TTL OR gate or diodes?
Hello Stampers,
I've got two TTL level IR detectors who's logic level is inverted,
and I only have one stamp pin to work with. I'm only trying to
detect the situation when both detectors are exposed to the IR led,
meaning that there is no signal coming from either detector.
Here is the truth table:
0 + 0 = 0
0 + 1 = 1
1 + 0 = 1
1 + 1 = 1
Can I connect the TTL outputs of both the detectors to the same stamp
pin with protection diode's to prevent reverse voltage (when one is
on and the other is not). Or, do I have to put a logic chip in my
design? I'd rather not add another space consuming chip.
Stewart
Stewart Mayer, stewlist@k... on 11/19/2001
0 + 0 = 0
0 + 1 = 1
1 + 0 = 1
1 + 1 = 1
Stewart
I would simply use 2 diodes and a resistor : each anode connected to the
output of each detector, cathode connected together and thru a 10K resistor
to the ground. That way, if one (or both) detector gives a high, one (or
two) diode is forward-biased, you get a 4.3 or 4.4 volt at the common
cathode. If both detectors give a low, then you get a low. That's it !
I think this is the simplest way to do AND functions... no chip, no power
supply.
Best regards,
Phil.
Subject: [noparse][[/noparse]basicstamps] TTL OR gate or diodes?
> Hello Stampers,
> 0 + 0 = 0
> 0 + 1 = 1
> 1 + 0 = 1
> 1 + 1 = 1
> Thanks,
> Stewart
Stewart
On Mon, 19 Nov 2001 20:51:00 +0100, Philippe Derenne wrote:
>Hi Stewart,
the
resistor
(or
common
power
>supply.
>Best regards,
>Phil.
>From: "Stewart Mayer" <stewlist@k...>
>>Hello Stampers,
>>0 + 0 = 0
>>0 + 1 = 1
>>1 + 0 = 1
>>1 + 1 = 1
stamp
>>Thanks,
>>Stewart
>basicstamps-unsubscribe@yahoogroups.com
>from the same email address that you subscribed. Text in the
Subject and Body of the message will
>be ignored.
>Your use of Yahoo! Groups is subject to
