fuzzy math, referencing, and exchanging information
Thanks Tracy,
How can I reference bits and nibbles from other indices without
another byte variable? For instance, how can I reference a low nibble
for byte_array(3)?
Another question is what will happen if I do the following:
On the master (BS2SX):
dayh VAR nib
day VAR byte
Main:
SERIN 1\0, 16624, 30, [noparse][[/noparse]dayh, day]
GOTO Main
END
On the slave (BS2):
tdata VAR byte(9)
Main:
SEROUT 5\4, 16468, 30, [noparse][[/noparse]tdata(2), tdata(3)]
GOTO Main
END
What will dayh and day variables receive? Will it be
a.) dayh = tdata(2).highnib, day.highnib = tdata(2).lownib,
day.lownib = tdata(3).highnib
b.) dayh = tdata(2).lownib, day = tdata(3)
c.) dayh = tdata(2).highnib, day = tdata(3)
Can't think of any other multiple choice scenarios. any response will
be appreciated.
RP
--- In basicstamps@y..., Tracy Allen <tracy@e...> wrote:
> >I was wondering how I can address bits
> >and nibbles from a byte array. I found out that byte_array
> >(index).lownib is a syntax error.
> byte_array.nib0(index) will reference nibs.
> byte_array.bit0(index) will reference bits
> byte_array(0) is the same variable as byte_array
> example with alias names:
> byte_array var byte(8) ' array of 8 bytes
> bat var byte_array ' alias for the 0th byte
> ' e.g., bat(7) is the last byte of 8
> gnat var bat.nib0 ' alias for 0th nibble
> ' e.g., gnat(15) is the last nib of 16
> bitty var bat.bit0 ' alias for 0th nibble
> ' e.g., bitty(63) for the last bit of 64
> -- Tracy
for byte_array(3)?
dayh VAR nib
day VAR byte
Main:
GOTO Main
END
On the slave (BS2):
tdata VAR byte(9)
Main:
GOTO Main
END
be appreciated.
RP
> -- Tracy
>for byte_array(3)?
Hi Ravi,
I am not sure quite what you want to do, but the easiest way would be
to play tricks with the index.
low nib of byte_array(index) is byte_array.nib0(index*2)
and
high nib of byte_array(index) is byte_array.nib0(index*2+1).
For example, when index=3, the corresponding indexes for the low and
high nibs are 6 and 7. As you have discovered by now, you cannot get
away with, byte_array(3).nib0, a syntax error. And while
byte_array.nib0(3) is okay for syntax, is refers to the high nibble
of the second byte, not to the low nibble of the third byte.
>dayh VAR nib
>day VAR byte
>Main:
> GOTO Main
> END
>On the slave (BS2):
>tdata VAR byte(9)
>Main:
> GOTO Main
> END
I'm not sure what tdata(n) is. But if it is a byte array, then I
think the answer is (b). Serout and Serin always justfy each data
element as a byte.
BTW, the "30" in the serin and serout will become pacing delays. Is
that what you want, or do you want timeouts for flow control?
>be appreciated.
huh? Please explain more are you trying to do.
>Thanks,
>RP
> > -- Tracy
>from the same email address that you subscribed. Text in the
>Subject and Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
> >Thanks Tracy,
nibble
> >for byte_array(3)?
> Hi Ravi,
be
> and
and
get
How would I alias them? So far, I have gotten syntax errors when I
type, for instance, "jhday VAR tdata.nib0(4)." However, I
will try to work with what you are saying.
> >dayh VAR nib
> >day VAR byte
> >Main:
> > GOTO Main
> > END
> >On the slave (BS2):
> >tdata VAR byte(9)
> >Main:
> > GOTO Main
> > END
> element as a byte.
Is
oops, I wanted timeouts for flow control. Just include "main" after
30. Sorry about that.
will
> >be appreciated.
I have an 8-byte string which contains the time code. Each bit in the
bytes is representative of days, times, signal status, etc.
Thus, I am trying to parse a nibble and/or bits out of a particular
(appropriate) byte in an array and send them to a different stamp.
I hope that clears up any confusion.
RP
> >Thanks,
> >RP
> > > -- Tracy
> > basicstamps-unsubscribe@y...
Do you remember this site:
http://www.jamesrusso.com/stamp/archive/1998/stamps.9809/msg00660.html
I am trying to make the BS2 work as a decoder and the BS2SX my
central MC to interface with other applications. That is why I asked
questions about how to reference nibbles and bits from other array
indices.
> >Thanks Tracy,
nibble
> >for byte_array(3)?
> Hi Ravi,
be
> and
and
get
> >dayh VAR nib
> >day VAR byte
> >Main:
> > GOTO Main
> > END
> >On the slave (BS2):
> >tdata VAR byte(9)
> >Main:
> > GOTO Main
> > END
> element as a byte.
Is
will
> >be appreciated.
> >Thanks,
> >RP
> > > -- Tracy
If you need to refer to variables both with a fixed name and as an
array, here is the trick I use. First define all the fixed variable
names in the specific order you want them. You can then use the
first variable you define with an array index, even though you have
not explicitly declared it as an array. The array is "implicit".
This is a tricky "feature" of the way the Stamp allocates memory.
You can refer to _any_ variable with an array index, and the stamp
will return values from successive positions in memory, and the size
of those variables (bit, nib, byte word) is the same as the size of
the variable referenced. Exammple:
tdata0 var byte
tdata1 var byte
tdata2 var byte
tdata3 var byte
tdata4 var byte
tdata5 var byte
tdata var tdata0 ' an alias for array addressing
tnibs var tdata.nib0 ' a nib alias for array addressing
tnib10 var tdata5.nib0 ' nib aliases for fixed addressing
tnib11 var tdata5.nib1
ii var nib
for ii=0 to 5
tdata(ii)=ii ' the array is implied, fill it
next
tdata5=tdata(2)+tdata3 ' can refer to fixed or array name
debug dec tdata5, tab, dec tdata(5),cr ' show same thing
for ii = 0 to 11
tnibs(ii)=ii ' fill up as 11 nibs
next
debug hex tdata5, tab, hex tnib10,tab, hex tnibs(11),cr
end
One question though.
Do those variables have to be the first ones declared in any program
or can I declare other variables prior?
RP
variable
size
> tdata0 var byte
> tdata1 var byte
> tdata2 var byte
> tdata3 var byte
> tdata4 var byte
> tdata5 var byte
> ii var nib
> for ii=0 to 5
> next
> for ii = 0 to 11
> next
> end
>Regards,
>RP
You can declare other variables prior. The important thing is to
declare them in the order that you want them in the array. The Stamp
compiler allocates memory as follows: first all the word variables
in the order you declare them, then the bytes, then the nibs and last
the bits. If you declare a bunch of bytes in a certain order, that
is how they will end up in the Stamp memory.
>variable
