Large Numbers
Hello,
I'm controlling, serially, a device that sends me large 16 and 32 bit numbers
in a series of 8 bit packets. After I receive each number into a byte sized
variable, I think I can create 16 bit numbers by multiplying the first byte by
16 and then adding the second byte and storing that number into a word size
variable. Is this correct?
However, since word is the largest variable size on the stamp (i'm using a
bs2p), how do I combine four bytes to make a 32 bit variable that I can then do
math on (division mostly) ? Does anyone have experience dealing with large
numbers like this?
Stewart
Stewart Mayer, stewlist@k... on 11/29/2001
numbers like this?
Stewart
Or:
Word1 = Byte1
Word1 = Word1<<8 + Byte0
Or:
Word1.HighByte = Byte1
Word1.LowByte = Byte 0
That should work for 16 bits.
Combining for 32 bits is a bit tricky. Sure, you can store 4 bytes in a
byte array together. But the Stamp has no easy way to handle 32 bit
math. I show some tricks in my Stamp book and Tracy has a lot on his Web
site, but general purpose 32-bit math on the Stamp is a difficult
proposition.
Although it is probably overkill, consider a PAK-I, II, or IX :
http://www.al-williams.com/awce/pak1.htm
Good luck!
Al Williams
AWC
* Control 8 servos at once
http://www.al-williams.com/awce/pak8.htm
> From: Stewart Mayer [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=E22VRhWQHhwNBIryfOSMna9jBEJiwYkyR4h1i0cyxOteRGbJoICMzC4sv_bui9xJbLXyrc5M59WfWYG8XQo3FFPduA]stewlist@k...[/url
> Sent: Thursday, November 29, 2001 1:39 PM
> Subject: [noparse][[/noparse]basicstamps] Large Numbers
> Hello,
> and 32 bit numbers
> into a byte sized
> the first byte by
> into a word size
> (i'm using a
> that I can then do
> dealing with large
> numbers like this?
> Thanks,
> Stewart
> from the same email address that you subscribed. Text in the
would do it in most processors. I wonder if you could fake the high bit as
a carry bit and use that to carry mathematical operations into a second
byte? so 15 bits would be used as a representation from 0-32767, and the
16th bit wouldn't represent anything except carry, which would end up in
the second byte.
On Thu, 29 Nov 2001, Al Williams wrote:
> Word1 = Byte1 * 256 + Byte0
> Or:
> Word1 = Byte1
> Or:
> proposition.
> Good luck!
> Al Williams
> AWC
> > From: Stewart Mayer [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Wh-l41oKYA0UyEN3I6okCtat0-GI4Hl2QmmA10vjtb6-LvLoRAc3HPfqbllTfkAv-0INs0_yBQq8fovweD0cSFs]stewlist@k...[/url
> > Hello,
> > and 32 bit numbers
> > into a byte sized
> > the first byte by
> > into a word size
> > (i'm using a
> > that I can then do
> > dealing with large
> > numbers like this?
> > Thanks,
> > Stewart
Sean T. Lamont, CTO / Chief NetNerd, Abstract Software, Inc. (ServNet)
Seattle - Bellingham - Vancouver - Portland - Everett - Tacoma - Bremerton
email: lamont@a... WWW: http://www.serv.net
"...There's no moral, it's just a lot of stuff that happens". - H. Simpson
Hi Stewart,
You can receive the bytes directly into words
wx var word
wy var word
z0 var wx.byte0
z1 var wx.byte1
z2 var wy.byte0
z3 var wy.byte1
serin dpin,baudmode,[noparse][[/noparse]z0,z1,z2,z3] ' 4 bytes
That assuming that your device sends the least significant byte first.
>can then do
>numbers like this?
Check out http://www.emesystems.com/BS2math6.htm
The methods of integer math have to be tailored to each situation,
depending on the range of the variables.
>Thanks,
> Stewart
-- best regards
Tracy Allen
mailto:tracy@e...
mathmatical means to work with the large numbers.
stew
On Thu, 29 Nov 2001 12:18:20 -0800, Tracy Allen wrote:
>>Hello,
by
>Hi Stewart,
>wx var word
>wy var word
>z0 var wx.byte0
>z1 var wx.byte1
>z2 var wy.byte0
>z3 var wy.byte1
>>can then do
>>numbers like this?
>>Thanks,
>>Stewart
>-- best regards
>Tracy Allen
>mailto:tracy@e...
of the message will
>be ignored.
