Downloaded to where?
Thanks to all for the help in getting my BS2SX working.
I'm using the windows stamp editor, v1.2
When I download and run a program, is it being burned into the EEprom?
If so, should I worry about ruining the EEPROM, burning it too many times?
What tools are available to query the memory and find out exactly what
bytes are stored where?
Does Parallax have a layout of the memory space for the BS2SX?
Thanks again for the help,
Art
Art
tad
Sent: Friday, November 30, 2001 8:55 PM
Subject: [noparse][[/noparse]basicstamps] Downloaded to where?
> Art
->From: Doug Heckaman [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=XTcXtiwWCBwDcEds44cqPlze-MtVVjk3oUC9NlexnMjdv0wIQKjmjxXEfbRRWDggh59OQm3-]tad@h...[/url
->Sent: Friday, November 30, 2001 9:00 PM
->To: basicstamps@yahoogroups.com
->Subject: Re: [noparse][[/noparse]basicstamps] Downloaded to where?
->I know that the epprom can be writen 10,000,000 times.
->tad
->From: Art Burke <pianomanab@s...>
->To: <basicstamps@yahoogroups.com>
->Sent: Friday, November 30, 2001 8:55 PM
->Subject: [noparse][[/noparse]basicstamps] Downloaded to where?
->> Thanks to all for the help in getting my BS2SX working.
->> I'm using the windows stamp editor, v1.2
->> When I download and run a program, is it being burned into the EEprom?
->> If so, should I worry about ruining the EEPROM, burning it too
->many times?
->> What tools are available to query the memory and find out exactly what
->> bytes are stored where?
->> Does Parallax have a layout of the memory space for the BS2SX?
->> Thanks again for the help,
->> Art
->> To UNSUBSCRIBE, just send mail to:
->> basicstamps-unsubscribe@yahoogroups.com
->> from the same email address that you subscribed. Text in the
->Subject and
->Body of the message will be ignored.
->> Your use of Yahoo! Groups is subject to
->http://docs.yahoo.com/info/terms/
->To UNSUBSCRIBE, just send mail to:
-> basicstamps-unsubscribe@yahoogroups.com
->from the same email address that you subscribed. Text in the
->Subject and Body of the message will be ignored.
->Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Each program download is burned into the EEPROM but there should be
no worries. The EEPROM has a large number of rated burn cycles. If
you downloaded a program once every minute, 24 hours a day, the
EEPROM would fail after something like 70 years.
The Windows stamp editor includes a feature to view the contents of
the EEPROM. Press CTL-M to activate the memory map.
Jim
EEprom?
times?
what
> Art
I also notice that the adapter that I received from Parallax has an output
of 17 volts with no load. Is that too high? Is that why the one chip on
the CPU DIP
gets very warm?
I thought that the input could be from 9 to 24 volts DC..
17 sounds a little high...
This stuff is fun, and thanks for the help guys!
Art
->From: n7zfi@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=TEh3A8EM_ErXs1eO2wYEzstIqCz13iKCxR1rDlXQjsu3h9scE7joomfkXXg0ppkQtVjC46Un6IM4]n7zfi@a...[/url
->Sent: Sunday, December 02, 2001 9:41 AM
->Subject: [noparse][[/noparse]basicstamps] Re: Downloaded to where?
->Art,
->Each program download is burned into the EEPROM but there should be
->no worries. The EEPROM has a large number of rated burn cycles. If
->you downloaded a program once every minute, 24 hours a day, the
->EEPROM would fail after something like 70 years.
->The Windows stamp editor includes a feature to view the contents of
->the EEPROM. Press CTL-M to activate the memory map.
->Jim
->EEprom?
->> If so, should I worry about ruining the EEPROM, burning it too many
->times?
->what
->> Art
rated at 9 volts
Sent: Sunday, December 02, 2001 2:11 PM
Subject: RE: [noparse][[/noparse]basicstamps] Re: Downloaded to where?
> Thanks for all the help, Jim.
> the CPU DIP
> gets very warm?
> Art
> ->From: n7zfi@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=wOkcljUSd0Aw2lTjuZcUXVM-4keq_4N1aPuFiMOFtoqWiHeHoW6jm2V6LsxVZHtYu2jPzIUk2Mn5]n7zfi@a...[/url
> ->Art,
> ->Jim
> ->EEprom?
> ->times?
> ->what
> ->> Art
The 9 volts are obtained a full rated load.
The this is to the fact that the power supplay has an internal
impedance.
