cycle limit?
We are using a BS-2sX to run experiment 27, and we modified the code
so it'll run continuously. We were running it on a Board of
Education (Rev.
. The problem is, after running for a couple
thousand (?) cycles, the program would stop sending DEBUG commands to
the Stamp Editor. And the output, as monitored by an oscilloscope,
would also cease.
Why's that?
Thanx,
Jimmy
Education (Rev.
would also cease.
Why's that?
Thanx,
Jimmy
>Education (Rev.
>would also cease.
>Why's that?
Did you check the battery voltage ? The BS-2SX is rather power hungry.
>Thanx,
>Jimmy
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
the problem is still there.
-Jimmy
--- In basicstamps@y..., Bruce Bates <bvbates@u...> wrote:
code
> >Education (Rev.
to
> >would also cease.
> >Why's that?
hungry.
> >Thanx,
> >Jimmy
> > basicstamps-unsubscribe@y...
Subject and
>We found a 9-VDC AC-DC converter and plugged it into the board. But
>-Jimmy
>Jimmy -
I'm not familiar with that particular exercise, but are you exceeding the
limits of some variable ? The size (NIB, BYTE, WORD) will dictate the maximum
number that can be contained therein.
Bruce Bates
