Infrared detector Troubles. HELP
I have a basic stamp2. Can someone please tell me how to correctly
hook up the detector and emmitter to the stamp and the correct code.
When I use stampsinclass.com's directions, the object is always
detected, no matter where I point the emmitter. I have the emitter
and detector side by side. When I unplug the emmitter, the signal
osciallates and it flickers between detected/not_detected. I have no
idea whats wrong!
Thank you!
rblundel@f...
idea whats wrong!
Thank you!
rblundel@f...
trigger alot of I/R detectors. Also, you may need to put a shield around the
LED (emitter) to direct it forward -- otherwise I/R escapes from the sides
and rear and will trigger the sensor if its nearby. Many use a piece of
shrink tubing over the LED.
> idea whats wrong!
> idea whats wrong!
> idea whats wrong!
> idea whats wrong!
> idea whats wrong!
> You need to make sure you don't have fluorescent lights on -- they seem to
the
> > idea whats wrong!
wrapped with electrical tape).
Al Williams
AWC
* Floating point A/D
http://www.al-williams.com/awce/pak9.htm
> From: Rodent [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=SMNgZsXrpbNE4gVXYXn_fCIA_EtRzOoKmtyMr0HH7B499Sz_5v_jliOvYk75Jn3ETqCyK7Mhvw5-]daweasel@s...[/url
> Sent: Saturday, November 17, 2001 10:22 PM
> Subject: Re: [noparse][[/noparse]basicstamps] Infrared detector Troubles. HELP
> they seem to trigger alot of I/R detectors. Also, you may
> need to put a shield around the LED (emitter) to direct it
> forward -- otherwise I/R escapes from the sides and rear and
> emitter and
> I have no
> > idea whats wrong!
> from the same email address that you subscribed. Text in the
aluminum block drilled to hold the LED and a small brass tube to further
reduce the side scatter. I was using one of the Panasonic sensors and fitted
it to the same aluminum block so that it looked out through a 1/16" vertical
slot. I had a good 15-18" range with a very narrow field of view -- at 12"
the field was about 2-3 inches wide.
Keep in mind some things pass I/R even though visible light will not
penetrate. Black antistatic foam is very good for blocking / absorbing
I/R -- would make a good sumo robot skin too...
> FWIW, I use a cut off piece of soda straw glued in place (and possibly
> > emitter and
> > I have no
> > > idea whats wrong!
