I''m working on a full automatic aquarium
How 'bout a mechanical solution.
Here at my cube I have a fluorescent lamp with a plastic sleeve over it.
This plastic sleeve is printed with a black mask that is very dense on one
side and gets progressively lighter as it goes around the tube. To adjust
the brightness you simply rotate the tube.
You could print a mask to overhead transparency film wrap this around a
length of transparent tubing (for rigidity) rig the tube around the
fluorescent lamp and rotate it with a stamp controlled stepper.
Or a little more high tech. Find some surplus lcd shutters. I think I saw
one in this months Nuts & Volts mag.
Best Regards,
Mike Witherspoon
From: iceninevt@y... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ADgLsrYNWMVMuWIPLiQ6z_-zC4v5CwqKCnJBzq-NJ-0xstYOCO8ukzGffhPAygyMFk4u_GkbfPSmrgRJ]iceninevt@y...[/url
Sent: Tuesday, November 20, 2001 9:07 AM
Subject: [noparse][[/noparse]basicstamps] Re: I'm working on a full automatic aquarium
Dimming flourescent tubes requires the use of a special ballast and
dimmer. The ballast is either expensive, or very expensive, depending
on the size/number of lamps. Even with the necessary ballast and
dimmer the effect is not smooth. I doubt you will be satisfied.
--- In basicstamps@y..., "Smalcor" <Smalcor.AmusementsProducts@1...>
wrote:
> Hello, I have a few problems, I'm trying to control fluorisent
light. I know it is possible, I only don't know how ! I Want to use
this for my aquarium and for a neighbour of me who has his special
birds in his house.
> I'm trying to build a circuit to be able to smoothly turn on my
fluorisent lights of my aquarium in the morning and smoothly turn
them off in the evening. I want this to be controlled by a basic
stamp. Also I would like to monitor my temperature and PH value end
display this together with the current time on a LCD. Has anyone any
experiences with this or is there someone who can help me work this
out?
> [noparse][[/noparse]Non-text portions of this message have been removed]
Best Regards,
Mike Witherspoon
birds in his house.
out?
