Help...again!
Hi
Ok, I followed the advice Tracy gave, and it worked... So, I was
sending data from the basic stamp to the tranciever, and looked at the
result in another transceiver to see if it sent the data... it did!
Ok, so, then, all happy and all, I went to the next stage... I built a
circuit for the computer that would take in the transmitted data,
convert to RS232 and connect to a serial port connector. Pin 2 is
connected for the data into the computer and pin 5 is grounded. The
rest of the pins for the serial connector I did not touch. please
note, that there is NO basic stamp on the computer end (can't afford
it for our budget)... so, we were hoping this C program would help us
in outputting the data...
The C program that I am using is the following... however, when I
tried my system out.. I got NOTHING on the computer side (ie, nothing
printed on the screen)... can someone tell me what am i doing wrong?
Thanks... now I gotta go to class...
Debu
#include <dos.h>
#include <stdio.h>
#include <conio.h>
#define PORT1 0x3F8
/* Defines Serial Ports Base Address */
/* COM1 0x3F8 */
/* COM2 0x2F8 */
/* COM3 0x3E8 */
/* COM4 0x2E8 */
void main(void)
int c;
int ch;
outportb(PORT1 + 1 , 0); /* Turn off interrupts - Port1 */
/* PORT 1 - Communication Settings */
outportb(PORT1 + 3 , 0x80); /* SET DLAB ON */
outportb(PORT1 + 0 , 0x03); /* Set Baud rate - Divisor Latch Low
Byte */
/* Default 0x03 = 38,400 BPS */
/* 0x01 = 115,200 BPS */
/* 0x02 = 57,600 BPS */
/* 0x06 = 19,200 BPS */
/* 0x0C = 9,600 BPS */
/* 0x18 = 4,800 BPS */
/* 0x30 = 2,400 BPS */
outportb(PORT1 + 1 , 0x00); /* Set Baud rate - Divisor Latch High
Byte */
outportb(PORT1 + 3 , 0x03); /* 8 Bits, No Parity, 1 Stop Bit */
outportb(PORT1 + 2 , 0xC7); /* FIFO Control Register */
outportb(PORT1 + 4 , 0x0B); /* Turn on DTR, RTS, and OUT2 */
printf("\nSample Comm's Program. Press ESC to quit \n");
do { c = inportb(PORT1 + 5); /* Check to see if char has
been */
received. */
if (c & 1) {ch = inportb(PORT1); /* If so, then get
Char */
printf("%c",ch);} /* Print Char to
Screen */
if (kbhit()){ch = getch(); /* If key pressed, get Char
outportb(PORT1, ch);} /* Send Char to Serial Port
} while (ch !=27); /* Quit when ESC (ASC 27) is pressed */
Debu
#include <dos.h>
#include <stdio.h>
#include <conio.h>
#define PORT1 0x3F8
/* COM1 0x3F8 */
/* COM2 0x2F8 */
/* COM3 0x3E8 */
/* COM4 0x2E8 */
void main(void)
int c;
int ch;
Byte */
Byte */
been */
received. */
Char */
Screen */
