I haven't done it, but I have been told some people have used a "cue
cat" (the free scanner from Radio Shack) with a PAK-VI. As far as I
know, any of the "keyboard wedge" scanners should work with the PAK-VI
(although you might have to put it in raw mode if it doesn't "smell"
like a keyboard).
The stamp doesn't have what it would take to decode barcode reliably so
your best bet is to get a dedicated reader that puts out decoded ASCII.
Typically they are either wedge type readers that "wedge" themselves
between a keyboard and a CPU (or whatever) or they are a device that
outputs standard RS232. There may be some out there that talk ethernet.
Be aware that there are quite a few different codes out there. Typically
grocery stores and similar point of sale operations use UPC but they also
use Interleave 2 of 5 for their case coding. A lot of warehouses, the US
Military and others use Code 39. Blood banks and others use Codabar.
There is one code out that is being considered for driver licenses and
will be able to put a brief dossier into a 1.5" by 2.5" area. A good
book on the subject is "The Bar Code Book" by Roger Palmer, Helmers
Publishing Co, ISBN 0-1911261-02-8.
On Fri, 30 Nov 2001 20:50:16 -0000 r_wh@y... writes:
> Anyone done anything with bar code readers and collecting the
> information with a BS2?
> -- Rich
> from the same email address that you subscribed. Text in the
________________________________________________________________
GET INTERNET ACCESS FROM JUNO!
Juno offers FREE or PREMIUM Internet access for less!
Join Juno today! For your FREE software, visit: http://dl.www.juno.com/get/web/.
Is it fairly straight forward to read the ASCII that come out of a
reader into the BS2?
-- Rich
reliably so
ASCII.
ethernet.
Typically
they also
the US
Codabar.
and
good
> > -- Rich
> > basicstamps-unsubscribe@y...
Does anyone know where I might find a bar codes reader and wands for sale?
Is there a place that creates modules for experimenters or to create your own
stand alone stuff? I am interested in being able to scan a bar code and
import the information into a stamp or PC.
Have you performed a Internet search for "Bar Code Scanner", they are a lot
to look at, depending on the search engine and search criteria. http://www.semicron.com/scannertips.html has some info about them.
I would suggest a serial port model, as being the easiest to interface to.
But do you want undecoded barcode info or translated barcode info? Portable
or not portable?
Seems to be a lot of choices and prices to choose from.
A search on Ebay for "bar code reader", turned up a whole bunch for sale
too.
own
Tim
To UNSUBSCRIBE, just send mail to: basicstamps-unsubscribe@yahoogroups.com
Find some old, dead CueCats -- they can be hacked and used as a regular
barcode reader.
own
In a message dated 01/27/2002 7:23:38 AM Mountain Standard Time, earlwbollinger@a... writes:
<< Have you performed a Internet search for "Bar Code Scanner", they are a lot
or not portable?
too.
Using a QueCat and a PS2 port might work too! Que Cats were being given away
at Radio Shack and other stores for quite a while. Maybe they still give
them away.
Thanks for the ideas. Ebay does have a lot to look at.
try Datalogic.com they have a range of OEM CCD and Laser Barcode
reader modules as well as complete units.
They have serial units at TTL levels suitable for the Stamp, decoded
or undecoded, as well as scanner heads and decoder IC's.
Cheers
Col
for sale?
create your own
code and
> Tim
like a keyboard).
Al Williams
AWC
* Connect a PS/2 keyboard or mouse to your next Stamp project
http://www.al-williams.com/awce/pak6.htm
> From: r_wh@y... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=jik5-lzKcGgMMB9iCAlGczeay89uq426eUNO3__o7W0KYthew0dJtwq_NwHY83ewxhEDZEs]r_wh@y...[/url
> Sent: Friday, November 30, 2001 2:50 PM
> Subject: [noparse][[/noparse]basicstamps] Bar code readers
> -- Rich
> -- Rich
-- Rich
reliably so
ASCII.
ethernet.
Typically
they also
the US
Codabar.
and
good
> > -- Rich
Tim
or not portable?
too.
them away.
From: Trkeenan@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=x7YUEgJ6CxbEo6uplTlPeJ1vf8F7e-RqmOeoVv22jBfcWoVqoMcRmnYBe4-pEeGzzJi4tyPXBQ]Trkeenan@a...[/url
Sent: Sunday, January 27, 2002 7:51 AM
Subject: [noparse][[/noparse]basicstamps] Bar Code Readers
own
Tim
barcode reader.
own
or not portable?
too.
them away.
Tim
Cheers
Col
for sale?
create your own
code and
> Tim