Also remenber that that DC voltage is function of the AC input.
The rated DC voltage is normally specified at nominal AC voltage
(120 VAC, 60 hz in the US)
Albert Catano
--- In basicstamps@y..., Doug Heckaman <tad@h...> wrote:
> Same with mine power supply. I dont know what is with that because
it is
> rated at 9 volts
> To: <basicstamps@y...>
an output
chip on
> > the CPU DIP
> > gets very warm?
> > Art
> > ->From: n7zfi@a... [noparse][[/noparse]mailto:n7zfi@a...]
> > ->To: basicstamps@y...
> > ->Art,
should be
If
contents of
> > ->Jim
> > ->EEprom?
too many
> > ->times?
exactly
> > ->what
> > ->> Art
> > -> basicstamps-unsubscribe@y...
Subject and
high.
If the power supply regulator chip has to drop 10 volts, that is way too
much.
That's why it's running so darned hot.
Art
->From: acatano2002@y... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=TzfiKQDS-G8BmXw04tJGGplUbHsinqh5UtD5FnV7n7DXQ27L78FRq0XmCUQlw3FMb6BfU01LljLTlfQqwQ]acatano2002@y...[/url
->Sent: Sunday, December 02, 2001 10:15 PM
->The 17 volts are refered as no load or open circuit voltage.
->The 9 volts are obtained a full rated load.
->The this is to the fact that the power supplay has an internal
->impedance.
->Also remenber that that DC voltage is function of the AC input.
->The rated DC voltage is normally specified at nominal AC voltage
->(120 VAC, 60 hz in the US)
->Albert Catano
->--- In basicstamps@y..., Doug Heckaman <tad@h...> wrote:
->> Same with mine power supply. I dont know what is with that because
->it is
->> rated at 9 volts
->> From: Art Burke <pianomanab@s...>
->> To: <basicstamps@y...>
->> Sent: Sunday, December 02, 2001 2:11 PM
->> Subject: RE: [noparse][[/noparse]basicstamps] Re: Downloaded to where?
->> > Thanks for all the help, Jim.
->> > I also notice that the adapter that I received from Parallax has
->an output
->> > of 17 volts with no load. Is that too high? Is that why the one
->chip on
->> > the CPU DIP
->> > gets very warm?
->> > I thought that the input could be from 9 to 24 volts DC..
->> > 17 sounds a little high...
->> > This stuff is fun, and thanks for the help guys!
->> > Art
->> > ->From: n7zfi@a... [noparse][[/noparse]mailto:n7zfi@a...]
->> > ->Sent: Sunday, December 02, 2001 9:41 AM
->> > ->To: basicstamps@y...
->> > ->Subject: [noparse][[/noparse]basicstamps] Re: Downloaded to where?
->> > ->Art,
->> > ->Each program download is burned into the EEPROM but there
->should be
->> > ->no worries. The EEPROM has a large number of rated burn cycles.
->If
->> > ->you downloaded a program once every minute, 24 hours a day, the
->> > ->EEPROM would fail after something like 70 years.
->> > ->The Windows stamp editor includes a feature to view the
->contents of
->> > ->the EEPROM. Press CTL-M to activate the memory map.
->> > ->Jim
->> > ->--- In basicstamps@y..., "Art Burke" <pianomanab@s...> wrote:
->> > ->> Thanks to all for the help in getting my BS2SX working.
->> > ->> I'm using the windows stamp editor, v1.2
->> > ->> When I download and run a program, is it being burned into the
->> > ->EEprom?
->> > ->> If so, should I worry about ruining the EEPROM, burning it
->too many
->> > ->times?
->> > ->> What tools are available to query the memory and find out
->exactly
->> > ->what
->> > ->> bytes are stored where?
->> > ->> Does Parallax have a layout of the memory space for the BS2SX?
->> > ->> Thanks again for the help,
->> > ->> Art
->> > ->To UNSUBSCRIBE, just send mail to:
->> > -> basicstamps-unsubscribe@y...
->> > ->from the same email address that you subscribed. Text in the
->> > ->Subject and Body of the message will be ignored.
->> > ->Your use of Yahoo! Groups is subject to
->> http://docs.yahoo.com/info/terms/
->> > To UNSUBSCRIBE, just send mail to:
->> > basicstamps-unsubscribe@y...
->> > from the same email address that you subscribed. Text in the
->Subject and
->> Body of the message will be ignored.
->> > Your use of Yahoo! Groups is subject to
