Bs2p-40 q
Just a quick sanity check..after skimming the docs it looks to me as if the 16
aux I/Os can be used as argumants anywhere the regular pins are if the AUXIO
command is invoked. Is this correct?
Also, does DIRS become a 32 bit word instead of the 16 bits I'm used to on my
BS2, or do I need to do an AUXIO/MAINIO switch to set the directions of the aux
I/O pins?
-dave
p.s.
I can't wait for a new version of the editor that will automagically handle the
pin mapping for the -40 part so that I can tell it to use pins 0-31 instead of 2
banks of 0-15...
Oh yes I'll see you, see you on the other side.... -Ozzy
dave paton http://www.dpaton.net dave at ieee dot org
I/O pins?
-dave
p.s.
banks of 0-15...
That's right.
>of the aux I/O pins?
DIRS is still 16 bits. Use AUXIO or MAINIO to choose which one to use.
BTW, the mainio and auxio commands also work on the BS2P-24, even
though the -24 does not have the extra 16 i/o pins. The OUTS and
DIRS registers can be used as ram. However, be careful. The pins
are actually there on the SX48 chip, and you can even tap into the
extra 16 signals with a fine wire or a probe. Do not leave those
pins in a state that will draw excess current. They are initialized
as low outputs (I think that's right). I wish we had some little
pads on the BS2P-IC so we could easily hack into at least a few of
those lines.
-- best regards
Tracy Allen
http://www.emesystems.com
mailto:tracy@e...
writes:
> 16
Yes, this is correct. To get back to the main pins, use MAINIO.
> aux
> I/O pins?
No, there is just another Dirs (and Ins and Outs for that matter). The
secondary set is invoked with AUXIO -- just like the pins.
writes:
> the
> of 2
That is not a planned upgrade as it would require the editor modifying your
code, which could lead to unpredictable behavior.
-- Jon Williams
-- Parallax
Oh well...
-dave
