HELP Control Varying Resistances
I need to be able to somehow change the resistance between two
outputs. For example with P0 and P1 set as outputs, I need an
external device to see 100k between them and then with a changes of
code, make it 50k or 0. Any ideas would be greatly appreciated
because I have been scratching my head for awhile on this. Thanks.
consigli@p... writes:
Dallas Semiconductor makes a variety of digital pots that you can control
very easily with SHIFTOUT.
-- Jon Williams
-- Parallax
my head I believe that an "audio volume knob" would do
the trick, as on a home stero. Basically I believe
that it is just a precision potentiometer with a
stepper motor attatched to it for the fine control up
and down the scale. You could build your own, but I
believe I have seen surplus for sale at Jameco or
maybe Electronic Goldmine. Going this route would
just be a matter of controlling the stepper to vary
the resistance of the pot. [noparse]:)[/noparse]
ross
> between two
> I need an
> with a changes of
> appreciated
> this. Thanks.
> from the same email address that you subscribed.
> Text in the Subject and Body of the message will be
> ignored.
__________________________________________________
Do You Yahoo!?
Yahoo! GeoCities - quick and easy web site hosting, just $8.95/month.
http://geocities.yahoo.com/ps/info1
your Stamp and it will change the output resistance accordingly. Plus,
you only need to use one Stamp pin. Digital pots are available through
Maxim <http://www.maxim-ic.com/>www.maxim-ic<http://www.maxim-ic.com/>.com
and others in several values. Maxim will also provide free samples for you
to try.
Tim
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
through a 0 ohm or 50K ohm resistor? Do it twice and you have a solution.
There's also something like a digital volume control which can step up and
down based on control pulses.
On Tue, 27 Nov 2001, Klutch wrote:
> Perhaps there is a better solution, but off the top of
> ross
> > between two
> > I need an
> > with a changes of
> > appreciated
> > this. Thanks.
> > ignored.
> Do You Yahoo!?
Sean T. Lamont, CTO / Chief NetNerd, Abstract Software, Inc. (ServNet)
Seattle - Bellingham - Vancouver - Portland - Everett - Tacoma - Bremerton
email: lamont@a... WWW: http://www.serv.net
"...There's no moral, it's just a lot of stuff that happens". - H. Simpson
reset, one for the clock, and one for the data. This may work though.
--- In basicstamps@y..., Timothy Medema <timm@c...> wrote:
> How about a digital potentiometer? You can send it a serial value
from
Plus,
through
ic.com/>.com
for you
> to try.
> Tim
> > basicstamps-unsubscribe@y...
Subject and
