One Final Infrared Question — Parallax Forums
edited 2001-11-19 20:58 in General Discussion
I have a radio shack infared detector (276-137). I have it powered
to 5v & grounded. I hae a voltmeter connected to the Vout wire. When
there is no IR present, the meter reads 5.0v. When I point a remote
control at the detector and hit a button, the voltage drops to about
3.4x volts. Shouldn't the voltage go low (around 0v) when it is
detecting IR?
the Radio shack manual is terrible and gives no insight into my
problem.
Any help would be greatly appreciated
    edited 2001-11-19 20:51
    IR signals are pulsed digital streams. It probably IS going to 0V, and
    then back up to 5V, but your voltmeter is reading the averages. Try
    hooking it up to a serial port or read it from a stamp or something.
    > detecting IR?
    > problem.
    Sean T. Lamont, CTO / Chief NetNerd, Abstract Software, Inc. (ServNet)
    Seattle - Bellingham - Vancouver - Portland - Everett - Tacoma - Bremerton
    email: lamont@a... WWW: http://www.serv.net
    "...There's no moral, it's just a lot of stuff that happens". - H. Simpson
    Hi
    If you look at the output with a scope you will probably see pulses because
    the remote is sending pulses. you are seeing the RMS value I suspect.
    hope this is some help.
    PS Try using a latch on the output.
    Lawrence C. Windrem
    lwindrem@p...
    lwindrem@g...
    Sent: Monday, November 19, 2001 3:45 PM
    Subject: [noparse][[/noparse]basicstamps] One Final Infrared Question
    > detecting IR?
    > problem.
