forgot about the other diode.
Anyway, I hope the asterisks line up vertically.
Sent: Sunday, December 02, 2001 12:34 AM
> Earl,
> From: "Earl Bollinger" <earlwb@w...>
noise,
> battery
especially
doesn't
down
six
but
> crystal
> a
and
> little
and
> joystick
> scanner
> several
to
even
> above
> catch
going
> > someplace.
take
> so
> sure
this
> out
frequency
> or
think
> > > - Matt
> > happen so
likely
> > miss
> second
> > you
> Then
> > you
want
> to
> much
> > data
> channel
> > in
of
> > the
ms
> > pulse
versa.
> > The
> them
> > to
main
> > wanting to
> of
> detailed
> maybe
the
would
> > need
even.
> > interference
> potential
at
> > all).
construction
> > site
> operated
> > by
> > someone is
are
> channel
> > monitor
a
> > Stamp.
channles
> > your
> > channels
the
> > pulse
out.
> > Using
> > memory
> > > > Good luck
> > > > Earl
> > > > From: Matt Johnson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=-g1cmaXPW62goPjL5NVGp9pD2qmtHEDJuetHUZPZaptixSaZv3nPgTym0NNLfi7bjlzuBFH1hTE]matt@m...[/url
have
> > had
> > happened.
download
> > to
etc.
> > Is
> started?
> > > > Thanks,
> > > > Matt Johnson
Subject
> > and
Subject
> and
and
overwriting previous data and have it end upon a trigger from say an
impact sensor. Then you would have the previous minute or so of data to
view.
Difficult problem to isolate as I have been on the "I don't have it" end
of the transmitter as well.....
Good luck,
Dale Harwood [noparse][[/noparse] N4VFF ]
internet> dale@h...
ax.25> n4vff@n4vff.#cha.tn.usa.noam
#include <std_disclaimer.h>
