Converting to ASCII for a Parallel PCD panel for BS2?
I am experimenting with a LCD panel and want to use it like a simple
digital thermometer.
I want to take a number and convert and output it to a LCD panel using
a BS2 Basic Stamp, the BS2 doesn't have a LCDcmd function.
if I have a word variable that is holding a value, how can I
convert that so it can be outputted to the LCD panel?
For example:
'{$STAMP BS2}
x var word
x = 1236
debug dec x
end
This displays 1236 out the serial port, but how would I show it on
a LCD panel?
For example:
'{$STAMP BS2}
x var word
x = 1236
debug dec x
end
a LCD panel?
When I have to display numbers, I use an array of characters.
text VAR byte(16)
Then, I prepare the text :
for i=0 to 15
lookup i,[noparse][[/noparse]"Temperature : "],text(i)
next
Finaly, if 'TEMP' is the variable containing the temperature, I use the DIG
function :
text(13)=48+(temp dig 1)
text(14)=48+(temp dig 0)
48 is the ASCII code of '0'. So if the temperature is 25, you get 50 and 53,
which are the codes for '2' and '5'
You just have to send the text array to the display (depending on the model
you have, serial / parallel)
Hope this helps...
Best regards,
Phil.
Sent: Saturday, November 24, 2001 5:34 PM
Subject: [noparse][[/noparse]basicstamps] Converting to ASCII for a Parallel PCD panel for BS2?
> For example:
> '{$STAMP BS2}
> x var word
> x = 1236
> debug dec x
> end
> a LCD panel?
> Thanks
I went through the manual several times and never saw it.
In regular basic (VB for example) you have CHR, ASC, VAL, et cetera,
I just never thought about the DIG function.
Thanks again, I appreciate it.
--- In basicstamps@y..., "Philippe Derenne" <derennep@s...> wrote:
> Hi,
> text VAR byte(16)
> for i=0 to 15
> next
use the DIG
> function :
50 and 53,
the model
> Hope this helps...
> Best regards,
> Phil.
> From: <earlwb@w...>
> To: <basicstamps@y...>
for BS2?
simple
using
> > For example:
> > '{$STAMP BS2}
> > x var word
> > x = 1236
> > debug dec x
> > end
> > a LCD panel?
> > Thanks
> > basicstamps-unsubscribe@y...
Subject and
